Már nem tudom hol találtam...
kész fájl itt@echo off
%windir%\system32\reg.exe query "HKU\S-1-5-19" 1>nul 2>nul || (
echo ==== ERROR ====
echo This script require administrator privileges.
echo To do so, right click on this script and select 'Run as administrator'
echo.
echo Press any key to exit...
pause >nul
goto :eof
for /f "tokens=6 delims=[]. " %%# in ('ver') do set winbuild=%%#
if %winbuild% gtr 7601 goto :proceed
:: # End Of Support KB4493132 #
reg add HKCU\Software\Microsoft\Windows\CurrentVersion\SipNotify /f /v DontRemindMe /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Windows\CurrentVersion\SipNotify /f /v DateModified /t REG_QWORD /d 0x0
reg add HKCU\Software\Microsoft\Windows\CurrentVersion\SipNotify /f /v LastShown /t REG_QWORD /d 0x0
schtasks /Change /DISABLE /TN "Microsoft\Windows\End Of Support\Notify1"
schtasks /Change /DISABLE /TN "Microsoft\Windows\End Of Support\Notify2"
schtasks /Delete /F /TN "Microsoft\Windows\End Of Support\Notify1"
schtasks /Delete /F /TN "Microsoft\Windows\End Of Support\Notify2"
set hosts=%windir%\system32\drivers\etc\hosts
findstr /i "RE2JgkA" %hosts% 1>nul 2>nul || (
attrib -r %hosts%
echo 127.0.0.1 query.prod.cms.rt.microsoft.com/cms/api/am/binary/RE2JgkA>>%hosts%
attrib +r %hosts%
attrib -a %hosts%
:proceed
:: # Unified Telemetry Client #
sc.exe config DiagTrack start= disabled
sc.exe stop DiagTrack
reg add HKLM\SOFTWARE\Policies\Microsoft\Windows\Gwx /v DisableGwx /t REG_DWORD /d 1 /f
reg add HKLM\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate /v DisableOSUpgrade /t REG_DWORD /d 1 /f
reg delete "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\OSUpgrade" /f
reg add HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\OSUpgrade /v AllowOSUpgrade /t REG_DWORD /d 0 /f
reg delete HKLM\SOFTWARE\Policies\Microsoft\Windows\DataCollection /f
reg delete HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Diagnostics\DiagTrack /f
reg add HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Diagnostics\DiagTrack /v DiagTrackAuthorization /t REG_DWORD /d 0 /f
reg add HKLM\SOFTWARE\Microsoft\SQMClient\IE /v CEIPEnable /t REG_DWORD /d 0 /f
reg add HKLM\SOFTWARE\Microsoft\SQMClient\IE /v SqmLoggerRunning /t REG_DWORD /d 0 /f
reg add HKLM\SOFTWARE\Microsoft\SQMClient\Reliability /v CEIPEnable /t REG_DWORD /d 0 /f
reg add HKLM\SOFTWARE\Microsoft\SQMClient\Reliability /v SqmLoggerRunning /t REG_DWORD /d 0 /f
reg add HKLM\SOFTWARE\Microsoft\SQMClient\Windows /v CEIPEnable /t REG_DWORD /d 0 /f
reg add HKLM\SOFTWARE\Microsoft\SQMClient\Windows /v SqmLoggerRunning /t REG_DWORD /d 0 /f
reg add HKLM\SOFTWARE\Microsoft\SQMClient\Windows /v DisableOptinExperience /t REG_DWORD /d 1 /f
reg delete HKLM\SYSTEM\CurrentControlSet\Control\WMI\AutoLogger\AutoLogger-Diagtrack-Listener /f
reg delete HKLM\SYSTEM\CurrentControlSet\Control\WMI\AutoLogger\Diagtrack-Listener /f
reg delete HKLM\SYSTEM\CurrentControlSet\Control\WMI\AutoLogger\SQMLogger /f
icacls "%ProgramData%\Microsoft\Diagnosis" /grant:r *S-1-5-32-544:(OI)(CI)(IO)(F) /T /C
del /f /q %ProgramData%\Microsoft\Diagnosis\*.rbs
del /f /q /s %ProgramData%\Microsoft\Diagnosis\ETLLogs\*
:: # Microsoft Compatibility Appraiser #
reg delete "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Appraiser" /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Appraiser" /v HaveUploadedForTarget /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\AIT" /v AITEnable /t REG_DWORD /d 0 /f
reg delete "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\ClientTelemetry" /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\ClientTelemetry" /v DontRetryOnError /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\ClientTelemetry" /v IsCensusDisabled /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\ClientTelemetry" /v TaskEnableRun /t REG_DWORD /d 1 /f
for %%i in (InstallInfoCheck,ARPInfoCheck,MediaInfoCheck,FileInfoCheck) do reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Tracing" /v %%i /t REG_DWORD /d 0 /f
reg delete "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags" /v UpgradeEligible /f
reg delete "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\TelemetryController" /f
schtasks /Change /DISABLE /TN "Microsoft\Windows\SetupSQMTask"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Customer Experience Improvement Program\BthSQM"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Customer Experience Improvement Program\Consolidator"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Customer Experience Improvement Program\TelTask"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Customer Experience Improvement Program\UsbCeip"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Application Experience\AitAgent"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser"
schtasks /Change /DISABLE /TN "Microsoft\Windows\Application Experience\ProgramDataUpdater"
schtasks /Change /DISABLE /TN "Microsoft\Windows\PerfTrack\BackgroundConfigSurveyor"
schtasks /Delete /F /TN "Microsoft\Windows\SetupSQMTask"
schtasks /Delete /F /TN "Microsoft\Windows\Customer Experience Improvement Program\BthSQM"
schtasks /Delete /F /TN "Microsoft\Windows\Customer Experience Improvement Program\Consolidator"
schtasks /Delete /F /TN "Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask"
schtasks /Delete /F /TN "Microsoft\Windows\Customer Experience Improvement Program\TelTask"
schtasks /Delete /F /TN "Microsoft\Windows\Customer Experience Improvement Program\UsbCeip"
schtasks /Delete /F /TN "Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser"
schtasks /Delete /F /TN "Microsoft\Windows\Application Experience\ProgramDataUpdater"
schtasks /Delete /F /TN "Microsoft\Windows\Application Experience\AitAgent"
schtasks /Delete /F /TN "Microsoft\Windows\PerfTrack\BackgroundConfigSurveyor"
echo.
echo.
echo Closing in 5 Seconds...
timeout /t 5 >nul
goto :eof
