A mai járművünk egy igen ritka gép, igazából a ZIL 137 elődje, 6x6-os, és Szibériában használták a 60-as években emberek szállítására, nehéz körülmények között.
Adatai:
ZIL-E-167 is an off-road truck:
This truck was designed in the beginning of 1960’s. It was designed to withstand difficult conditions in Siberia, Urals and far east and northern territories of Soviet Union. It is also able to cross water and it is able to control its tire pressure, equipped with air cleaning systems and has 4.5 kW electric engine to pump water (in case of fire) and it also has radio transmission capabilities.
Wheels 6x6
Engine: (2xZIL-375) Engine displacement 2x3,5 liters Performance 2x180 hp Fuel tank capacity 900 liters Fuel consumption 100 liters/100km Max speed 65 km/h (on the road fully loaded) Max speed in 50/80 cm water 30/20 km/h
[edit] Measures
* Length 9260 mm
* Width 3130 mm
* Height 3060 mm
* Ground clearance 750 mm
* Turning radius 11 900 mm
Weights:
* Cerb (sicsic) weight 7000 kg
* Payload 5000 kg
Abilities
* Ability to go through obstacles:
* Trench 2000 mm
* Vertical wall 1000 mm
* Rise angle 42 degrees
* Fording 1800 mm
* Snow 1000 mm
Vagy csak simán a hasa alá vesz őket, szerintem egy sport kocsi aláférne szélességre és magasságra is.
