vCenter database recovery
Quick HowTo
Windows error log
MSSQL$VIM_SQLEXP
CREATE DATABASE or ALTER DATABASE failed because the resulting cumulative database size would exceed your licensed limit of 10240 MB per database
Solution
VMware knowledge base
MSSQL CLI
start cmd as administratot
sqlcmd -S np:\\127.0.0.1\pipe\MSSQL$VIM_SQLEXP\sql\query
(Exact string can be recovered for the MSSQL admin GUI if it is not the same)
list DBs
EXEC sp_databases
go
Change DB
use VIM_VCDB;
go
Dry run
Copy paste SQL script from KB entry.
Cleanup
Set DELETE_DATA to 1 as below in the script and re-run
-- ######### USER CONFIGURABLE PARAMETERS ########################
-- 0 = COUNT ONLY; 1 = DELETE ROWS
SET @DELETE_DATA = 1
10G DB cleanup took cca. 3 hours
Légy az első hozzászóló!
Hozzászólok
