2 variációt tudok elképzelni, illetve 3-at.
1:Nem jól van rajta a hűtő, túlhevül, sát dáon.
2:''Intel® 845E chipsets, standard FSB @ 533 / 400MHz,
Max. 800+ MHz at overclocking mode (see CAUTION 1)
P4i45E motherboard may be fine tuned to support higher CPU bus
frequencies on certain condition (over-clocking mode). Please refer
to the NOTE on pages 7-8 for the details.''
3:Lehet hogy át kellene Jumperelni.
Mivel ha jól látom,ezen még jumerrel megy az állítgatás.
''P4i45E may be fine tuned to support higher CPU front side bus frequencies on certain condition at over-clocking mode. Please refer to the tables below for the details.
CPU FSB Configuration Note
P4i45E 800 MHz 1. Set the “FSB” jumper to “800” mode (see page 15).
Vagy:
Update BIOS version to 2.10 or later version.'',
Sajna ennyi 5letem van csak
