- Meggyi001: Kuponok....
- sidi: 386-os Chicony gázplazma laptop memóriabővítése
			  Jim-Y veterán válasz  Jim Tonic
								#6418
							üzenetére Jim Tonic
								#6418
							üzenetéreHát, pedig ezt írja ki: Array assignment to [Village People - YMC ...] failed: Cannot convert value "Village People - YMCA.mp3" to type "System
 .Int32". Error: "Nem megfelelő a bemeneti karakterlánc formátuma.".
 At E:\_ATTILA\SCRIPTS\checkMusic.ps1:8 char:13
 + $multiples[ <<<< $key] = $value
 + CategoryInfo : InvalidOperation: (E:\_ATTILA\70\Village People - YMCA.mp3 SObject) [], RuntimeExceptio SObject) [], RuntimeExceptio
 n
 + FullyQualifiedErrorId : ArrayAssignmentFailedkód: $multiples = @()
 foreach($elem in $files){
 $key = $elem.Name.toString()
 $value = $elem
 $multiples[$key] = $value
								#6416
							üzenetére Jim Tonic
								#6416
							üzenetéreMert mindenképp Int32-t szeretne kulcsnak
 Példa:$files = get-childitem ... //fájlok beolvasása
 $hashTable = @() //hashtable inicializálás
 foreach($hash in $files){
 //ezek közül egy se működött valamiért:(
 $hashTable.$hash.Name = $hash
 $hashTable[$hash.Name] = $hash
 $hashTable["$hash.Name"] = $hash
 $hashTable += {name=$hash.Name,value=$hash}
 }több ötletem így hirtelen nem volt :/
			  Jim-Y veterán Közben próbálkoztam 1-2 dologgal 1: az eredeti
 $loc = get-location
 $files = get-childitem -Path $loc -Recurse | where {$_.Length -gt 0}
 $length = $files.length
 $multiples = @()
 $rows = 0
 $groups = 0
 [int]$10n = $length*0.1
 [int]$20n = $length*0.2
 [int]$30n = $length*0.3
 [int]$40n = $length*0.4
 [int]$50n = $length*0.5
 [int]$60n = $length*0.6
 [int]$70n = $length*0.7
 [int]$80n = $length*0.8
 [int]$90n = $length*0.9
 [int]$100n = $length
 for($i=0;$i -lt $length;++$i){
 $ismultiple = 0
 $tempi = $files[$i]
 switch($i)
 $10n { write-host "10%" }
 $20n { write-host "20%" }
 $30n { write-host "30%" }
 $40n { write-host "40%" }
 $50n { write-host "50%" }
 $60n { write-host "60%" }
 $70n { write-host "70%" }
 $80n { write-host "80%" }
 $90n { write-host "90%" }
 $100n { write-host "100%" }
 if($multiples -contains $tempi.FullName){ } else {
 for($j=$i+1;$j -lt $length;++$j){
 $tempj = $files[$j]
 if($tempj.Name -eq $tempi.Name -and $tempj.Length -eq $tempi.Length){
 $multiples += $tempj.FullName
 $rows++
 $ismultiple = 1
 if($ismultiple){
 $multiples += $tempi.FullName
 $rows++
 $groups++
 $multiples += "`n"
 $multiples += "$loc folder has $length files, there are $groups files multiplied,`n and you could delete $($rows-$groups) files from the $rows multiplications!"
 $multiples > multiples.txtEz a tesztmappán ~21-22mp-ig futott 2: nem tömbbe írós, hanem fileba: Ebben a verzióban a $multiples tömb helyett amit a végén fájlba írok, egy fájlhozz appendelem szekvenciálisan a dolgokat
 $multiples = @() -> New-Item multiples.txt -type file -force
 $multiples += $files[$j].FullName ->
 Add-Content multiples.txt -value $files[$j].FullName
 stb..Ez a tesztmappán 1-2mp-el futott hosszabb ideig mint az első 3: hashmap
 Sajnos nem sikerült olyan sszociatív tömböt csinálnom ahol a key-nek megette volna a fájl nevét Így egy .NET-es ArrayList-el próbálkoztam. Sajnos ez fut legtovább, a tesztmappán olyan 24mp-ig.. Így egy .NET-es ArrayList-el próbálkoztam. Sajnos ez fut legtovább, a tesztmappán olyan 24mp-ig..$loc = get-location
 $hashTable = New-Object System.Collections.ArrayList(,(get-childitem -Path $loc -Recurse | where {$_.Length -gt 0}))
 $duplications = New-Object System.Collections.ArrayList($null)
 $rows = 0
 $groups = 0
 $length = $hashTable.Count
 $ism = 0
 if($duplications.Contains($hashTable.Item($i).FullName)){ } else {
 $temp = $hashTable.Item($i)
 $tempj = $hashTable.Item($j)
 if($tempj.Name -eq $temp.Name -and $tempj.Length -eq $temp.Length){
 $duplications.Add($tempj.FullName)
 $rows++
 $ism = 1
 if($ism) {
 $rows++
 $groups++
 $duplications.Add($temp.FullName)
 $duplications.Add("`n")
 Write-Host "$length files, there are $groups files multiplied,`n and you could delete $($rows-$groups) files from the $rows multiplications!"
 $duplications > multiples.txtMost véletlenül az egész partíció gyökerére futtattam le az első verziót, 10perc alatt csinált meg 10%-ot
			  Jim-Y veterán válasz  Sk8erPeter
								#6411
							üzenetére Sk8erPeter
								#6411
							üzenetéreNagyon ráérek, és ahogy ez lenni szokott, persze nem tanulással töltöm a feles időt
 Ezzel kezdtem, így jutottam el a lentiig.
			  Jim-Y veterán Magát a tömböt összeírni alig pár másodperc, nem az a hosszú, hanem ami a for ciklusban van, csináltam egy olyan kiiratást ami 10 százalékonként kiír a képernyőre, bár ez nem mutatja meg, hogy ténylegesen mi a sok idő... Ami ötletem még van, az az, hogy ha egy fájlhoz összeszedi a duplikációkat, akkor azokat kitörli a tömbből, így a következő vizsgálandó fájlnál már annyival kevesebb elemet kell végignézni, bár ha kevés a duplikáció a mappában, akkor ez szinte semmit nem segítene. A másik ötletem, hogy az is lassú lehet amikor valamit hozzáadok a $multiples tömbhöz, mert elméletileg ilyenkor mindig készít egy másolatot az aktuális tömbről, legalábbis valami ilyesmit olvastam a neten, tehát lehet ezt a tömbhöz hozzáadok dolgot ki kéne cserélni valamire, például arra, hogy már az elején hozzon létre egy fájlt, majd utána csak appendoljon hozzá, hátha így gyorsabb lesz... majd mindjárt kipróbálom.
			  Jim-Y veterán Sziasztok PowerShellben csináltam egy olyan scriptet ami egy directoryban rekurzívan megnézi a duplikációkat, és a duplikált állományok nevét kigyűjti egy fájlba. A problémám az, hogy az algoritmus amit használtam/írtam nagyon lassú. Ha ~2000 fájlt kell összehasonlítania az még viszonylag gyors 10,15mp, de 5500 állománnyal már percek óta szöszöl :S
 megj: közben 2-3 perc múlva végzettAz ilyen rekurzív összehasonlítgatós dolgokat hogyan lenne célszerű megoldani? Jelenleg a kódom: $loc = get-location
 $multiples = @()
 $ismultiple = 0
 if($multiples -contains $files[$i].Name){ } else {
 $elem = $files[$i]
 if($files[$j].Name -eq $elem.Name -and $files[$j].Length -eq $elem.Length){
 $ismultiple = 1
 if($ismultiple){
 $multiples += $elem.FullName
 $multiples += "`r`n`r`n"
 $multiples > multiples.txtLátható, hogy először kigyűjtöm a fájlneveket egy tömbbe, majd az első rekordot keresem a fennmaradó elemek között, ha van duplikáció, akkor kiírom azokat a fájlba, és ugrok a második elemre.
 Szinte biztos vagyok benne, hogy van ennél hatásosabb módszer, de már túl késő van ahhoz, hogy rájöjjek, hogy mi az megj: haha, lehet csak azért szöszölt annyit, mert muter fél mappája duplikált, egy rahedli duplikációja van
								#6347
								#6347
							üzenetéreLaborra lehet menni BsC-n is, t.k egy projektmunka, de tudtommal nincs kreditértéke, tehát csak olyanok mennek akiket érdekel a téma, vagy sok szabadidejük van. Gyakorlat szinte mindenből van, ellenben hardvert semmihez sem használtunk, egyszer még az elején kinyitottunk egy gépházat és kábé ennyi, ilyen szempontból egyáltalán nem gyakorlatias..
			  Jim-Y veterán Van grafika, C szakirányon is, OpenGL + DirectX Azért így is maradt elég sok matek.. Analízis x4
 Lineáris Algebra x1
 Numerikus Módszerek x2
 Diszkrét Matematika x2
 Valószínűségszámítás x1asszem ennyi  Mondjuk így, hogy már megvan a diplomám nem bántam meg, hogy ide jöttem és nem a BME-re. De véleményem szerint nehéz lenne megmondani, hogy melyik jobb, nem hiszem, hogy a BME-t könnyebb lenne elvégezni, vagy fordítva. Én BMF-ről hallottam még, mai nevén Óbudai Egyetem, az is felejtős, nagy vicc az egész
			  Jim-Y veterán Sk8erPeter-el értek egyet, mindkét képzés jó, azt válaszd amelyik hozzád közelebb áll: matek -> ELTE
 fizika -> BMEIgazából tök mindegy melyiket csinálod meg, ha van egy kis sütnivalód, akkor egyetem után mindkét diplomával fogsz állást kapni...
			  Jim-Y veterán Üdv, nekem az lenne a kérdésem, hogy a JSP mennyire van jelen még? Lenne egy feladat, amit ebben kéne megcsinálnom, de azt is hallottam, hogy eléggé leszálló ágban van, és a legtöbb helyen már JSF-et használnak. Nektek erről mi a véleményetek?
			  Jim-Y veterán gondoltam jelzem, hogy tényleg van az apinak egy heatlayeres része, ami úgy néz, ki, hogy jó lesz nekem
			  Jim-Y veterán Sziasztok! Használta már valaki közületek a Google Maps API v3-at a HeatMapAPI-val?
 Adatokat szeretnék megjeleníteni magayarország térképen, és első blikkre a fenti két toolt találtam alkalmasnak erre. Ha valaki ebben a témában otthon van, vagy csináltált már ilyet, vagy tudna valami tényleg jó, és használható tutorialt linkelni, vagy annyit tudna segíteni, hogy milyen toolokat érdemes erre használni, azt megköszönném. Üdv
			  Jim-Y veterán válasz  peter9228
								#6146
							üzenetére peter9228
								#6146
							üzenetéreHát, meg ez annyira nem triviális kérdés, mert a Perl/Python scriptnyelv, míg a Java,C++,C# nem. Lehet azért ajánlották a Pythont, mert azokat a feladatokat, amiket kaphattok érettségin egy scriptnyelvben könnyebb megvalósítani, meg gyorsabb is. Ha így van, akkor vagy a Python vagy a Perl legyen, nekem utóbbival van tapasztalatom, nem rossz. De ha az érettségi feladat megoldása nem szempont, akkor Java vagy C#, mert ezeknek később hasznát fogod venni! Nagyobb hasznát mint egy scriptnyelvnek, mert míg előbbieket relatíve nehezebb megtanulni, vagy legalábbis több idő, addig egy felaldatot megoldani perlben vagy pythonban kevesebb utánaolvasást igényel.
			  Jim-Y veterán Sziasztok! Nekem egy olyan kérdésem lenne, hogy a Windows Run-ról hol tudok mélyrehatóbban olvasni? Googlis keresés nem járt sikerrel. Azt szeretném kideríteni, hogy hogyan tudnám rávenni a run-t, hogy én adhassam meg, hogy mit, milyen névvel indítson?! Bővebben: ha beírom, hogy firefox, akkor azt megnyitja, ha beírom, hogy iexplore, akkor az Explorert nyitja meg, kérdésem, hogy milyen mappában lévő exéket nyit meg, illetve pl a Chrome.exe-t hova rakjam, hogy a "chrome"-ot begépelve elindítsa pl a chromot? Nem lehet erről bővebben olvasni valaol, hogy hogy működik a Run? Én így nyitom meg a calculátort, a paintet, a kedvenc böngészőmet, és ezt szeretném még több installált programra kiterjeszteni. Előre is köszi, üdv
			  Jim-Y veterán Sziasztok. Kéne írnom egy szerver oldali programot PHP-ban,mivel szerver oldali dolgokat nem kódoltam még, csak kliens oldalit, ezért nem tudom hogyan kéne hozzákezdeni. 2 google keresés közben hozzátok fordulok linkekért, tanácsokért. Kezdetben annyi lenne a program dolga, hogy feldolgozzon egy bejövő kérést. De nekem még csak nem is magával a kóddal lenne a legnagyobb gondom, hanem a többivel. Gondolok itt arra, hogy hogy szokott ez menni? Csak simán feltöltöm a szerverre a kódom ami lekezeli a kérést? A szerveren futó alkalmazásokkal nem fog összeveszni? Vagy úgy irom a kódot, hogy egy bizonyos porton érkező kéréseket kezeljen? Ez a gond, hogy még soha nem láttam közelről webservert, és nem tudom hogy működik..:S
								#5572
								#5572
							üzenetéreKicsit már belekavarodtam sajnos, meg sem tudom mondani már, hogy mi oldotta meg:/ Kezdek fáradni
			  Jim-Y veterán Sziasztok, kis help jól jönne, Java: String line;
 for (line = freader.readLine(); line != null; line = freader.readLine()) {
 String[] user = line.split(":");
 System.out.println("Current user :: " + currentUser);
 System.out.println("Felhasznalonev :: " + user[0]);
 System.out.println("Jelszo :: " + user[1]);
 if(user[0].equals(currentUser)) {
 writer.println(user[1]);
 writer.flush();
 freader.close();
 writer.println("null");
 writer.flush();freader egy fileból olvas aminek 4 sora van, íme: alpha:111
 beta:222
 charlie:333
 tango:444A kódban ezek: System.out.println("Current user :: " + currentUser);
 System.out.println("Jelszo :: " + user[1]);csak debug miatt vannak. A probléma az, hogy nem működik jól, azt szeretném elérni, hogy: - a currentUser-ben az van, hogy "alpha"
 - ezt keresse meg a fileban, ha megtalálta, akkor a hozzá tartozó jelszót küldje rá a socketre, itt a writer jelenti a socketet.Sajnos most úgy működik, hogy: - a currentUserben szépen benne van, hogy alpha
 - a fileon is szépen végigiterál
 - de visszaküldeni már null-t küd és nem a jelszót:SSzerintem valamilyen alapvető szintaktikai hiba van benne, olyasmire gyanakszom, hogy amikor megtalálja az alpha-t a fileban akkor vagy nem áll meg és küldi el a hozzá tartozó jelszót, vagy simán nem küldi el valamiért:/ ötlet? üdv mod: arra közben rájöttem, hogy a végére nem kéne a writer.println("null") , mert így ezt mindig elküldi, az meg nem jó:/ Hogy tudom azt megcsinlni, hogy null-t csakis akkor küldjön ha nincs currentUser a fileban? üdv
			  Jim-Y veterán válasz  Geriman25
								#5243
							üzenetére Geriman25
								#5243
							üzenetéreUhh, hát azért először jó lenne kicsit böngészni a wikipediát a témában, hogy azért tisztában legyél az alap dolgokkal, írd be a wiki keresőbe, hogy programozás, és kezdj el olvasni, a linkeken keresztül kiterjeszteni a tudásod. Nagyon pongyolán, ha webre akarsz programozni, weboldal alá akarsz programkódot írni, akkor PHP,javascript,html,css, html-dom,jquery,AJAX ... ezek nézd át. Ha meg objektum orientáltan akarsz programozni akkor ismerkedj meg a JAVA nyelvvel, vagy ha az egyik legrégebbitlegelterjedtebbet akarod megtanulni akkor C++, vagy ha az újak közül, ASP .NET, C#.
			  Jim-Y veterán Sziasztok, szeretném ha valaki akinek van egy szabad délutánja, és össze tudna dobni egy ehhez hasonló dinamikus honlapot, az jelezze, tervezünk többen egy ehhez hasonlót csinálni, csak pc-házas témában, és kéne hozzá programozói support, hogy később is lehessen szerkeszteni, ha 1-1 új termék megjelenik a piacon, akkor azt fel tudjuk majd tölteni a táblázatba. Ha valakinek lenne kedve, egy ilyen honlapot leprogramozni, akkor azt megköszönjük, ha nem akkor felkeresem ezen honlap készítőjét, hátha ebben is partner lenne, de egyből nem akartam ezzel terhelni, ezért kérdezem meg itt először, üdv
			  Jim-Y veterán Sziasztok, szeretnék valakitől segítséget kérni 3-4 SQL parancs legenerálásához, ergo 3 feladat megoldásához  1-1 feladat megoldása cca 2 sor
			  Jim-Y veterán Igazából a programozáshoz matematikai logika kell legfőképp, illetve sok gyakorlás 1-1 programnyelvre lebontva, szerintem attól, hogy egy, vagy több logikai játékkal foglalkozol, még nem fog jobban menni a programozás:S Inkább találj egy olyan programnyelvet amivel sulin kívül is szivesen foglalkozol, abba ásd bele magad, érd el, hogy szívesen programozz benne, ha ez megvan akkor lehet, hogy már a többi is könnyebben fog menni ..
			  Jim-Y veterán válasz  [pod]Diablo
								#5066
							üzenetére [pod]Diablo
								#5066
							üzenetéreSzia, szerintem biztos, sajnos most nem tudok konkretumot irni, de win PowerShellben szerintem nagyon egyszeruen lehet ilyen programot irni. PS win7 ota alapbol megtalalhato az OSben.
			  Jim-Y veterán lejárt az időlimit én meg össze-vissza szórakoztam a konvertálatlan/programkód bizbaszokkal, szoval: var nap = 0;
 bool volte = false;
 int eljárás Eldont(bevetel_tomb b,kiadas_tomb k) {
 ciklus 0..b.length()-ig {
 if(k[i] > b[i]) {
 nap = i+1;
 volte = true;
 return 0; // vagy akár visszatérési értékben visszadhatod a 'nap' -ot is.
			  Jim-Y veterán Sziasztok, van itt valaki aki tud nekem segíteni egy picit javascriptben?^^
			  Jim-Y veterán Sziasztok, prog.hu nem küldte ki a regisztrációs emailt szv itt teszem fel a kérdést:
 javascript / HTML -ről van szó:van egy következő iframeem:
 <iframe name="chPageName" src="default.html" id="chPageFrame" scrolling="no" frameborder="0" height="270" width="340"></iframe> -> ennek most csak a teszt kedvéért van height és width értéke, ezeket 0-ra fogom állítani ,mert hiddenként fogom használni, ez egy external URL-re mutat. Le szeretném kérdezni scripttel az iframepage contentjét, kéne belőle a getElementsByTagName('td')... egy csomó helyen rákerestem de mindenhol vagy olyan megoldás volt ami a korábbi böngészőkön működött, vagy amit csak én nem tudtam megcsiálni kéne olyan megoldás ami a legújabb FF-on és IE-n is mükszik kéne olyan megoldás ami a legújabb FF-on és IE-n is mükszik köszi köszi
- iPhone topik
- Milyen autót vegyek?
- Futás, futópályák
- Gumi és felni topik
- BestBuy topik
- Gyúrósok ide!
- Thinkpad E15 Gen2 15.6" FHD IPS i7-1165G7 16GB 512GB NVMe ujjlolv gar
- Samsung S25 128GB Navy Blue makulátlan állapotban garival eladó
- DJI Mavic 3 Pro Fly More Combo (2 akku) RC Pro - drón szett újszerű állapotban
- Akciós áron eladó ÚJ HP Dragonfly G4 /I7-1355U/16 GB/1000GB SSD/13,5"/FHD+/400nit/1 ciklus
- Lenovo ThinkPad P15v Gen 3 i7 12800H 16GB 256GB SSD
- Apple iPhone 13 Pink Super Retina XDR, 5G, dupla kamera 128 GB Használt, karcmentes 100%
- Kezdő Gamer PC-Számítógép! Csere-Beszámítás! I5 7500 / GTX 1050Ti / 16GB DDR4 / 128SSD+1TB HDD
- Bomba ár! Lenovo X1 Yoga 2nd - i7-7G I 8GB I 256GB SSD I 14" WQHD Touch I W11 I CAM I Garancia!
- HP EliteBook 840 G7 i5-10210U 16GB 256GB 14" 400nit 100% sRGB 1 év garancia
							 köszi^^
 köszi^^
							 haha
 haha
 , otthon kipróbálom, melóban nem tudok belépni a sysadvancedsettings-be.. :/
