Local Sidereal Time on Atmega328 (Arduino)
Sokat nem tennék hozzá, egy távcsőves projektemhez van szükség rá, hátha másnak is jól jön.
Itt a sketch:
/* Based on http://astro.neutral.org/arduino/local-sidereal-time-arduino-microcontroller.shtml
and https://forum.arduino.cc/index.php?topic=359573.0 V-drive user's example.
távcsőves 2017.06.24.
#include <RTClib.h> // https://github.com/adafruit/RTClib
#include <Wire.h>
RTC_DS3231 RTC;
int TIMEZONE = 1; // Your timezone, my location timezone is 1 (Central Europe)
int DST = 1; // Value = 1 if summer time, in winter value = 0
float LONGITUDE = 15.28133; // Your position to the Earth (West value - sign. My current position in the example, if you not have GPS receiver, Google Maps tell your cordinate's.)
void setup()
Serial.begin(9600);
Wire.begin();
RTC.begin();
void loop() {
CalculateLST();
delay(1000);
void CalculateLST() { // Calculate Local Sidereal Time
DateTime now = RTC.now();
double M, Y, D, MN, H, S;
double A, B, C, E, F;
M = (int)now.month();
Y = (int)now.year();
D = (int)now.day();
MN = (int)now.minute();
H = (int)now.hour() - (TIMEZONE + DST); // Hours must be GMT/UT.
S = (int)now.second();
if (M < 3) {
M += 12;
Y -= 1;
A = (long)Y / 100;
B = (long)A / 4;
C = (long)2 - A + B;
E = (long)(365.25 * (Y + 4716));
F = (long)(30.6001 * (M + 1));
double LastJDN = C + D + E + F - 1524.5; // Julian day last midnight UT
double Current_d = LastJDN - 2451545.0; //Days since Year 2000
long Current_T = Current_d / 36525; // Julian centuries since Year 2000
long NewJDN = LastJDN + H / 24; // Julian day today
Serial.println();
Serial.print("Julian Day Number..: ");
Serial.print(NewJDN); // Julian day today
double Term1 = 6.697374558; // this line must be a double!
double Term2 = 0.06570982441908 * Current_d;
H = H + ((double)MN / 60) + ((double)S / 3600);
float GMST;
float Term3;
Term3 = 0.00273790935 * H;
Term3 += H;
GMST = Term1 + Term2 + Term3; // Terms are found at http://aa.usno.navy.mil/faq/docs/GAST.php
//add on longitude divided by 15 to get LST
double LST = GMST + (LONGITUDE / 15); // longitude as hour angle.
//reduce it to 24 format
int LSTint;
LSTint = (int)LST;
LSTint /= 24;
LST = LST - (double)LSTint * 24;
int LST_H = (int)LST;
int LST_M = ((LST - LST_H) * 60);
int LST_S = (((LST - LST_H) * 60) - LST_M) * 60;
Serial.println();
Serial.print("Local Sidereal time: ");
Serial.print(LST_H);
Serial.print(':');
Serial.print(LST_M);
Serial.print(':');
Serial.println(LST_S);
