polgcsabi
Ott, hogy adott a LED buli (ON OFF) ebből hogyan lesz egy 16-os tömb.
#include <EtherCard.h>
#define STATIC 0 // set to 1 to disable DHCP (adjust myip/gwip values below)
// mac address
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x36 };
// ethernet interface ip address
static byte myip[] = { 192,168,1,80 };
// gateway ip address
static byte gwip[] = { 192,168,1,1 };
// LED to control output
int ledPin10 = 9;
byte Ethernet::buffer[700];
char const page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
"<head><title>"
"Service Temporarily Unavailable"
"</title></head>"
"<body>"
"<h3>This page is used behind the scene</h3>"
"<p><em>"
"Commands to control LED are transferred to Arduino.<br />"
"The syntax: http://192.168.0.XX/OFF or ON"
"</em></p>"
"</body>"
"</html>"
void setup () {
pinMode(ledPin10, OUTPUT);
Serial.begin(9600);
Serial.println("Trying to get an IP…");
Serial.print("MAC: ");
for (byte i = 0; i < 6; ++i) {
Serial.print(mymac[i], HEX);
if (i < 5) Serial.print(":");
Serial.println();
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0){
Serial.println( "Failed to access Ethernet controller");
else{Serial.println("Ethernet controller access: OK");}
#if STATIC
Serial.println( "Getting static IP.");
if (!ether.staticSetup(myip, gwip)){
Serial.println( "could not get a static IP");
blinkLed(); // blink forever to indicate a problem
#else
Serial.println("Setting up DHCP");
if (!ether.dhcpSetup()){
Serial.println( "DHCP failed");
#endif
ether.printIp("My IP: ", ether.myip);
ether.printIp("Netmask: ", ether.netmask);
ether.printIp("GW IP: ", ether.gwip);
ether.printIp("DNS IP: ", ether.dnsip);
void loop () {
word len = ether.packetReceive();
word pos = ether.packetLoop(len);
// IF LED10=ON turn it ON
if(strstr((char *)Ethernet::buffer + pos, "GET /ON") != 0) {
Serial.println("Received ON command");
digitalWrite(ledPin10, HIGH);
// IF LED10=OFF turn it OFF
if(strstr((char *)Ethernet::buffer + pos, "GET /OFF") != 0) {
Serial.println("Received OFF command");
digitalWrite(ledPin10, LOW);
// show some data to the user
memcpy_P(ether.tcpOffset(), page, sizeof page);
ether.httpServerReply(sizeof page-1);
void blinkLed(){
while (true){
delay(500);
delay(500);
Hozzáteszem: Nem vagyok valami nagy C-s!! Csak néhány hónapja kezdtem az egészet.
Erről az ENC-28J60-as panelről gyér az infó (legalábbis az én felfogásomhoz képest). -
polgcsabi
polgcsabi
Janos250
#17544
Konkrétan ezt szeretném:
Van egy 16-os tömb aminek 0-4096 közt szeretnék értéket adni webes felületen.
int lederteke[16];
Hogyan lehet megoldani?
Nekem az is elég lenne, hogy mondjuk, beütöm a böngészőbe:
192.168.1.139/lederteke[16.28.4020,1256, stb.] vagy valami ilyesmi. Leütöm az ENTERT és az arduino kódban a ledértréke tömb felveszi a mind a 16 értéket amit beírtam.
Köszi! -
polgcsabi
Lenne 1 kis bajom.
Van nekem ENC28J60 Ethernet cuccom, és azt szeretném megoldani, hogy hogyan tudok küldeni adatokat, értékeket az arduino panelnek.
Pontosabban:
a=0 v. a=1
ill.
egy 32-es tömb értékei
- Samsung Galaxy S21 Ultra 256GB, Kártyafüggetlen, 1 Év Garanciával
- Hp USB-C/Thunderbolt 3 dokkolók: USB-C Universal, G2, G4, G5, Hp Elite/Zbook- Thunderbolt 4 G4
- Gamer PC-Számítógép! Csere-Beszámítás! R5 8400F / RTX 3070Ti / 32GB DDR5 / 1TB SSD!
- REFURBISHED és ÚJ - HP USB-C Dock G5 (5TW10AA) - 3x4K felbontás
- HIBÁTLAN iPhone 14 Pro Max 128GB Silver -1 ÉV GARANCIA - Kártyafüggetlen, MS3937, 100% Akkumulátor
ekkold
