ezt írja a gép (a linux topicban kérdezett cf kártyás):
[38007.040765] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[38007.040847] ata1.00: failed command: WRITE DMA
[38007.040922] ata1.00: cmd ca/00:40:c0:a7:35/00:00:00:00:00/e0 tag 0 dma 32768 out
[38007.040933] res 40/00:01:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[38007.041026] ata1.00: status: { DRDY }
[38012.081592] ata1: link is slow to respond, please be patient (ready=0)
[38017.066679] ata1: device not ready (errno=-16), forcing hardreset
[38017.066709] ata1: soft resetting link
[38022.263766] ata1: link is slow to respond, please be patient (ready=0)
[38027.080785] ata1: SRST failed (errno=-16)
[38027.080861] ata1: soft resetting link
[38032.277892] ata1: link is slow to respond, please be patient (ready=0)
[38037.094917] ata1: SRST failed (errno=-16)
[38037.094993] ata1: soft resetting link
[38042.292189] ata1: link is slow to respond, please be patient (ready=0)
[38072.146378] ata1: SRST failed (errno=-16)
[38072.146454] ata1: soft resetting link
[38077.175447] ata1: SRST failed (errno=-16)
[38077.187585] ata1: reset failed, giving up
[38077.187623] ata1.00: disabled
[38077.187649] ata1.00: device reported invalid CHS sector 0
[38077.187689] ata1: EH complete
[38077.188362] sd 0:0:0:0: [sda] Unhandled error code
[38077.188381] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[38077.188407] sd 0:0:0:0: [sda] CDB: Write(10): 2a 00 00 35 a7 c0 00 00 40 00
[38077.188460] end_request: I/O error, dev sda, sector 3516352
[38077.188555] sd 0:0:0:0: [sda] Unhandled error code
[38077.188572] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[38077.188596] sd 0:0:0:0: [sda] CDB: Write(10): 2a 00 00 49 b1 d8 00 00 08 00
[38077.188646] end_request: I/O error, dev sda, sector 4829656
[38077.188690] Buffer I/O error on device sda1, logical block 603451
[38077.188730] lost page write due to I/O error on sda1
[38077.189101] Aborting journal on device sda1.
[38077.189237] EXT3-fs (sda1): error in ext3_ordered_write_end: IO failure
[38077.189282] EXT3-fs (sda1): error: remounting filesystem read-only
[38077.189395] EXT3-fs (sda1): error in ext3_reserve_inode_write: Journal has aborted
[38077.189637] EXT3-fs (sda1): error in ext3_reserve_inode_write: Journal has aborted
[38077.189859] sd 0:0:0:0: [sda] Unhandled error code
[38077.189877] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[38077.189903] sd 0:0:0:0: [sda] CDB: Write(10): 2a 00 00 34 17 f8 00 00 08 00
[38077.189954] end_request: I/O error, dev sda, sector 3414008
[38077.189998] Buffer I/O error on device sda1, logical block 426495
[38077.190040] lost page write due to I/O error on sda1
[38077.190093] sd 0:0:0:0: [sda] Unhandled error code
[38077.190110] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[38077.190135] sd 0:0:0:0: [sda] CDB: Write(10): 2a 00 00 00 08 00 00 00 08 00
[38077.190184] end_request: I/O error, dev sda, sector 2048
[38077.190225] Buffer I/O error on device sda1, logical block 0
[38077.190263] lost page write due to I/O error on sda1
[38077.190328] JBD: I/O error detected when updating journal superblock for sda1.
[38077.190439] EXT3-fs (sda1): I/O error while writing superblock
[38077.190746] ------------[ cut here ]------------
[38077.190837] WARNING: at /build/buildd-linux-2.6_3.1.6-1-i386-Q6YFvu/linux-2.6-3.1.6/debian/build/source_i386_none/fs/ext3/inode.c:1620 ext3_ordered_writepage+0x38/0x186 [ext3]()
[38077.190863] Modules linked in: loop wlan_scan_ap(O) ath_rate_sample(O) ecb evdev snd_pcm option scx200_acb snd_timer cs5535_mfgpt i2c_core cryptd ath_pci(O) usb_wwan snd aes_i586 usbserial aes_generic wlan(O) soundcore snd_page_alloc ath_hal(P) pcspkr geode_aes geode_rng cs5535_mfd rng_core ext3 jbd mbcache sd_mod crc_t10dif ata_generic pata_cs5536 ohci_hcd pata_amd libata scsi_mod ehci_hcd usbcore via_rhine mii [last unloaded: scsi_wait_scan]
[38077.191059] Pid: 860, comm: flush-8:0 Tainted: P O 3.1.0-1-486 #1
[38077.191075] Call Trace:
[38077.191107] [<c1022330>] ? warn_slowpath_common+0x68/0x79
[38077.191164] [<d08c68a0>] ? ext3_ordered_writepage+0x38/0x186 [ext3]
[38077.191192] [<c102234e>] ? warn_slowpath_null+0xd/0x10
[38077.191249] [<d08c68a0>] ? ext3_ordered_writepage+0x38/0x186 [ext3]
[38077.191276] [<c1079b36>] ? __writepage+0x8/0x1d
[38077.191300] [<c1079f6c>] ? write_cache_pages+0x1bd/0x27f
[38077.191325] [<c1079b2e>] ? test_set_page_writeback+0xa9/0xa9
[38077.191353] [<c11155e7>] ? blk_flush_plug_list+0x14e/0x156
[38077.191386] [<c10b71c2>] ? wb_do_writeback+0x152/0x152
[38077.191420] [<c1005c98>] ? native_sched_clock+0x41/0x97
[38077.191492] [<c107a05c>] ? generic_writepages+0x2e/0x42
[38077.191522] [<c10b6844>] ? writeback_single_inode+0xba/0x1cc
[38077.191549] [<c10b6ab7>] ? writeback_sb_inodes+0x11b/0x18c
[38077.191578] [<c10b6b78>] ? __writeback_inodes_wb+0x50/0x81
[38077.191606] [<c10b6c87>] ? wb_writeback+0xde/0x175
[38077.191637] [<c102b9d2>] ? __mod_timer.isra.37+0xb9/0xc3
[38077.191663] [<c10b717c>] ? wb_do_writeback+0x10c/0x152
[38077.191691] [<c10b71c2>] ? wb_do_writeback+0x152/0x152
[38077.191717] [<c10b722b>] ? bdi_writeback_thread+0x69/0x172
[38077.191743] [<c10b71c2>] ? wb_do_writeback+0x152/0x152
[38077.191768] [<c1035aca>] ? kthread+0x62/0x67
[38077.191792] [<c1035a68>] ? flush_kthread_worker+0x73/0x73
[38077.191823] [<c1275946>] ? kernel_thread_helper+0x6/0xd
[38077.191839] ---[ end trace 32e3fa90ec650fb1 ]---
[73963.554684] sd 0:0:0:0: [sda] Unhandled error code
[73963.554704] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[73963.554731] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 08 17 f8 00 00 08 00
[73963.554783] end_request: I/O error, dev sda, sector 530424
[73963.554958] sd 0:0:0:0: [sda] Unhandled error code
[73963.554975] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[73963.555002] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 08 17 f8 00 00 08 00
[73963.555052] end_request: I/O error, dev sda, sector 530424
Ez most "diszk"csere vagy alaplap csere? a döntés maga kevésbé fontos, a fontos az lenne, hogy eltaláljuk, mi a hiba oka, mert elérhetetlen helyen van a gép.
ezen a diszken tegnap végigment egy badblock non-destructive-write módban, nem dobott hibát.
