Csicsóka
DoItYourself
#46549
Vannak még olyan partíciók az eMMC-ben amit a droid "egyéb" dolgokra használ, ez nem látszik.
A system, cache, data közönséges ext4 partíciók, amik együttes mérete kb. 6.5 GB.Itt látszik is, USB-ről futó **MC alatt:
osmc-megogo ~ # df
Fájlrendszer Méret Fogl. Szab. Fo.% Csatol. pont
devtmpfs 306M 0 306M 0% /dev
/dev/sda2 7,0G 1,1G 6,0G 16% /
tmpfs 407M 0 407M 0% /dev/shm
tmpfs 407M 42M 366M 11% /run
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 407M 0 407M 0% /sys/fs/cgroup
tmpfs 407M 4,0K 407M 1% /tmp
/dev/sda1 256M 9,1M 247M 4% /boot
tmpfs 82M 0 82M 0% /run/user/0
/dev/data 4,8G 641M 4,2G 14% /root/mnt
/dev/cache 496M 608K 486M 1% /root/mnt1
/dev/system 976M 150M 811M 16% /root/mnt2A többit pedig a dtb-ből lehet meglátni.
partitions {
parts = <0xb>;
part-0 = <0x36>;
part-1 = <0x37>;
part-2 = <0x38>;
part-3 = <0x39>;
part-4 = <0x3a>;
part-5 = <0x3b>;
part-6 = <0x3c>;
part-7 = <0x3d>;
part-8 = <0x3e>;
part-9 = <0x3f>;
part-10 = <0x40>;
logo {
pname = "logo";
size = <0x0 0x2000000>;
mask = <0x1>;
linux,phandle = <0x36>;
phandle = <0x36>;
recovery {
pname = "recovery";
mask = <0x1>;
linux,phandle = <0x37>;
phandle = <0x37>;
rsv {
pname = "rsv";
size = <0x0 0x800000>;
mask = <0x1>;
linux,phandle = <0x38>;
phandle = <0x38>;
tee {
pname = "tee";
mask = <0x1>;
linux,phandle = <0x39>;
phandle = <0x39>;
crypt {
pname = "crypt";
mask = <0x1>;
linux,phandle = <0x3a>;
phandle = <0x3a>;
misc {
pname = "misc";
mask = <0x1>;
linux,phandle = <0x3b>;
phandle = <0x3b>;
instaboot {
pname = "instaboot";
size = <0x0 0x20000000>;
mask = <0x1>;
linux,phandle = <0x3c>;
phandle = <0x3c>;
boot {
pname = "boot";
mask = <0x1>;
linux,phandle = <0x3d>;
phandle = <0x3d>;
system {
pname = "system";
size = <0x0 0x60000000>;
mask = <0x1>;
linux,phandle = <0x3e>;
phandle = <0x3e>;
cache {
pname = "cache";
mask = <0x2>;
linux,phandle = <0x3f>;
phandle = <0x3f>;
data {
pname = "data";
size = <0xffffffff 0xffffffff>;
mask = <0x4>;
linux,phandle = <0x40>;
phandle = <0x40>;
blakey
DoItYourself
#46458
Elvileg S905D. De mindegy, mert itt nem a procival van a gond hanem valami mással, S905W ami ugye az egyik leggyengébb S905-ös SoC még az is pufferelés nélkül indítja a 4K 24fps-t Ce-vel, kártyáról, Vero-n meg a FHD is pufferel, a burosch.mpg anyagot is puffereli fél percig, ilyennel még nem találkoztam.
Természetesen hálózati lejátszásról beszélek, mert elsősorban úgy próbáltam a lejátszást.
Ha elindul akkor hasonló a többi cucchoz, melegedés némileg megoldott, annyira azért nem melegszik, mint egy X96, ha már abba a házba került.. -
Met
DoItYourself
#46419
Jó persze, meg tudom oldani hogy lássam amit kell.
Csak nem értem hogy mi történt. -
Met
DoItYourself
#46375
Már annyira nem zavar hogy időnként tisztítani kell, inkább az zavar hogy egy csomó minden nem látszik.
Multibit
DoItYourself
#46389
... és 75 ohmos BNC (mint leginkább szabványos coax)
vargalex
DoItYourself
#46069
Jó sokáig nem olvastam a topic-ot, így ez a hozzászólás most jött szembe és valahogy az összefoglaló hivatkozott része is kimaradt eddig...
A 3,5mm Jack SPDIF koax kimenet egyáltalán nem kínai találmány, anno több hangkártyán is ilyen volt. Többek között pl. a Creative Sound Blaster Live! kártyán is már 1998-ban.
Ha viszont félreértettem, akkor bocsi...
blakey
DoItYourself
#46375
Milyen, jó? Még nem próbáltam.
Shummo
DoItYourself
#46360
Csicsóka
DoItYourself
#46286
Igen néztem, de ezzel sem jó. Sajnos itt hardveres gond van, az RTL 8211F gigabit chip beteg. Forrasztás, kontakt a csatlakozóban, kábel rendben van.
havri1
DoItYourself
#46289
Ezen a mecool m8s prox -en sztem nincs reset. Van egy apró nyílás alul, de nincs mögötte gomb.
ztsoft
DoItYourself
#46184
Nekem nincs gondom DD+ hanggal a CE 8.95.4.2-es alatt (ahogy a mostani Nightly-vel sem).
Ha nem engedélyezem a DD átkódolást, akkor sima PCM 2.0-át ír az erősítő (48 kHz-en, így a TV is szól), ha engedélyezem, akkor DD 5.1-et ír.
Ha engedélyezem a DD+-t, akkor nincs hang, a fenti beállítástól függetlenül.Igaz, nálam másképp van bekötve.
Box - HDMI - TV.
Box - optika - erősítő.Megnéztem úgy is, ahogy Neked van bekötve, de nekem a TV (Samsung H6400) nem engedi át a tömörített több csatornás hangot a HDMI-ből optikára.
blakey
DoItYourself
#46195
Megnéztem, 3 DD+-os anyaggal és tökéletesen működik, akár AC3-ra konvertáva akár sztereóra állítva, HDMI-n keresztül legújabb (CoreELEC-S905.arm-9.0-nightly_20181103) Nightly-val és ebben már megint van 4K 60Hz.
Wasquez
DoItYourself
#46142
Köszönöm!
junkpod
DoItYourself
#46184
Mi ebben a különleges? Csak akkor van dd+ hang ha engedélyezed a dd+ hangot? Szvsz ez ok.
FNZ
DoItYourself
#46120
CE-t felmásoltam a leírtak alapján egy 16 gb-os sd kártyára. nyomom a reset gombot, áramot adok, de csak a mecool felirat van és nem történik semmi.
akkor nincs bekötve a reset gomb?
próbáljam meg ezt? -
Khaosz55
DoItYourself
#46156
Elolvastam az összefoglalót kb a végén azt sem tudtam mit akarok. Beelink GT1 jó választás?
Janaboy
DoItYourself
#46135
Ezt mondtam en is a faternak, de nem akarja ugy.
a.t.t.i.
DoItYourself
#46125
Másik boxnál csináltam,dualbotttal,de azt hiszem ezen nincs reset gomb.
darvinya
DoItYourself
#46069
Nem szabványos megoldás, kínai találmány…
Ez így nem teljesen igaz, mert 3.5 jack szabványos.
Az, hogy RCA helyett alkalmaztak 3.5 jack-et, nem más mint alternatív csatlakozás hely hiány miatt.Akkor lenne nem szabványos, ha teljesen egyedi csatlakozást alkalmaznának.
Beni2360
DoItYourself
#46069
OK, rendben, értettem.
Akkor én itt feladom mert elég sok mindent mondanak és mást.
Emlékszem valami már volt erről de ott volt a kimeneten piros fény.
Jelenlegi boxaimon minden van toslink kimenet, így részemről ez a téma lezárt nem folyok bele és a kezemre csapok legközelebb ha kedvem támad ilyenbe belefolyni.
Ui: Az összefoglaló ezen része kimaradt vagy már nem emlékszek rá.
akela91
DoItYourself
#45968
Megcsináltam, de nálam ez nem segít, minden felbontáson igazítanom kell ezek után is a Video calibration alatt. (szerencsére már meg is jegyzi a whitelist állítás után, és reboot után is jó marad)
LG B8-am van, és OFF-on van aminek offon kell lennie. Androidos Kodi 17 alatt is és CE-s KODI 18 alatt is ugyanez a helyzet.
Nézzétek meg, lehet csak nem tűnt fel, hogy pár pixellel al van csúszva a KODI itt-ott. Van ahol ilyen 50-el arrébb kell tolnom.
Alien!
DoItYourself
#45903
dvdfab 10, h264 / 2 pass. (CUDA), 17-18mbit, arra kell figyelni, hogy képaránynak eredetit kell választani (szélesvászon esetén kódolja a fekete sávokat is) akkor nem csúszik szét a 3D kép.
Márton beállításával (3840x1080 full-sbs), a h265 is jó, viszont én evvel kevésbé éles képet kapok passzívon. -
darvinya
DoItYourself
#45844
Ezzel vitatkoznék, mert pl:.X96mini-nél lévő szilikon párna+fémlap drágább, mint 2×2×0.5 borda+szilikon paszta.
Utóbbi ráadásul jobban adja le a hőt, hiába kisebb.(#45843) Márton
Próbáld ki előző hsz-ben lévő CE verziót, de felrakás után net nélkül kapcsold ki a frissítést, hogy ne frissüljön automatikusan.
z-csongor
DoItYourself
#45778
Powerline-nak nalam nem sok ertelme lenne, mert annyibol kijon egy Amazon FireTV stick.
Tehat azt mondod, hogy a leggagyibbat vegyem meg (Pontosan melyiket) es egy ac-s USB sticket melle? Tudsz valami oldalt/forumot mutatni, ahol jobban bele lehet melyedni, hogy pontosan milyen stickek kompatibilisek, netan egy osszehasonlitas?
akela91
DoItYourself
#45772
Nem, TANIX TX9 PRO 3GB/32GB. Nagyon bejön, pár hete használom. Az elején az alap androiddal majd CE - vel. Ajánlom. Gigabites ethernet van rajta, EU-ból jött 68$ért.
Ágoston1007
DoItYourself
#45678
Szia, köszönöm a gyors választ
Az a baj, hogy ha bekapcsolom a hangtovábbítást, akkor van HDMI és SPDIF is, de így az erősítő 2.0-t kap. Ha bejelölöm, hogy ac3 kompatibilis vevőkészülék, akkor az erősítő 5.1 lesz, de akkor meg a tévé elhallgat. Kipróbáltam már mindenféle beállítást, de nem sikerül. Csatornák száma 2.0 vagy 5.1; kimeneti konfiguráció optimális, vagy leginkább egyező. Rögzített nem lehet, mert akkor nincs hangtovábbítás....
Lehet, hogy nem lehet?😞
Üdv: Ágó
UI.: 45655 kérdésre esetleg van ötleted?
DoItYourself
#45583
90 dollár Lengyelországból, ingyen postával:
Mecool KI Pro
A Vero némileg drágább, úgy tudom. -
Met
DoItYourself
#44995
Úgy néz ki nem működik.
Vagy csak valamit nem jól állítottam be.
-szabi-
DoItYourself
#45494
Ez volt a megoldás.
Kipróbálom a delay és period értéket átállítani.
Köszi.
Shane83
DoItYourself
#45449
Ja, értem. Köszönöm!
szabi__memo
DoItYourself
#45449
Shane83
DoItYourself
#45441
Értem. Ezek szerint már nem tervezitek, hogy lesz ilyen a folytatásban? Esetleg csak annyit, hogy frissítés után írnátok ide a topikba egy hozzászólást. Elég is lenne annyi, hogy "Frissítve: S905W és BB2" és az összefoglaló elején pedig linkelnétek a hozzászóláshoz. Szerintem sokan örülnénk neki.
És előre is köszönjük, ha megoldható a dolog!
messer30
DoItYourself
#45441
igen!
-szabi-
DoItYourself
#45358
Szia
Végül a nagy-tesót rendeltem meg: Tanix TX3 Max 28€.
Köszi.
Egyébként mostanában 10-15 nap alatt itt vannak a cuccok az aliról.üdv
-szabi-
DoItYourself
#45348
Hi
Igazad van.
Mindenképp 2/16gb kivitelt szeretnék.
Valamint S905x procit favorizálom.
Ami rendelhető is azok közül ezt találtam:
MAGICSEE N5 29€
Erről van valami tapasztalat?
A GB vásárlói visszajelzések elég vegyesek.Az összefoglaló nem ajánlja S905w procival szerelt box-okat, viszont a linkelt hozzászólások 10 hónaposak.
Azóta van valami javulás ezekkel?
Ha mindössze 4k60Hz amivel kevesebbet tud azt túlélem.
Mert akkor ez a három is szóba jöhet:
X96 Mini 29€
Tanix TX3 Mini 31€
Alfawise S95 32€Mit gondolsz?
üdv
szabi -
Márton
DoItYourself
#45343
CE-m nincs, csak LE.
köszi, akkor marad a tv fapados lejátszója ha full minőséget akarok
kgymac
DoItYourself
#45280
Utoljára kb. fél éve olvastam, nem emlékeztem rá, csak másik kodis topicból.
Kapanyél
DoItYourself
#45162
Igen, még Androiddal kipróbáltam CE előtt, akkor kente el a számat kapásból, hogy nem csatlakozik az 5G-shez. A DVB miatt még rápróbálok egy LE-t majd, csak feltúrok egy másik memóriakártyát a művelethez...
divan
Azt olvastam, hogy tuner csak LE alatt megy szinte, a többin felejtsem el, de nagyon keveseknek van ilyen változat, szóval az info is kevés a neten a témáról. A dtb a K1pro-s, a másik S905D-hez valóval még annyira sem megy, mint ezzel. Köszi, hogy ránézel!
blakey
DoItYourself
#45153
Még megvan a Pro L is.
blakey
DoItYourself
#45150
Miért, van rajta LAN? 😁
Carvus
DoItYourself
#45067
dugesz77
DoItYourself
#44996
Én még anno ezt a xiaomit vettem csak sajnos most már nem árulják. Pedig betyár jó minőség,nagyon stabil a bt kapcsolat és eddig az összes boxom felismerte. De vettem még az RPI2 retropie alá ilyen SNES usb-s irányítót is azzal sem volt gond eddig.
kenand
DoItYourself
#44943
Köszönöm, akkor a 905x2-re LibreElec /Linux még nem igen lesz...pedig az USB3/Gigabit LAN vonzó lehetne...
Keef_Lee
DoItYourself
#44960
direwolf
DoItYourself
#44872
Milyen whitelistet?
ztsoft
DoItYourself
#44843
Köszönöm, hogy megnézted!
Én Android alatt a gyári lejátszót nem bírtam rávenni, hogy a 3D MVC-t lejátssza (érdeles módon, minden egyes indításnál más-más hibát dobott), volt még egy DLNA lejátszó az csak 2D-t tudott.
Akkor a CE alatti 3D iso-t, MVC-t is elengedem.
Egyre jobban hajlok afelé, hogy a NAS lesz a média center is, azaz, HTPC.
djnice
DoItYourself
#44849
Lehet, de nem csinál semmit
Dikri
DoItYourself
#44752
Nem csak médialejátszásra vettem, gyermekeim szoktak játszani rajta.
CE jobb mint LE, csak mert az van rá opimalizálva LE. -
RedCat
DoItYourself
#44700
Hihetetlen, ez volt a baj. Köszi mindenkinek a segítséget!
Digitalis
DoItYourself
#44657
Igen, tegnap este. Szokásos. Már a boot.img-t sem látni, unsupported videó format-tal nyit. (CE-t bootolás után már a CVBS kompoziton sem látom, lehet nem is támogatja már)
TV-szervizmenüben nincs hibakód"no errors buffer" és minden a helyén. -
Csicsóka
DoItYourself
#44569
A vero4k+ csak osmc, nuku droid. Az is kell neki.
Skyner
DoItYourself
#44569
Igen, Minix Neo U9-H a kiszemelt (S912), nem az U1 (S905).
Folyamatos használathoz ajánlott hozzá egy billentyűzet+egér, vagy elegendő a hozzáadott távirányító?
Belföldi vs. külföldi beszerzés között kb. 8000 Ft különbség van, viszont a hazai 2 év garancia talán megéri a nyugalmat. Szerintetek is?Esetleg érdemes a Black Friday-t kivárni? Szokták ezeket a boxokat ilyenkor akciózni (idehaza és/vagy külföldi webshopokban)?
darvinya
DoItYourself
#44506
Excelvan E09 projektor típusa, rövid fókusztávolságú.
Majd kipróbálom, SD kártyával úgysem rontható el, max. nem indul el CE.
Október közepére itt van elvileg. -
128bit
DoItYourself
#44345
Az újabbakkal mi a gond?
Nem veszek észre semmi problémot 8.95.2 vel sem .igaz ritkán használom mostanában -
Lacko66
DoItYourself
#44250
Másik kártyára 8.95.0-t téve (ami gyakorlatilag azonnal frissült 8.95.2-re) ugyanez a helyzet, a kép belassul és akadozik, a hang rendben. MediaInfoval megnézve a Barry Gibb videót azt látom, hogy 3 azonos hangsáv van benne. TSMuxerrel kiszedtem 2 hangsávot, csak az elsődlegest hagytam benne hátha ez is befolyásol valamit de semmi változás. A fájl nevében található 422-es szám alapján a tévém HDMI Ultra HD csatlakozását átállítottam UHD 4:4:4/4:2:2-re de a hiba továbbra is fennáll. Próbaképpen raktam a kártyára egy régebbi LibreELEC-S905.arm-7.0.3.012l-t de ugyanaz a helyzet. Több ötletem nincs, visszaraktam a 8.2.3.1-es kártyát és átkódolom ezt a 2 videót progresszívbe. Egyébként is interlace videóba nagyon-nagyon ritkán futok bele és ha ez a lejátszási hiba újra jelentkezne akkor belefér az időmbe átalakítani progresszívbe.
Köszönöm a segítséget.
er2es
DoItYourself
#44098
köszönöm!
zoli03
DoItYourself
#44081
Azért annyira utánanéztem, hogy nincs a MECOOL-on 3,5mm-es jack kimenet fejhallgatónak. A TV-n sincs, erősítőm nincs, nem is kell nekem. Az összefoglalót olvastam, Bluetooth-szal nem akarok szórakozni, optikai hangkimenet nincs a MECOOL-on. Az működik, hogy összekötöm a TV-boxot HDMI kábellel a TV-vel, és a TV optikai hangkimenetéről veszem le a hangot egy külső hangkártyával? (Azokon már van fejhallgató kimenet).
DoItYourself
#44042
Itt írja, hogy hogy rakták hozzá a gigabitet, amit amúgy Sam nem nagyon tartott szükségesnek:
"I’m still not of the opinion that Gigabit Ethernet is necessary. It is however, nice to have. But it has to work properly. Implementing it in a way that works well was quite difficult and we were lucky to get this in."
blakey
DoItYourself
#44045
S905D lesz, szinte biztos, egyébként van egy ilyen infó csak elfelejtettem betenni:
"As soon as Leia is final, I will focus on mainline S905D/X only" - Adam ezt írta, hogy ez tényleg így lesz-e vagy sem azt nem tudom. -
DoItYourself
#44042
Erre én is nagyon kíváncsi vagyok. Mivel tudom megnézni?
blakey
DoItYourself
#44045
Sam a megjelenéskor írta, ha megtalálom akkor idézni fogom.
(#44044) ztsoft
Kezdesz felcsigázni és keresem a válaszokat a miértre
, nálam nincs akadás és ma megint CE-n fogom nézni, kifejezetten az akadásokat fogom tesztelni. -
blakey
DoItYourself
#44042
S905D(2), emlékeim szerint, ha ez lenne a kérdés lényege.
Keef_Lee
DoItYourself
#43947
Kösz. Igen, de 2 GB ram kellene, mert hátha át kell ugrani böngészni. (Mondom ezt úgy, hogy beüzemelése óta nem jártam az LE-n kívül a Sunwellel)
Viszont az még 2+8-as volt. Az volt számomra a megfelelő memória kombináció. Már nincs is ilyen, mert ha 2 a ram, akkor már 16 a rom. -
mgaben
DoItYourself
#43814
No, egyelőre annyi, hogy nem zarkoznak el semmitől. Kuldjek képet a problémáról. Haaaaat...
Küldök képet az LE kodi alatt a sys inforol és adroidbol is... Még az android alatt a terminal emulator parancs eredményét amikor kiirta, hogy gxl_p212_1g. Mást nagyon nem tudok. -
ztsoft
DoItYourself
#43838
A saját lejátszójánál tudja kezelni mind a DD, mind a DTS formátumot, még a DD Plus-al (E-AC3) is elboldogul. TV adásnál is van DD (2.0, 5.1), ott is van hang.
Az már más kérdés, hogy a HDMI bemeneten lehet nem tudja. -
mgaben
DoItYourself
#43814
Ebay... De elég az, hogy a parancsra adott választ lefényképezem nekik?
Na mindegy, igazad van. Nem kerül semmibe... -
mgaben
DoItYourself
#43802
Ok. Tök egyértelműen megtaláltam az elvileg hozzá illő dtb fájlt. Nincs is ezzel gond. De mint írtam már az LE alatt sem indult el azzal, csak az alap dtb.img-vel. Viszont itt a lemezkép kiírása után NINCS általános dtb.img fájl, csak amik a mappában vannak. De azokkal meg nem megy.
Ahogy itt az összefoglalóban is le van írva, hogy az s905x-es modelleknél elég szokott lenni az általános dtb.img.
Fórumon konkrétan le van írva:
X96 2G/16G S905X gxl_p212_2gDe mondom, ezzel nem megy.
junkpod
DoItYourself
#43769
Először nem is értettem milyen 4.1? Mert nekem a 3.1 volt az utolsó.
Akkor megnyugodhatok, ez egy a nemhivatalosnal is nemhivatalosabb build...
a.t.t.i.
DoItYourself
#43673
Köszi,megpróbálom.
mgaben
DoItYourself
#43542
akela91
DoItYourself
#43542
Ebből a Mecool BB2- ből a PRO változat is megfelelő? (tuner nem kell, IPTV van)
(#43541) mgaben: Köszi, esetleg ezek jobbak szerinted mint a Mecool BB2 pro?
blakey
DoItYourself
#43521
Sőt, ki is került.
Nerazim
DoItYourself
#43497
Na bekapcsoltam az SMB-t és így már működik minden, sikerült a transmission-t beállítani, úgyhogy happy van. Igen úgy akarom majd hosszútávon,de most még csak egy pendrive-ot dugtam rá próbaképpen és teljesen jól működik. Köszi mégegyszer.
junkpod
DoItYourself
#43484
Igen, ezt írtam elsőre is, örülök, hogy sikerült.
vargalex
DoItYourself
#43445
Belenéztem, nekem is ezek a kódok vannak benne. De azért megosztom:
0x116 KEY_UP
0x11a KEY_DOWN
0x151 KEY_LEFT
0x150 KEY_RIGHT
0x113 KEY_OK
0x119 KEY_BACK
0x14c KEY_MENU
0x141 KEY_MUTE
0x14e KEY_1
0x10d KEY_2
0x10c KEY_3
0x14a KEY_4
0x109 KEY_5
0x108 KEY_6
0x146 KEY_7
0x105 KEY_8
0x104 KEY_9
0x101 KEY_0
0x142 KEY_DELETE
0x111 KEY_HOME
0x157 KEY_VOLUMEDOWN
0x156 KEY_VOLUMEUP
#eger 0x100Mondjuk én nem foglalkoztam az összes gombbal, csak az édesanyám számára szükségesekkel.
Én közvetlenül az eszközön vi-al szerkesztettem a szükséges file-okat, így hogy ne legyen a windows-os sorvégekkel probléma feltöltöttem a google drive-ra. Így a box-on SSH-n ezeket a parancsokat kiadva működésbe hozható:
systemctl stop kodi
systemctl stop eventlircd
wget --no-check-certificate "https://docs.google.com/uc?export=download&id=1Z51my7E_ZX6Yydp3_NnmdI9FCTXp1IrE" -O /storage/.config/rc_keymaps/my_t95m
wget --no-check-certificate "https://docs.google.com/uc?export=download&id=1-r_D0cwMRLHZc8xpqVQSMDttdOE6-FdN" -O /storage/.config/rc_maps.cfg
ir-keytable -a /storage/.config/rc_maps.cfg -s rc0
systemctl start eventlircd
systemctl start kodi -
junkpod
DoItYourself
#43445
Az más XML. Az a külön Kodi parancsok bekötéséhez kell. Próbálták már kiadni az ssh-n azt a parancsot amit írtam?
Illetve ami még fontos, hogy ne notepaddal csináljátok a lista fájlokat, hanem mondjuk note+ -ap (ha jól emlékszem a nevére) és ügyeletek rá, hogy a sorvege jelek Linuxos kódok legyenek, ne Windowsos. A szerkeszto edit menüben van egy sorvege jel konvertalo funkció. -
tamás86
DoItYourself
#43435
Igen ezt csinaltam de nem mukodik.
sepsi0
DoItYourself
#43363
Öreg vagyok már...
De még mindig ott van a kisördög a fejemben, de öreg vagyok ahhoz is, hogy saját káromon tanuljak.
Komolyan mondom, amíg nem tévedtem ide, azt sem tudtam mi az a freki váltás, most meg nem tudok nélküle élni. Meg még egyéb apróságok, amik az LE-ben vannak.
Ahhh bocsánat a hsz gyártásért.
Szerencsére csak hallgatok az érvekre, igaz nehezen.
Akkor BB2-re fel.
sepsi0
DoItYourself
#43361
Hát köszönöm, átfutottam azt a 6 oldalt...
Akkor most vegyek MeCool BB2-t?
Soha nem próbáltam a CoreElec-et, írjátok hogy stabíl, nekem csak 1080-ra kell. Sok különbség van a LibreElec-hez képest.
Csak nem tudok szabadulni a kínai boxoktól, igaz semmi bajom velük. -
Keef_Lee
DoItYourself
#43352
Keret, meg ilyenek...
és a kalandvágy hol marad?!
kmarci25
DoItYourself
#43352
Ezek szerint a nyugalom saját erősséged is!
Majd 3 hónap szállítási idő...
Keef_Lee
DoItYourself
#43350
Remélem 905W-t vettél
Legalább arról is lenne tapasztalat -
kmarci25
DoItYourself
#43347
De akár ez is mehetne oda, kiegészítő infóként. CE kiadások. És köszönjük a karbantartást!
erzol
DoItYourself
#43323
Köszönöm a válaszod. A tv -n mindent kikapcsoltam, de nem változott a dolog.
Hiába próbálok mondjuk a VLC-ben képarányt változtatni, nemmtörténik semmi. Függőlegesen kicsit meg van nyúlva a kép.
Box beállításaiban automatikus screen resolution és hdmi self adaptation van bekapcsolva, de ha ezeket átállítom akkor sem történik semmi.
z123456789
DoItYourself
#43321
Milyen igazad van.
darvinya
DoItYourself
#42949
Már tudom hiba okát, de azt senki nem veszi figyelembe.
Téma zárva.
vargalex
DoItYourself
#42892
Én S905-ről tudok nyilatkozni 100 Mbps-es LAN-al (T95M). Ahogy írtam, nálam nem volt gond a 4K-s teszt videókkal sem (persze a 120 Mbps-es teszttel már igen).
vargalex
DoItYourself
#42883
Ezt azért nem állítanám ilyen határozottan...
vargalex
DoItYourself
#42869
Én sem, hiszen nincs 4K TV-m. De most a virágboltban rákerestem az "uhd remux" kifejezésre. Majd a találatokat méret szerint csökkenőleg rendezeztem (tudom, ez nem bitráta szerint csökkenő, de azért nagyjából megfelel). Az első néhányat néztem meg:
1. BiTRATE.......: 74 800 kbps
2. Video: [HEVC] / 77.9 Mbps / 3840x2160 / 23.976
3. BiTRATE.......: 72 100 kbps
4. Bitrata..........: 46154 kbps
5. BiTRATE.......: 88 000 kbpsEz még mind átfér 100-as hálón...
peterk
DoItYourself
#42858
Amlogicon nem tudom tesztelni, mert csak gigás amlogicom van
(Ezen természetesen mennek).De igazából mindegy, ha a sávszélesség a gond, az bármilyen platformon kodi alatt hasonlóan kevés lesz. Windows, Android, Android TV, vagy akár Ubuntu alatt is, akár desktop PC-n is. A kodi frame bufferelés pedig hasonlóan működik eszköztől, platformtól függetlenül. (Az persze előfordulhat, hogy mondjuk egy PI-n a 100-as net sem igazán 100-as, hanem kevesebb. Nem volt PI-m, csak a példa kedvéért írtam. A lényeg, hogy előfordulhat, hogy a 100 nem is 100, és akkor semmi sem segít.)
TCr
DoItYourself
#42869
Jól tudod.
ztsoft
DoItYourself
#42858
Én ezt használom a belső hálózat tesztelésére, [link]. Gondolom ez elég lehet arra.
Le is játssza akadás nélkül a NAS-ról.(#42860) vargalex
Ezt szépen benéztem.
Simán átugrottam a parancson, csak a szövegben lévő útvonalat néztem.
vargalex
DoItYourself
#42858
Ahogy linkeltem, a 100 GB-os UHD BD-n maximum 128 Mbps a bitráta. Ezek alapján kb. 73 GB-ig jó lehet... Persze a remuxnál megoldható, hogy a 60 GB csak egy 10 perces rövidfilm legyen. Akkor ez nyilván nem igaz...
darvinya
DoItYourself
#42826
És (#42828) peterk
Mint írtam, mindenféle cache-el próbáltam már.
Alappal mp-ként cache-el, tehát nézhetetlen fogalmát kimeríti.
USB tárról nézem, nincs hálózat.Ugyanezt a tárat, ugyanúgy USB 2 csatlakozással laptop viszi, mert kihasználja RAM adta lehetőséget.
De LE/CE-n max. 500MB-ig használja RAM-ot.
1GB RAM ilyen szempontból teljesen felesleges. -
junkpod
DoItYourself
#42818
készen is van az új remote configom, nem volt nehéz egyáltalán. egyelőre (a külön beállított kodi funkciók kivételével, ahhoz majd még át kell másolnom az xml fájlt) minden működik a távon ahogy akartam
most nézegetem a beállításokat
ztsoft
DoItYourself
#42818
Szerintem simán lehet a remote.conf-ból faragni olyat, ami jó a CE-hez. Nálam a gomb kódok megegyeznek, gondolom a többinél is.
remote.conf:
#RKM ff00
factory_code = 0xff000001
work_mode = 0
key_begin
# < > dn up
0x0e 105
0x1a 106
0x02 108
0x03 103
#ok back
0x07 232
0x5c 158
#menu home
0x13 125
0x48 102
#v- mute v+
0x58 114
0x01 113
0x0b 115
#power
0x14 116
key_endAmi a CE-hez kell:
# table rikomagic_mk22_plus, type: NEC
0x14 KEY_POWER
0x01 KEY_MUTE
0x03 KEY_UP
0x02 KEY_DOWN
0x0e KEY_LEFT
0x1a KEY_RIGHT
0x07 KEY_ENTER
0x13 KEY_CONTEXT_MENU
0x0b KEY_VOLUMEUP
0x58 KEY_VOLUMEDOWN
0x5c KEY_BACK
0x48 KEY_HOMEEz a kód a Rikomagic MK22 Plus-hoz való, csak szemléltetés véget tettem be.
foresz
DoItYourself
#42761
Beírtam az általad írt kódot és most már reagál az ok gomb az power gomb az hangot némít az egérváltó pedig vissza gomb a többi semmi. Viszont végre reagál valamire, nagyon köszönöm.
Csak innen hogy tovább?176.680044@3] hdmitx aud_n_para = 5120
[ 176.680108@3] hdmitx set channel status
[ 176.680281@3] hdmitx: audio: Audio Type: PCM
[ 176.680299@3] hdmitx: audio: set audio param
[ 308.133349@0] remote: scancode is 0x000e,invalid key is 0x0000.
[ 308.583440@0] remote: scancode is 0x000e,invalid key is 0x0000.
[ 308.710986@0] remote: scancode is 0x000e,invalid key is 0x0000.
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7600X 32/64GB RAM RTX 5060 Ti 16GB GAMER PC termékbeszámítással
- Tablet felvásárlás! Samsung Galaxy Tab S10+, Samsung Galaxy Tab S10 Ultra, Samsung Galaxy Tab S10 FE
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RTX 5060 8GB GAMER PC termékbeszámítással
- BESZÁMÍTÁS! MSI H310M i5 9500 16GB DDR4 120GB SSD 2TB HDD RTX 2060 Super 8GB ÚJ Zalman T4 Plus 600W
- Apple iPhone XR / 128GB / Kártyafüggetlen / 12Hó Garancia / 95% akku
vargalex
