Dzsekó _
jim bcs
Fujitsu 2,5
1.08GB/platter Section (all drives under here use platters that can hold 1.08GB of data apiece.)
Hornet 8/Mobile 3 (4000RPM, 128KB cache, ATA-16 interface)
MHA2021AT 2.16GB (2/4)
MHA2032AT 3.24GB (3/6)
1.36-1.62GB/platter Section (all drives under here use platters that can hold 1.36-1.62GB of data apiece.)
Hornet 9/Mobile 4 (4000RPM, 512KB cache, ATA-33 interface, 12.5mm z-height)
MHC2040AT 4.09GB (3/6)
Hornet 9L/Mobile 4L (4000RPM, 512KB cache, ATA-33 interface)
MHD2021AT 2.16GB (2/3 [short-stroked])
MHD2032AT 3.25GB (2/4)
2.16GB/platter Section (all drives under here use platters that can hold 2.16GB of data apiece.)
Hornet 10/Mobile 6 (4200RPM, 512KB cache, ATA-33 interface, 12.5mm z-height)
MHE2064AT 6.49GB (3/6)
Hornet 10L/Mobile 6L (4200RPM, 512KB cache, ATA-33 interface)
MHF2021AT 2.16GB (1/2)
MHF2043AT 4.32GB (2/4)
3.2-3.4GB/platter Section (all drives under here use platters that can hold 3.2-3.4GB of data apiece.)
Hornet 11/Mobile 10 (4200RPM, 512KB cache, ATA-33 interface, 12.5mm z-height)
MHG2102AT 10GB (3/6)
Hornet 11L/Mobile 10L (4200RPM, 512KB cache, ATA-33 interface)
MHH2032AT 3.2GB (1/2)
MHH2048AT 4.8GB (2/3)
MHH2064AT 6.4GB (2/4)
6GB/platter Section (all drives under here use platters that can hold 6GB of data apiece.)
Hornet 12/Mobile 18 XP (4200RPM, 512KB cache, ATA-66 interface, 12.5mm z-height)
MHJ2181AT 18.1GB (3/6)
Hornet 12L/Mobile 18 XP (4200RPM, 512KB cache, ATA-66 interface)
MHK2060AT 6GB (1/2)
MHK2090AT 9GB (2/3)
MHK2120AT 12GB (2/4)
10GB/platter Section (all drives under here use platters that can hold 10GB of data apiece.)
Hornet 13 (4200RPM, 2MB cache, ATA-66 interface, 12.5mm z-height)
MHL2300AT 30GB (3/6)
Hornet 13L (4200RPM, 2MB cache, ATA-66 interface)
MHM2100AT 10GB (1/2)
MHM2150AT 15GB (2/3)
MHM2200AT 20GB (2/4)
15GB/platter Section (all drives under here use platters that can hold 15GB of data apiece.)
Hornet 14L (4200RPM, 2MB cache, ATA-100 interface)
MHN2100AT 10GB (1/2 [short-stroked])
MHN2150AT 15GB (1/2)
MHN2200AT 20GB (2/3 [short-stroked])
MHN2300AT 30GB (2/4)
20GB/platter Section (all drives under here use platters that can hold 20GB of data apiece.)
Hornet 15L (4200RPM, 2MB cache, ATA-100 interface)
MHR2010AT 10GB (1/1)
MHR2020AT 20GB (1/2)
MHR2030AT 30GB (2/3)
MHR2040AT 40GB (2/4)
MHR2 SA (4200RPM, 2MB cache, SATA-150 interface)
MHR2020SA 20GB (1/2)
Note: These are prototype drives. Tom's Hardware reviewed one.
30GB/platter Section (all drives under here use platters that can hold 30GB of data apiece.)
Hornet 16L (4200RPM, 2MB cache, ATA-100 interface)
MHS2020AT 20GB (1/2 [short-stroked])
MHS2030AT 30GB (1/2)
MHS2040AT 40GB (2/3 [short-stroked])
MHS2060AT 60GB (2/4)
40GB/platter Section (all drives under here use platters that can hold 40GB of data apiece.)
Hornet V40 (4200RPM, 2MB [80GB: 8MB] cache, ATA-100 interface)
MHT2020AT 20GB (1/1)
MHT2030AT 30GB (1/2 [short-stroked])
MHT2040AT 40GB (1/2)
MHT2060AT 60GB (2/3)
MHT2080AT 80GB (2/4)
Hornet Z40 (5400RPM, 8MB cache, ATA-100 interface)
MHT2040AH 40GB (1/2)
MHT2060AH 60GB (2/3)
MHT2080AH 80GB (2/4)
Hornet M40 (5400RPM, 8MB cache, SATA-150 interface)
MHT2040BH 40GB (1/2)
MHT2060BH 60GB (2/3)
MHT2080BH 80GB (2/4)
MHV2 AS (5400RPM, 8MB cache, ATA-100 interface, for 24/7 constant use)
MHV2040AS 40GB (1/2)
MHV2060AS 60GB (2/3)
MHV2080AS 80GB (2/4)
MHV2 BS (5400RPM, 8MB cache, SATA-150 interface, for 24/7 constant use)
MHV2040BS 40GB (1/2)
MHV2060BS 60GB (2/3)
MHV2080BS 80GB (2/4)
50GB/platter Section (all drives under here use platters that can hold 50GB of data apiece.)
Hornet V50 (4200RPM, 8MB cache, ATA-100 interface)
MHU2100AT 100GB (2/4)
60-66GB/platter Section (all drives under here use platters that can hold 60-66GB of data apiece.)
Hornet V60 (4200RPM, 8MB [40GB: 2MB] cache, ATA-100 interface)
MHV2040AT 40GB (1/2 [short-stroked])
MHV2060AT 60GB (1/2)
MHV2080AT 80GB (2/3 [short-stroked])
MHV2100AT 100GB (2/4 [short-stroked])
MHV2120AT 120GB (2/4)
Hornet Z60 (5400RPM, 8MB cache, ATA-100 interface)
MHV2040AH 40GB (1/2 [short-stroked])
MHV2060AH 60GB (1/2)
MHV2080AH 80GB (2/3 [short-stroked])
MHV2100AH 100GB (2/4 [short-stroked])
MHV2120AH 120GB (2/4)
Hornet M60 (5400RPM, 8MB cache, SATA-150 interface)
MHV2040BH 40GB (1/2 [short-stroked])
MHV2060BH 60GB (1/2)
MHV2080BH 80GB (2/3 [short-stroked])
MHV2100BH 100GB (2/4 [short-stroked])
MHV2120BH 120GB (2/4)
Hornet J70H (4200RPM, 8MB cache, SATA-150 interface, 12.5mm z-height)
MHV2160BT 160GB (3/6 [short-stroked])
MHV2200BT 200GB (3/6)
MHW2 BK (7200RPM, 8MB cache, SATA-300 interface, for 24/7 constant use)
MHW2060BK 60GB (1/2)
MHW2080BK 80GB (2/3 [short-stroked])
MHW2120BK 120GB (2/4)
MHW2 AC (4200RPM, 8MB cache, ATA-100 interface, Extreme Environment)
MHW2040AC 40GB (1/2 [short-stroked])
MHW2060AC 60GB (1/2)
MHW2040AC E 40GB (1/2 [short-stroked])
MHW2060AC E 60GB (1/2)
80GB/platter Section (all drives under here use platters that can hold 80GB of data apiece.)
Hornet V80 (4200RPM, 2MB [80GB: 8MB] cache, ATA-100 interface)
MHW2040AT 40GB (1/1)
MHW2060AT 60GB (1/2 [short-stroked])
MHW2080AT 80GB (1/2)
Hornet M80 (5400RPM, 8MB cache, SATA-150 interface)
MHW2020BH 20GB (1/1 [short-stroked])
MHW2040BH 40GB (1/1)
MHW2060BH 60GB (1/2 [short-stroked])
MHW2080BH 80GB (1/2)
MHW2100BH 100GB (2/3 [short-stroked])
MHW2120BH 120GB (2/3)
MHW2160BH 160GB (2/4)
Hornet A80 (7200RPM, 8MB cache, SATA-300 interface)
MHW2080BJ 80GB (1/2)
MHW2120BJ 120GB (2/3)
MHW2160BJ 160GB (2/4)
100GB/platter Section (all drives under here use platters that can hold 100GB of data apiece.)
Hornet J100H (4200RPM, 8MB cache, SATA-150 interface, 12.5mm z-height)
MHX2250BT 250GB (3/5)
MHX2300BT 300GB (3/6)
MHY2 BS (5400RPM, 8MB cache, SATA-150 interface, for 24/7 constant use)
MHY2040BS (1/1 [short-stroked])
MHY2060BS (1/2 [short-stroked])
MHY2080BS (1/2 [short-stroked])
MHY2100BS (1/2)
MHY2120BS (2/3 [short-stroked])
MHY2160BS (2/4 [short-stroked])
MHY2200BS (2/4)
120GB/platter Section (all drives under here use platters that can hold 120GB of data apiece.)
Hornet M120 (5400RPM, 8MB cache, SATA-150 interface)
MHY2040BH 40GB (1/1 [short-stroked])
MHY2060BH 60GB (1/1)
MHY2080BH 80GB (1/2 [short-stroked])
MHY2100BH 100GB (1/2 [short-stroked])
MHY2120BH 120GB (1/2)
MHY2160BH 160GB (2/3 [short-stroked])
MHY2200BH 200GB (2/4 [short-stroked])
MHY2250BH 250GB (2/4)
MHZ2 BS (5400RPM, 8MB cache, SATA-300 interface, for 24/7 constant use)
MHZ2120BS 120GB (1/2)
MHZ2250BS 250GB (2/4)
MHZ2 BK (7200RPM, 16MB cache, SATA-300 interface, for 24/7 constant use)
MHZ2080BK 80GB (1/2 [short-stroked])
MHZ2120BK 120GB (1/2)
MHZ2160BK 160GB (2/3 [short-stroked])
MHZ2250BK 250GB (2/4)
160-166GB/platter Section (all drives under here use platters that can hold 160-166GB of data apiece.)
Hornet M160 (5400RPM, 8MB cache, SATA-300 interface)
MHZ2080BH 80GB(1/1)
MHZ2120BH 120GB (1/2 [short-stroked])
MHZ2160BH 160GB(1/2)
MHZ2200BH 200GB (2/4 [short-stroked])
MHZ2250BH 250GB (2/4 [short-stroked])
MHZ2320BH 320GB (2/4)
Hornet A160 (7200RPM, 16MB cache, SATA-300 interface)
MHZ2080BJ 80GB (1/1)
MHZ2120BJ 120GB (1/2 [short-stroked])
MHZ2160BJ 160GB (1/2)
MHZ2200BJ 200GB (2/4 [short-stroked])
MHZ2250BJ 250GB (2/4 [short-stroked])
MHZ2320BJ 320GB (2/4)
MHZ2 CJ (7200RPM, 16MB cache, SATA-300 interface, with hardware AES 256-bit encryption)
MHZ2080CJ 80GB (1/1)
MHZ2120CJ 120GB (1/2 [short-stroked])
MHZ2160CJ 160GB (1/2)
MHZ2250CJ 250GB (2/4 [short-stroked])
MHZ2320CJ 320GB (2/4)
Hornet J170 (4200RPM, 8MB cache, SATA-300 interface, 12.5mm z-height)
MHZ2400BT 400GB (3/5)
MHZ2500BT 500GB (3/6)
Fujitsu aimed these at CE applications (e.g. tiny DVRs, etc), but Sony went ahead and used (misused?) them in some Vaio laptops as well. Most of the MHZ2500BTs floating around the internet are pulls from those machines, apparently.
250GB/platter Section (all drives under here use platters that can hold 250GB of data apiece.)
Hornet M250 (5400RPM, 8MB cache, SATA-300 interface)
MJA2080BH 80GB (1/1 [short-stroked])
MJA2120BH 120GB (1/1)
MJA2160BH 160GB (1/2 [short-stroked])
MJA2250BH 250GB (1/2)
MJA2320BH 320GB (2/3 [short-stroked])
MJA2400BH 400GB (2/4 [short-stroked])
MJA2500BH 500GB (2/4)
MJA2 CH (5400RPM, 8MB cache, SATA-300 interface, with hardware AES 256-bit encryption)
MJA2080CH 80GB (1/1 [short-stroked])
MJA2160CH 160GB (1/2 [short-stroked])
MJA2250CH 250GB (1/2)
MJA2320CH 320GB (2/3 [short-stroked])
MJA2400CH 400GB (2/4 [short-stroked])
MJA2500CH 500GB (2/4)
HGST CE AV
160-167GB/platter Section (all drives under here use platters that can hold 160-167GB of data apiece.)
CinemaStar 7K160 (7200RPM, 8MB cache, ATA-100 interface)
HCS721680PLAT00 80GB (1/1)
HCS721616PLAT00 160GB (1/2)
CinemaStar 7K160 (7200RPM, 8MB cache, SATA-300 interface)
HCS721680PLA390 80GB (1/1)
HCS721616PLA390 160GB (1/2)
ExcelStor Venus (7200RPM, 8MB cache, ATA-100 interface)
V8080 80GB (1/1)
V8160 160GB (1/2)
Note: these are relabelled CinemaStar 7K160s.
ExcelStor Venus (7200RPM, 8MB cache, SATA-300 interface)
V8080S 80GB (1/1)
V8160S 160GB (1/2)
CinemaStar 7K500 (7200RPM, 8MB cache, ATA-100 interface)
HCS725025VLAT80 250GB (2/4 [short-stroked])
HCS725032VLAT80 320GB (2/4)
HCS725040VLAT80 400GB (3/6 [short-stroked])
HCS725050VLAT80 500GB (3/6)
CinemaStar 7K500 (7200RPM, 8MB cache, SATA-300 interface)
HCS725025VLA380 250GB (2/4 [short-stroked])
HCS725032VLA380 320GB (2/4)
HCS725040VLA380 400GB (3/6 [short-stroked])
HCS725050VLA380 500GB (3/6)
200-250GB/platter Section (all drives under here use platters that can hold 200-250GB of data apiece.)
CinemaStar 7K1000 (7200RPM, 32MB cache, SATA-300 interface)
HCS721075KLA330 750GB (4/8 [short-stroked])
HCS721010KLA330 1TB (5/10)
CinemaStar P7K500 (7200RPM, 8MB cache, ATA-100 interface)
HCP725025GLAT80 250GB (1/2)
HCP725032GLAT80 320GB (2/3 [short-stroked])
HCP725050GLAT80 500GB (2/4)
CinemaStar P7K500 (7200RPM, 8MB cache, SATA-300 interface)
HCP725025GLA380 250GB (1/2)
HCP725032GLA380 320GB (2/3 [short-stroked])
HCP725050GLA380 500GB (2/4)
V9160 160GB (1/2 [short-stroked])
V9250 250GB (1/2)
Note: these are relabelled CinemaStar P7K500s.
V9160S 160GB (1/2 [short-stroked])
V9250S 250GB (1/2)
CinemaStar 7K1000.B (7200RPM, 8MB cache, SATA-300 interface)
HCT721025SLA380 250GB (1/2)
CinemaStar 5K320 (5400RPM, 8MB cache, SATA-300 interface)
HCS5C3225SLA380 250GB (1/2)
CinemaStar 5K500 (5400RPM, 8MB cache, SATA 3Gbps interface)
HCS545050GLA380 500GB (2/4)
320-400GB/platter Section (all drives under here use platters that can hold 320-400GB of data apiece.)
CinemaStar 7K1000.B (7200RPM, SATA-300 interface)
HCT721016SLA380 (8MB Cache) 160GB (1/1)
HCT721032SLA380 (8MB Cache) 320GB (1/2)
HCT721050SLA380 (8MB Cache) 500GB (2/3)
HCT721010SLA360 (16MB Cache) 1TB (3/6)
HCS5C3232SLA380 320GB (1/2)
CinemaStar 5K2000 (5400RPM, 32MB cache, SATA-600 interface)
HCS5C2015ALA632 1.5TB (5/10 [short-stroked])
HCS5C2020ALA632 2TB (5/10)
500GB/platter Section (all drives under here use platters that can hold 500GB of data apiece.)
CinemaStar 7K1000.C (7200RPM, SATA-300 interface)
HCS721016CLA382 (8MB Cache) 160GB (1/1 [short-stroked])
HCS721025CLA382 (8MB Cache) 250GB (1/1)
HCS721032CLA382 (8MB Cache) 320GB (1/2 [short-stroked])
HCS721050CLA382 (8MB Cache) 500GB (1/2)
HCS721075CLA332 (32MB Cache) 750GB (2/3)
HCS721010CLA332 (32MB Cache) 1TB (2/4)
CinemaStar 5K1000 (5700RPM, 8MB cache, SATA-300 interface)
HCS5C1016CLA382 160GB (1/1 [short-stroked])
HCS5C1025CLA382 250GB (1/1)
HCS5C1032CLA382 320GB (1/2 [short-stroked])
HCS5C1050CLA382 500GB (1/2)
HCS5C1075CLA382 750GB (2/3)
HCS5C1010CLA382 1TB (2/4)
1TB/platter Section (all drives under here use platters that can hold 1TB of data apiece.)
CinemaStar 7K1000.D (7200RPM, 32MB cache, SATA-600 interface)
HCS721025DLE630 250GB (1/1 [short-stroked])
HCS721032DLE630 320GB (1/1 [short-stroked])
HCS721050DLE630 500GB (1/1)
HCS721075DLE630 750GB (1/2 [short-stroked])
HCS721010DLE630 1TB (1/2)
CinemaStar 5K1000.B (7200RPM, 32MB cache, SATA-600 interface)
HCS5C1025DLE630 250GB (1/1 [short-stroked])
HCS5C1032DLE630 320GB (1/1 [short-stroked])
HCS5C1050DLE630 500GB (1/1)
HCS5C1075DLE630 750GB (1/2 [short-stroked])
HCS5C1010DLE630 1TB (1/2)
HGST Desktop
80-83GB/platter Section (all drives under here use platters that can hold 80-83GB of data apiece.)
Deskstar 7K250 (7200RPM, ATA-100 interface)
HDS722540VLAT20 (2MB Cache) 40GB (1/1)
HDS722580VLAT20 (2MB Cache) 80GB (1/2)
HDS722512VLAT20 (2MB Cache) 120GB (2/3)
HDS722512VLAT80 (8MB Cache) 120GB (2/3)
HDS722516VLAT20 (2MB Cache) 160GB (2/4)
HDS722516VLAT80 (8MB Cache) 160GB (2/4)
HDS722525VLAT80 (8MB Cache) 250GB (3/6)
Deskstar 7K250 (7200RPM, 8MB cache, SATA-150 interface)
HDS722540VLSA80 40GB (1/1)
HDS722580VLSA80 80GB (1/2)
HDS722512VLSA80 120GB (2/3)
HDS722516VLSA80 160GB (2/4)
HDS722525VLSA80 250GB (3/6)
ExcelStor Ganymede (7200RPM, 2MB cache, ATA-100 interface)
J640 40GB (1/1)
J660 60GB (1/1 [short-stroked])
J680 80GB (1/2)
Note: these are relabelled Deskstar 7K250s.
ExcelStor Ganymede (7200RPM, 8MB cache, SATA-150 interface)
J680S 80GB (1/2)
Deskstar 7K80 (7200RPM, 2MB cache, ATA-100 interface)
HDS728040PLAT20 40GB (1/1)
HDS728080PLAT20 80GB (1/2)
Deskstar 7K80 (7200RPM, SATA-300 interface)
HDS728040PLA320 (2MB Cache) 40GB (1/1)
HDS728080PLA380 (8MB Cache) 80GB (1/2)
ExcelStor Callisto (7200RPM, 2MB cache, ATA-100 interface)
J840 40GB (1/1)
J860 60GB (1/1 [short-stroked])
J880 80GB (1/2)
Note: these are relabelled Deskstar 7K80s.
ExcelStor Callisto (7200RPM, 8MB cache, SATA-300 interface)
J880S 80GB (1/2)
ExcelStor GStor Plus (7200RPM, ?MB cache, ATA-100 interface)
J1080 80GB (1/2)
Note: these are relabelled Deskstar 7K80s, with an extra chip on the PCB that handles automated partition creation, backup, rollback, and encryption.
Deskstar 7K400 (7200RPM, 8MB cache, ATA-100 interface)
HDS724040KLAT80 400GB (5/10)
Deskstar 7K400 (7200RPM, 8MB cache, SATA-150 interface)
HDS724040KLSA80 400GB (5/10)
Deskstar 7K500 (7200RPM, 8MB cache, ATA-100 interface)
HDS725050KLAT80 500GB (5/10)
Deskstar E7K500 (7200RPM, 16MB cache, SATA-300 interface)
HDS725050KLA360 500GB (5/10)
HDS725050KLA361 500GB (5/10)*
*Note: apparently only 400GB of space is accessible in this model of E7K500.
125GB/platter Section (all drives under here use platters that can hold 125GB of data apiece.)
Deskstar 7K160 (7200RPM, 8MB cache, ATA-100 interface)
HDS721612PLAT80 120GB (1/2)
Deskstar 7K160 (7200RPM, 8MB cache, SATA-300 interface)
HDS721612PLA380 120GB (1/2)
Deskstar T7K250 (7200RPM, 8MB cache, ATA-100 interface)
HDT722516DLAT80 160GB (2/3 [short-stroked])
HDT722525DLAT80 250GB (2/4)
Deskstar T7K250 (7200RPM, 8MB cache, SATA-300 interface)
HDT722516DLA380 160GB (2/3 [short-stroked])
HDT722525DLA380 250GB (2/4)
HDS721680PLAT80 80GB (1/1)
HDS721616PLAT80 160GB (1/2)
Deskstar 7K160 (7200RPM, SATA-300 interface)
HDS721680PLA320 (2MB Cache) 80GB (1/1)
HDS721680PLA380 (8MB Cache) 80GB (1/1)
HDS721616PLA320 (2MB Cache) 160GB (1/2)
HDS721616PLA380 (8MB Cache) 160GB (1/2)
ExcelStor Jupiter (7200RPM, 8MB cache, ATA-100 interface)
J8080 80GB (1/1)
J8160 160GB (1/2)
Note: these are relabelled Deskstar 7K160s.
ExcelStor Jupiter (7200RPM, 8MB cache, SATA-300 interface)
J8080S 80GB (1/1)
J8160S 160GB (1/2)
Deskstar T7K500 (7200RPM, 8MB cache, ATA-100 interface)
HDT725025VLAT80 250GB (2/4 [short-stroked])
HDT725032VLAT80 320GB (2/4)
HDT725040VLAT80 400GB (3/6 [short-stroked])
HDT725050VLAT80 500GB (3/6)
Deskstar T7K500 (7200RPM, SATA-300 interface)
HDT725025VLA380 (8MB Cache) 250GB (2/4 [short-stroked])
HDT725025VLA360 (16MB Cache) 250GB (2/4 [short-stroked])
HDT725032VLA380 (8MB Cache) 320GB (2/4)
HDT725032VLA360 (16MB Cache) 320GB (2/4)
HDT725040VLA380 (8MB Cache) 400GB (3/6 [short-stroked])
HDT725040VLA360 (16MB Cache) 400GB (3/6 [short-stroked])
HDT725050VLA380 (8MB Cache) 500GB (3/6)
HDT725050VLA360 (16MB Cache) 500GB (3/6)
Deskstar 7K1000 (7200RPM, 32MB cache, SATA-300 interface)
HDS721075KLA330 750GB (4/8 [short-stroked])
HDS721010KLA330 1TB (5/10)
Note: The first consumer 1TB 3.5" hard drive.
Deskstar P7K500 (7200RPM, 8MB cache, ATA-100 interface)
HDP725016GLAT80 160GB (1/2 [short-stroked])
HDP725025GLAT80 250GB (1/2)
HDP725032GLAT80 320GB (2/3 [short-stroked])
HDP725040GLAT80 400GB (2/4 [short-stroked])
HDP725050GLAT80 500GB (2/4)
Deskstar P7K500 (7200RPM, SATA-300 interface)
HDP725016GLA380 (8MB Cache) 160GB (1/2 [short-stroked])
HDP725025GLA380 (8MB Cache) 250GB (1/2)
HDP725032GLA380 (8MB Cache) 320GB (2/3 [short-stroked])
HDP725032GLA360 (16MB Cache) 320GB (2/3 [short-stroked])
HDP725040GLA380 (8MB Cache) 400GB (2/4 [short-stroked])
HDP725040GLA360 (16MB Cache) 400GB (2/4 [short-stroked])
HDP725050GLA380 (8MB Cache) 500GB (2/4)
HDP725050GLA360 (16MB Cache) 500GB (2/4)
J9160 160GB (1/2 [short-stroked])
J9250 250GB (1/2)
Note: these are relabelled Deskstar P7K500s.
J9160S 160GB (1/2 [short-stroked])
J9250S 250GB (1/2)
Deskstar 7K1000.B (7200RPM, SATA-300 interface)
HDT721025SLA380 250GB (8MB Cache) (1/2)
HDT721075SLA360 750GB (16MB Cache) (3/6)
Deskstar E7K1000 (7200RPM, 32MB cache, SATA-300 interface)
HDE721075SLA330 750GB (3/6)
HDT721016SLA380 160GB (8MB Cache) (1/1)
HDT721032SLA360 320GB (16MB Cache) (1/2)
HDT721050SLA360 500GB (16MB Cache) (2/3)
HDT721064SLA360 640GB (16MB Cache) (2/4)
HDT721010SLA360 1TB (16MB Cache) (3/6)
HDE721050SLA330 500GB (2/3)
HDE721010SLA330 1TB (3/6)
Deskstar 7K2000 (7200RPM, 32MB cache, SATA-300 interface)
HDS722020ALA330 2TB (5/10)
Deskstar 7K1000.C (7200RPM, SATA-300 interface)
HDS721016CLA382 160GB (8MB Cache) (1/1 [short-stroked])
HDS721025CLA382 250GB (8MB Cache) (1/1)
HDS721032CLA362 320GB (16MB Cache) (1/2 [short-stroked])
HDS721050CLA362 500GB (16MB Cache) (1/2)
HDS721064CLA332 640GB (32MB Cache) (2/3 [short-stroked])
HDS721075CLA332 750GB (32MB Cache) (2/3)
HDS721010CLA332 1TB (32MB Cache) (2/4)
Deskstar 7K1000.C (7200RPM, SATA-600 interface)
HDS721016CLA682 160GB (8MB Cache) (1/1 [short-stroked])
HDS721025CLA682 250GB (8MB Cache) (1/1)
HDS721032CLA662 320GB (16MB Cache) (1/2 [short-stroked])
HDS721050CLA662 500GB (16MB Cache) (1/2)
HDS721064CLA632 640GB (32MB Cache) (2/3 [short-stroked])
HDS721075CLA632 750GB (32MB Cache) (2/3)
HDS721010CLA632 1TB (32MB Cache) (2/4)
Deskstar 5K1000 (5700RPM, 8MB cache, SATA-300 interface)
HDS5C1050CLA382 500GB (1/2)
HDS5C1010CLA382 1TB (2/4)
600-667GB/platter Section (all drives under here use platters that can hold 600-667GB of data apiece.)
Deskstar 7K3000 (7200RPM, 64MB cache, SATA-600 interface)
HDS723015BLA642 1.5TB (3/5 [short-stroked])
HDS723020BLA642 2TB (3/6)
HDS723030ALA640 3TB (5/10)
Deskstar 5K3000 (32MB cache, SATA-600 interface)
HDS5C3015ALA632 1.5TB (5940RPM) (3/5 [short-stroked])
HDS5C3020ALA632 2TB (5940RPM) (3/6)
HDS5C3030ALA630 3TB (5700RPM) (5/10)
It would be interesting to compare the latest Seagate Barracuda Green 2TB ST2000DL003 drive with the 2TB 5K3000 here, as both models have the same platter capacity and spin at nearly the same RPM.
800GB/platter Section (all drives under here use platters that can hold 800GB of data apiece.)
Deskstar 7K4000 (7200RPM, 64MB cache, SATA-600 interface)
HDS724040ALE640 4TB (5/10)
Deskstar 5K4000 (5700RPM, 32MB cache, SATA-600 interface)
HDS5C4040ALE630 4TB (5/10)
Deskstar 7K1000.D (7200RPM, 32MB cache, SATA-600 interface)
HDS721025DLE630 250GB (1/1 [short-stroked])
HDS721032DLE630 320GB (1/1 [short-stroked])
HDS721050DLE630 500GB (1/1)
HDS721075DLE630 750GB (1/2 [short-stroked])
HDS721010DLE630 1TB (1/2)
Deskstar 5K1000.B (5400RPM?, 32MB cache, SATA-600 interface)
HDS5C1010DLE630 1TB (1/2)
HGST Enterprise
Ultrastar A7K1000 (7200RPM, 32MB cache, SATA-300 interface)
HUA721050KLA330 500GB (3/6 [short-stroked])
HUA721075KLA330 750GB (4/8 [short-stroked])
HUA721010KLA330 1TB (5/10)
400GB/platter Section (all drives under here use platters that can hold 400GB of data apiece.)
Ultrastar A7K2000 (7200RPM, 32MB cache, SATA-300 interface)
HUA722020ALA330 2TB (5/10)
HUA722020ALA331 (Encryption) 2TB (5/10)
Ultrastar 7K3000 (7200RPM, 64MB cache)
HUA723020ALA640 2TB (SATA-600 Interface) (5/10)
HUA723020ALA641 2TB (SATA-600 Interface, Encryption) (5/10)
HUS723020ALS640 2TB (SAS-600 Interface) (5/10)
HUS723020ALS641 2TB (SAS-600 Interface, Encryption) (5/10)
Ultrastar 5K3000 (5700RPM, 64MB cache, SATA-600 interface)
HUA5C3020ALA640 2TB (5/10)
HUA5C3020ALA641 2TB (Encryption) (5/10)
Ultrastar 7K4000 (7200RPM, 64MB cache)
HUS724020ALA640 2TB (SATA-600 Interface) (5/10)
HUS724020ALE640 2TB (SATA-600 Interface) (5/10)
HUS724020ALE641 2TB (SATA-600 Interface, Encryption) (5/10)
HUS724020ALS640 2TB (SAS-600 Interface) (5/10)
HUS724020ALS641 2TB (SAS-600 Interface, Encryption) (5/10)
HUA722050CLA330 500GB (1/2)
HUA722050CLA331 (Encryption) 500GB (1/2)
HUA722010CLA330 1TB (2/4)
HUA722010CLA331 (Encryption) 1TB (2/4)
600GB/platter Section (all drives under here use platters that can hold 600GB of data apiece.)
HUA723030ALA640 3TB (SATA-600 Interface) (5/10)
HUA723030ALA641 3TB (SATA-600 Interface, Encryption) (5/10)
HUS723030ALS640 3TB (SAS-600 Interface) (5/10)
HUS723030ALS641 3TB (SAS-600 Interface, Encryption) (5/10)
HUA5C3030ALA640 3TB (5/10)
HUA5C3030ALA641 3TB (Encryption) (5/10)
HUS724030ALA640 3TB (SATA-600 Interface) (5/10)
HUS724030ALE640 3TB (SATA-600 Interface) (5/10)
HUS724030ALE641 3TB (SATA-600 Interface, Encryption) (5/10)
HUS724030ALS640 3TB (SAS-600 Interface) (5/10)
HUS724030ALS641 3TB (SAS-600 Interface, Encryption) (5/10)
Deskstar NAS (7200RPM, 64MB cache, SATA-600 interface)
HDN724030ALE640 3TB (5/10)
HUS724040ALA640 4TB (SATA-600 Interface) (5/10)
HUS724040ALE640 4TB (SATA-600 Interface) (5/10)
HUS724040ALE641 4TB (SATA-600 Interface, Encryption) (5/10)
HUS724040ALS640 4TB (SAS-600 Interface) (5/10)
HUS724040ALS641 4TB (SAS-600 Interface, Encryption) (5/10)
HDN724040ALE640 4TB (5/10)
MegaScale 4000 (5700RPM, 64MB cache, SATA-600 interface)
HMS5C4040ALE640 4TB (5/10)
MegaScale DC 4000.B (5700RPM, 64MB cache, SATA-600 interface)
HMS5C4040BLE640 4TB (5/10)
HMS5C4040BLE641 (Encryption) 4TB (5/10)
Deskstar NAS (7200RPM, 128MB cache, SATA-600 interface)
HDN726050ALE610 5TB (5/10)
1.2TB/platter Section (all drives under here use platters that can hold 1.2TB of data apiece.)
Ultrastar 7K6000 (7200RPM, 128MB cache, SATA-600 interface)
HUS726060ALE610 6TB (512K Sector Emu) (5/10)
HUS726060ALN610 6TB (4K Sectors) (5/10)
HUS726060ALE611 6TB (512K Sector Emu, BDE) (5/10)
HUS726060ALN611 6TB (4K Sectors, BDE) (5/10)
HUS726060ALE614 6TB (512K Sector Emu, Secure Erase) (5/10)
HUS726060ALN614 6TB (4K Sectors, Secure Erase) (5/10)
Ultrastar 7K6000 (7200RPM, 128MB cache, SAS-1200 interface)
HUS726060AL5210 6TB (512K Sector Emu) (5/10)
HUS726060AL4210 6TB (4K Sectors) (5/10)
HUS726060AL5211 6TB (512K Sector Emu, TCG SED) (5/10)
HUS726060AL4211 6TB (4K Sectors, TCG SED) (5/10)
HUS726060AL5214 6TB (512K Sector Emu, Secure Erase) (5/10)
HUS726060AL4214 6TB (4K Sectors, Secure Erase) (5/10)
HUS726060AL5215 6TB (512K Sector Emu, TCG+FIPS BDE) (5/10)
HUS726060AL4215 6TB (4K Sectors, TCG+FIPS BDE) (5/10)
HDN726060ALE610 6TB (5/10)
HGST Legacy DK23xx Series
DK23AA (4200RPM, 512KB cache, ATA-66 interface)
DK23AA-60 6GB (1/2)
DK23AA-90 9GB (2/3)
DK23AA-12 12GB (2/4)
DK23BA (4200RPM, 512KB [20GB: 2MB] cache, ATA-66 interface)
DK23BA-60 6GB (1/2 [short-stroked])
DK23BA-10 10GB (1/2)
DK23BA-20 20GB (2/4)
DK23CA (4200RPM, 512KB [20 & 30GB: 2MB] cache, ATA-100 interface)
DK23CA-75 7.5GB (1/1)
DK23CA-10 10GB (1/2 [short-stroked])
DK23CA-15 15GB (1/2)
DK23CA-20 20GB (2/3 [short-stroked])
DK23CA-30 30GB (2/4)
DK23DA (4200RPM, 2MB cache, ATA-100 interface)
DK23DA-10F 10GB (1/1)
DK23DA-20F 20GB (1/2)
DK23DA-30F 30GB (2/3)
DK23DA-40F 40GB (2/4)
DK23EB (5400RPM, 2MB cache, ATA-100 interface)
DK23EB-20 20GB (1/2)
DK23EB-40 40GB (2/4)
Endurastar N4K20/DK23FA-20N (4200RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HTA422020F9ATN0/DK23FA-20N 20GB (1/2)
Endurastar J4K20/DK23FA-20J (4200RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HTA422020F9ATJ0/DK23FA-20J 20GB (1/2)
DK23EA (4200RPM, 2MB cache, ATA-100 interface)
DK23EA-20 20GB (1/2 [short-stroked])
DK23EA-30 30GB (1/2)
DK23EA-40 40GB (2/3 [short-stroked])
DK23EA-60 60GB (2/4)
DK23FB (5400RPM, 8MB cache, ATA-100 interface)
DK23FB-20 20GB (1/2 [short-stroked])
DK23FB-40 40GB (2/3 [short-stroked])
DK23FB-60 60GB (2/4)
Travelstar 4K80/DK23FA (4200RPM, 2MB [60 & 80GB: 8MB) cache, ATA-100 interface)
HTS428030F9AT00/DK23FA-30 30GB (1/2 [short-stroked])
HTS428040F9AT00/DK23FA-40 40GB (1/2)
HTS428060F9AT00/DK23FA-60 60GB (2/3)
HTS428080F9AT00/DK23FA-80 80GB (2/4)
Note: these are Hitachi's last in-house notebook drives. After acquiring IBM's drive business, these were re-branded as the Travelstar 4K80 series, and subsequent Hitachi-branded drives (starting with the Travelstar 80GN and 5K80) were designed by IBM's Travelstar team.
HGST Travelstar Cinemastar Endurastar
30GB/platter Section (all drives under here use platters that can hold 30GB of data.)
Travelstar 7K60 (7200RPM, 8MB cache, ATA-100 interface)
HTS726060M9AT00 60GB (2/4)
Travelstar E7K60 (7200RPM, 8MB cache, ATA-100 interface, for 24/7 constant use)
HTE726040M9AT00 40GB (2/4 [short-stroked])
HTE726060M9AT00 60GB (2/4)
Endurastar J4K30 (4172RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HEJ423020F9AT00 20GB (1/2 [short-stroked])
HEJ423030F9AT00 30GB (1/2)
Endurastar N4K30 (4172RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HEN423020F9AT00 20GB (1/2 [short-stroked])
HEN423030F9AT00 30GB (1/2)
40GB/platter Section (all drives under here use platters that can hold 40GB of data.)
Travelstar 80GN (4200RPM, 8MB [20 & 40GB: 2MB] cache, ATA-100 interface)
IC25N020ATMR04 20GB (1/1)
IC25N040ATMR04 40GB (1/2)
IC25N060ATMR04 60GB (2/3)
IC25N080ATMR04 80GB (2/4)
Note: these came out shortly after the IBM drive division acquisition, so they use IBM's old model numbering system.
Travelstar 5K80 (5400RPM, 8MB cache, ATA-100 interface)
HTS548020M9AT00 20GB (1/1)
HTS548040M9AT00 40GB (1/2)
HTS548060M9AT00 60GB (2/3)
HTS548080M9AT00 80GB (2/4)
Travelstar 4K40 (4200RPM, 2MB cache, ATA-100 interface)
HTS424020M9AT00 20GB (1/1)
HTS424030M9AT00 30GB (1/2 [short-stroked])
HTS424040M9AT00 40GB (1/2)
Note: the Hitachi datasheet says, "Based on proven technology of Travelstar 80GN and Travelstar 4K80", and "The Travelstar 4K40 is based on an industry leading design that has been made even better."
50GB/platter Section (all drives under here use platters that can hold 50GB of data.)
Travelstar 5K100 (5400RPM, 8MB cache, ATA-100 interface)
HTS541040G9AT00 40GB (1/2 [short-stroked])
HTS541060G9AT00 60GB (2/3 [short-stroked])
HTS541080G9AT00 80GB (2/4 [short-stroked])
HTS541010G9AT00 100GB (2/4)
Travelstar 5K100 (5400RPM, 8MB cache, SATA-150 interface)
HTS541040G9SA00 40GB (1/2 [short-stroked])
HTS541060G9SA00 60GB (2/3 [short-stroked])
HTS541080G9SA00 80GB (2/4 [short-stroked])
HTS541010G9SA00 100GB (2/4)
Travelstar E5K100 (5400RPM, 8MB cache, ATA-100 interface, for 24/7 constant use)
HTE541040G9AT00 40GB (1/2 [short-stroked])
Travelstar E5K100 (5400RPM, 8MB cache, SATA-150 interface, for 24/7 constant use)
HTE541040G9SA00 40GB (1/2 [short-stroked])
Travelstar 7K100 (7200RPM, 8MB cache, ATA-100 interface)
HTS721060G9AT00 60GB (2/3 [short-stroked])
HTS721080G9AT00 80GB (2/4 [short-stroked])
HTS721010G9AT00 100GB (2/4)
Travelstar 7K100 (7200RPM, 8MB cache, SATA-150 interface)
HTS721060G9SA00 60GB (2/3 [short-stroked])
HTS721080G9SA00 80GB (2/4 [short-stroked])
HTS721010G9SA00 100GB (2/4)
Travelstar E7K100 (7200RPM, 8MB cache, ATA-100 interface, for 24/7 constant use)
HTE721060G9AT00 60GB (2/3 [short-stroked])
HTE721080G9AT00 80GB (2/4 [short-stroked])
HTE721010G9AT00 100GB (2/4)
Travelstar E7K100 (7200RPM, 8MB cache, SATA-150 interface, for 24/7 constant use)
HTE721060G9SA00 60GB (2/3 [short-stroked])
HTE721080G9SA00 80GB (2/4 [short-stroked])
HTE721010G9SA00 100GB (2/4)
Endurastar J4K50 (4260RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HEJ425030F9AT00 30GB (1/2 [short-stroked])
HEJ425040F9AT00 40GB (1/2 [short-stroked])
HEJ425050F9AT00 50GB (1/2)
Endurastar N4K50 (4260RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HEN425030F9AT00 30GB (1/2 [short-stroked])
HEN425040F9AT00 40GB (1/2 [short-stroked])
HEN425050F9AT00 50GB (1/2)
60GB/platter Section (all drives under here use platters that can hold 60GB of data.)
Travelstar 4K120 (4200RPM, 8MB [40 & 60GB: 2MB] cache, ATA-100 interface)
HTS421240H9AT00 40GB (1/2 [short-stroked])
HTS421260H9AT00 60GB (1/2)
HTS421280H9AT00 80GB (2/3 [short-stroked])
HTS421210H9AT00 100GB (2/4 [short-stroked])
HTS421212H9AT00 120GB (2/4)
Travelstar 5K120 (5400RPM, 8MB cache, ATA-100 interface)
HTS541260H9AT00 60GB (1/2)
HTS541280H9AT00 80GB (2/3 [short-stroked])
HTS541210H9AT00 100GB (2/4 [short-stroked])
HTS541212H9AT00 120GB (2/4)
Travelstar 5K120 (5400RPM, 8MB cache, SATA-150 interface)
HTS541260H9SA00 60GB (1/2)
HTS541280H9SA00 80GB (2/3 [short-stroked])
HTS541210H9SA00 100GB (2/4 [short-stroked])
HTS541212H9SA00 120GB (2/4)
80GB/platter Section (all drives under here use platters that can hold 80GB of data.)
Travelstar 5K160 (5400RPM, 8MB cache, ATA-100 interface)
HTS541640J9AT00 40GB (1/1)
HTS541660J9AT00 60GB (1/2 [short-stroked])
HTS541680J9AT00 80GB (1/2)
HTS541612J9AT00 120GB (2/3)
HTS541616J9AT00 160GB (2/4)
Travelstar 5K160 (5400RPM, 8MB cache, SATA-150 interface)
HTS541640J9SA00 40GB (1/1)
HTS541660J9SA00 60GB (1/2 [short-stroked])
HTS541680J9SA00 80GB (1/2)
HTS541612J9SA00 120GB (2/3)
HTS541616J9SA00 160GB (2/4)
Travelstar E5K160 (5400RPM, 8MB cache, ATA-100 interface, for 24/7 constant use)
HTE541660J9AT00 60GB (1/2 [short-stroked])
HTE541680J9AT00 80GB (1/2)
HTE541612J9AT00 120GB (2/3)
HTE541616J9AT00 160GB (2/4)
Travelstar E5K160 (5400RPM, 8MB cache, SATA-150 interface, for 24/7 constant use)
HTE541660J9SA00 60GB (1/2 [short-stroked])
HTE541680J9SA00 80GB (1/2)
HTE541612J9SA00 120GB (2/3)
HTE541616J9SA00 160GB (2/4)
Cinemastar C5K160 (5400RPM, 8MB cache, SATA-150 interface, for CE applications)
HCC541680J9SA00 80GB (1/2)
HCC541616J9SA00 160GB (2/4)
100GB/platter Section (all drives under here use platters that can hold 100GB of data.)
Travelstar 7K200 (7200RPM, 16MB cache, SATA-300 interface)
HTS722080K9A300 80GB (1/2 [short-stroked])
HTS722010K9A300 100GB (1/2)
HTS722012K9A300 120GB (2/3 [short-stroked])
HTS722016K9A300 160GB (2/4 [short-stroked])
HTS722020K9A300 200GB (2/4)
Travelstar 7K200 (7200RPM, 16MB cache, SATA-150 interface)
HTS722080K9SA00 80GB (1/2 [short-stroked])
HTS722010K9SA00 100GB (1/2)
HTS722012K9SA00 120GB (2/3 [short-stroked])
HTS722016K9SA00 160GB (2/4 [short-stroked])
HTS722020K9SA00 200GB (2/4)
Travelstar E7K200 (7200RPM, 16MB cache, SATA-300 interface, for 24/7 constant use)
HTE722012K9A300 120GB (2/3 [short-stroked])
HTE722016K9A300 160GB (2/4 [short-stroked])
HTE722020K9A300 200GB (2/4)
Endurastar J4K100 (4260RPM, 8MB cache, SATA-150 interface, Extreme Environment)
HEJ421080G9SA00 80GB (1/2 [short-stroked])
HEJ421010G9SA00 100GB (1/2)
Endurastar J4K100 (4260RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HEJ421040G9AT00 40GB (1/1 [short-stroked])
HEJ421080G9AT00 80GB (1/2 [short-stroked])
HEJ421010G9AT00 100GB (1/2)
Endurastar N4K100 (4260RPM, 8MB cache, ATA-100 interface, Extreme Environment)
HEN421040G9AT00 40GB (1/1 [short-stroked])
HEN421080G9AT00 80GB (1/2 [short-stroked])
HEN421010G9AT00 100GB (1/2)
120GB/platter Section (all drives under here use platters that can hold 120GB of data.)
Travelstar 5K250 (5400RPM, 8MB cache, SATA-300 interface)
HTS542580K9A300 80GB (1/2 [short-stroked])
HTS542512K9A300 120GB (1/2)
HTS542516K9A300 160GB (2/3 [short-stroked])
HTS542520K9A300 200GB (2/4 [short-stroked])
HTS542525K9A300 250GB (2/4)
Travelstar 5K250 (5400RPM, 8MB cache, SATA-150 interface)
HTS542580K9SA00 80GB (1/2 [short-stroked])
HTS542512K9SA00 120GB (1/2)
HTS542516K9SA00 160GB (2/3 [short-stroked])
HTS542520K9SA00 200GB (2/4 [short-stroked])
HTS542525K9SA00 250GB (2/4)
Travelstar E5K250 (5400RPM, 8MB cache, SATA-300 interface, for 24/7 constant use)
HTE542580K9A300 80GB (1/2 [short-stroked])
HTE542512K9A300 120GB (1/2)
HTE542516K9A300 160GB (2/3 [short-stroked])
HTE542525K9A300 250GB (2/4)
Cinemastar C5K250 (5400RPM, 8MB cache, SATA-150 interface, for CE applications)
HCC542580K9SA00 80GB (1/2 [short-stroked])
HCC542512K9SA00 120GB (1/2)
HCC542516K9SA00 160GB (2/3 [short-stroked])
HCC542525K9SA00 250GB (2/4)
160-167GB/platter Section (all drives under here use platters that can hold 160-167GB of data.)
Travelstar 5K320 (5400RPM, 8MB cache, SATA-300 interface)
HTS543280L9A300 80GB (1/1)
HTS543212L9A300 120GB (1/2 [short-stroked])
HTS543216L9A300 160GB (1/2)
HTS543225L9A300 250GB (2/4 [short-stroked])
HTS543232L9A300 320GB (2/4)
Travelstar 5K320 (5400RPM, 8MB cache, SATA-150 interface)
HTS543280L9SA00 80GB (1/1)
HTS543212L9SA00 120GB (1/2 [short-stroked])
HTS543216L9SA00 160GB (1/2)
HTS543225L9SA00 250GB (2/4 [short-stroked])
HTS543232L9SA00 320GB (2/4)
Travelstar 5K320 BDE (5400RPM, 8MB cache, SATA-300 interface, Bulk Data Encryption)
HTS543280L9SA01 80GB (1/1)
HTS543212L9SA01 120GB (1/2 [short-stroked])
HTS543216L9SA01 160GB (1/2)
HTS543225L9SA01 250GB (2/4 [short-stroked])
HTS543232L9SA01 320GB (2/4)
Travelstar 5K320 EA 24/7 (5400RPM, 8MB cache, SATA-300 interface, for 24/7 constant use)
HTE543212L9A300 120GB (1/2 [short-stroked])
HTE543216L9A300 160GB (1/2)
HTE543225L9A300 250GB (2/4 [short-stroked])
HTE543232L9A300 320GB (2/4)
Travelstar 7K320 (7200RPM, 16MB cache, SATA-300 interface)
HTS723280L9A360 80GB (1/1)
HTS723212L9A360 120GB (1/2 [short-stroked])
HTS723216L9A360 160GB (1/2)
HTS723225L9A360 250GB (2/4 [short-stroked])
HTS723232L9A360 320GB (2/4)
Travelstar 7K320 BDE (7200RPM, 16MB cache, SATA-300 interface, Bulk Data Encryption)
HTS723280L9SA61 80GB (1/1)
HTS723212L9SA61 120GB (1/2 [short-stroked])
HTS723216L9SA61 160GB (1/2)
HTS723225L9SA61 250GB (2/4 [short-stroked])
HTS723232L9SA61 320GB (2/4)
Travelstar 7K320 EA 24/7 (7200RPM, 16MB cache, SATA-300 interface, for 24/7 constant use)
HTE723212L9A300 120GB (1/2 [short-stroked])
HTE723216L9A300 160GB (1/2)
HTE723225L9A300 250GB (2/4 [short-stroked])
HTE723232L9A300 320GB (2/4)
Travelstar 5K500 (5400RPM, 8MB cache, SATA-300 interface, 12.5mm z-height)
HTS545040KTA300 400GB (3/5)
HTS545050KTA300 500GB (3/6)
Travelstar 5K500 BDE (5400RPM, 8MB cache, SATA-150 interface, 12.5mm z-height, Bulk Data Encryption)
HTS545040KTSA01 400GB (3/5)
HTS545050KTSA01 500GB (3/6)
Travelstar E5K500 (5400RPM, 8MB cache, SATA-300 interface, 12.5mm z-height, for 24/7 constant use)
HTE545040KTA300 400GB (3/5)
HTE545050KTA300 500GB (3/6)
Cinemastar C5K320 (5400RPM, 8MB cache, SATA-300 interface, for CE applications)
HCC543212L9SA00 120GB (1/2 [short-stroked])
HCC543216L9SA00 160GB (1/2)
HCC543225L9SA00 250GB (2/4 [short-stroked])
HCC543232L9SA00 320GB (2/4)
250GB/platter Section (all drives under here use platters that can hold 250GB of data.)
Travelstar 5K500.B (5400RPM, 8MB cache, SATA-300 interface)
HTS545012B9A300 120GB (1/1)
HTS545016B9A300 160GB (1/2 [short-stroked])
HTS545025B9A300 250GB (1/2)
HTS545032B9A300 320GB (2/3 [short-stroked])
HTS545040B9A300 400GB (2/4 [short-stroked])
HTS545050B9A300 500GB (2/4)
Travelstar 5K500.B BDE (5400RPM, 8MB cache, SATA-300 interface, Bulk Data Encryption)
HTS545012B9A301 120GB (1/1)
HTS545016B9A301 160GB (1/2 [short-stroked])
HTS545025B9A301 250GB (1/2)
HTS545032B9A301 320GB (2/3 [short-stroked])
HTS545040B9A301 400GB (2/4 [short-stroked])
HTS545050B9A301 500GB (2/4)
Travelstar 5K500.B EA 24/7 (5400RPM, 8MB cache, SATA-300 interface, for 24/7 constant use)
HTE545016B9A300 160GB (1/2 [short-stroked])
HTE545025B9A300 250GB (1/2)
HTE545032B9A300 320GB (2/3 [short-stroked])
HTE545050B9A300 500GB (2/4)
Travelstar 7K500 (7200RPM, 16MB cache, SATA-300 interface)
HTS725012A9A364 120GB (1/1)
HTS725016A9A364 160GB (1/2 [short-stroked])
HTS725025A9A364 250GB (1/2)
HTS725032A9A364 320GB (2/3 [short-stroked])
HTS725050A9A364 500GB (2/4)
Travelstar 7K500 BDE (7200RPM, 16MB cache, SATA-300 interface, Bulk Data Encryption)
HTS725012A9A361 120GB (1/1)
HTS725016A9A361 160GB (1/2 [short-stroked])
HTS725025A9A361 250GB (1/2)
HTS725032A9A361 320GB (2/3 [short-stroked])
HTS725050A9A361 500GB (2/4)
Travelstar 7K500 EA 24/7 (7200RPM, 16MB cache, SATA-300 interface, for 24/7 constant use)
HTE725016A9A364 160GB (1/2 [short-stroked])
HTE725025A9A364 250GB (1/2)
HTE725032A9A364 320GB (2/3 [short-stroked])
HTE725050A9A364 500GB (2/4)
Travelstar 5K750 (5400RPM, 8MB cache, SATA-300 interface)
HTS547550A9E384 500GB (2/4)
Travelstar 5K750 BDE (5400RPM, 8MB cache, SATA-300 interface, Bulk Data Encryption)
HTS547550A9E385 500GB (2/4)
Travelstar 5K750 EA 24/7 (5400RPM, 8MB cache, SATA-300 interface, for 24/7 constant use)
HTE547550A9E384 500GB (2/4)
Travelstar 7K750 (7200RPM, 16MB cache, SATA-300 interface)
HTS727550A9E364 500GB (2/4)
Travelstar 7K750 BDE (7200RPM, 16MB cache, SATA-300 interface, Bulk Data Encryption)
HTS727550A9E365 500GB (2/4)
Travelstar 7K750 EA 24/7 (7200RPM, 16MB cache, SATA-300 interface, for 24/7 constant use)
HTE727550A9E364 500GB (2/4)
Cinemastar C5K500 (5400RPM, 8MB cache, SATA-300 interface, for CE applications)
HCC545016B9A300 160GB (1/2 [short-stroked])
HCC545025B9A300 250GB (1/2)
HCC545032B9A300 320GB (2/3 [short-stroked])
HCC545050B9A300 500GB (2/4)
320-375GB/platter Section (all drives under here use platters that can hold 320-375GB of data.)
HTS547564A9E384 640GB (2/4)
HTS547575A9E384 750GB (2/4)
HTS547564A9E385 640GB (2/4)
HTS547575A9E385 750GB (2/4)
HTE547564A9E384 640GB (2/4)
HTE547575A9E384 750GB (2/4)
HTS727564A9E364 640GB (2/4)
HTS727575A9E364 750GB (2/4)
HTS727564A9E365 640GB (2/4)
HTS727575A9E365 750GB (2/4)
HTE727564A9E364 640GB (2/4)
HTE727575A9E364 750GB (2/4)
Travelstar Z5K320 (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm)
HTS543216A7A384 160GB (1/1)
HTS543225A7A384 250GB (1/2 [short-stroked])
HTS543232A7A384 320GB (1/2)
Travelstar Z5K320 BDE (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm, Bulk Data Encryption)
HTS543216A7A385 160GB (1/1)
HTS543225A7A385 250GB (1/2 [short-stroked])
HTS543232A7A385 320GB (1/2)
Travelstar Z5K320 EA 24/7 (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm, for 24/7 constant use)
HTE543225A7A384 250GB (1/2 [short-stroked])
HTE543232A7A384 320GB (1/2)
Travelstar Z7K320 (7200RPM, 16MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm)
HTS723216A7A364 160GB (1/1)
HTS723225A7A364 250GB (1/2 [short-stroked])
HTS723232A7A364 320GB (1/2)
Travelstar Z7K320 BDE (7200RPM, 16MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm, Bulk Data Encryption)
HTS723216A7A365 160GB (1/1)
HTS723225A7A365 250GB (1/2 [short-stroked])
HTS723232A7A365 320GB (1/2)
Travelstar Z7K320 EA 24/7 (7200RPM, 16MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm, for 24/7 constant use)
HTE723225A7A364 250GB (1/2 [short-stroked])
HTE723232A7A364 320GB (1/2)
CinemaStar Z5K320 (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm, for CE applications)
HCC543216A7A380 160GB (1/1)
HCC543225A7A380 250GB (1/2 [short-stroked])
HCC543232A7A380 320GB (1/2)
Travelstar 5K1000 (5400RPM, 8MB cache, SATA-600 interface)
HTS541064A9E680 640GB (2/4)
HTS541075A9E680 750GB (2/4)
Travelstar 5K1000 BDE (5400RPM, 8MB cache, SATA-600 interface, Bulk Data Encryption)
HTS541064A9E681 640GB (2/4)
HTS541075A9E681 750GB (2/4)
Travelstar 5K1000 EA 24/7 (5400RPM, 8MB cache, SATA-600 interface, for 24/7 constant use)
HTE541064A9E680 640GB (2/4)
HTE541075A9E680 750GB (2/4)
Travelstar 7K1000 (7200RPM, 32MB cache, SATA-600 interface)
HTS721075A9E630 750GB (2/4)
Travelstar 7K1000 BDE (7200RPM, 32MB cache, SATA-600 interface, Bulk Data Encryption)
HTS721075A9E631 750GB (2/4)
Endurastar J4K320 (4260RPM, 8MB cache, SATA-150 interface, Extreme Environment)
HEJ423280H9E300 80GB (1/1 [short-stroked])
HEJ423210H9E300 100GB (1/1 [short-stroked])
HEJ423220H9E300 200GB (1/2 [short-stroked])
HEJ423225H9E300 250GB (1/2 [short-stroked])
HEJ423232H9E300 320GB (1/2)
500GB/platter Section (all drives under here use platters that can hold 500GB of data.)
Travelstar Z5K500 (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm)
HTS545025A7E380 250GB (1/1)
HTS545032A7E380 320GB (1/2 [short-stroked])
HTS545050A7E380 500GB (1/2)
Travelstar Z5K500 BDE (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm, Bulk Data Encryption)
HTS545025A7E381 250GB (1/1)
HTS545032A7E381 320GB (1/2 [short-stroked])
HTS545050A7E381 500GB (1/2)
Travelstar Z5K500 EA 24/7 (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height instead of 9.5mm, for 24/7 constant use)
HTE545032A7E380 320GB (1/2 [short-stroked])
HTE545050A7E380 500GB (1/2)
Travelstar Z5K500 (5400RPM, 8MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm)
HTS545025A7E680 250GB (1/1)
HTS545032A7E680 320GB (1/2 [short-stroked])
HTS545050A7E680 500GB (1/2)
Travelstar Z5K500 BDE (5400RPM, 8MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, Bulk Data Encryption)
HTS545025A7E681 250GB (1/1)
HTS545032A7E681 320GB (1/2 [short-stroked])
HTS545050A7E681 500GB (1/2)
Travelstar Z5K500 w/ TCG Opal (5400RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, TCG Opal Encryption)
HTS545025A7E685 250GB (1/1)
HTS545032A7E685 320GB (1/2 [short-stroked])
HTS545050A7E685 500GB (1/2)
Travelstar Z5K500 EA 24/7 (5400RPM, 8MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, for 24/7 constant use)
HTE545032A7E680 320GB (1/2 [short-stroked])
HTE545050A7E680 500GB (1/2)
Travelstar Z7K500 (7200RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm)
HTS725025A7E630 250GB (1/1)
HTS725032A7E630 320GB (1/2 [short-stroked])
HTS725050A7E630 500GB (1/2)
Travelstar Z7K500 BDE (7200RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, Bulk Data Encryption)
HTS725025A7E631 250GB (1/1)
HTS725032A7E631 320GB (1/2 [short-stroked])
HTS725050A7E631 500GB (1/2)
Travelstar Z7K500 w/ TCG Opal (7200RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, TCG Opal Encryption)
HTS725025A7E635 250GB (1/1)
HTS725032A7E635 320GB (1/2 [short-stroked])
HTS725050A7E635 500GB (1/2)
Travelstar Z7K500 EA 24/7 (7200RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, for 24/7 constant use)
HTE725032A7E630 320GB (1/2 [short-stroked])
HTE725050A7E630 500GB (1/2)
HTS541010A9E680 1TB (2/4)
HTS541010A9E681 1TB (2/4)
HTE541010A9E680 1TB (2/4)
HTS721010A9E630 1TB (2/4)
HTS721010A9E631 1TB (2/4)
Travelstar 7K1000 EA 24/7 (7200RPM, 32MB cache, SATA-600 interface, for 24/7 constant use)
HTE721010A9E630 1TB (2/4)
Travelstar 5K1500 (5400RPM, 32MB cache, SATA-600 interface, three platters in 9.5mm z-height)
HTS541515A9E630 1.5TB (3/6)
Travelstar 5K1500 BDE (5400RPM, 32MB cache, SATA-600 interface, three platters in 9.5mm z-height, Bulk Data Encryption)
HTS541515A9E631 1.5TB (3/6)
Travelstar 5K1500 w/ TCG Opal (5400RPM, 32MB cache, SATA-600 interface, three platters in 9.5mm z-height, TCG Opal Encryption)
HTS541515A9E635 1.5TB (3/6)
Travelstar 5K1500 EA 24/7 (5400RPM, 32MB cache, SATA-600 interface, three platters in 9.5mm z-height, for 24/7 constant use)
HTE541515A9E630 1.5TB (3/6)
Travelstar Z5K1000 (5400RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm)
HTS541075A7E630 750GB (2/3)
HTS541010A7E630 1TB (2/4)
Travelstar Z5K1000 BDE (5400RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, Bulk Data Encryption)
HTS541075A7E631 750GB (2/3)
HTS541010A7E631 1TB (2/4)
Travelstar Z5K1000 w/ TCG Opal (5400RPM, 32MB cache, SATA-600 interface, 7mm z-height instead of 9.5mm, TCG Opal Encryption)
HTS541075A7E635 750GB (2/3)
HTS541010A7E635 1TB (2/4)
60GB/platter Section (all drives under here use platters that can hold 60GB of data apiece.)
Fireball 3 (5400RPM, 2MB cache, ATA-133 interface)
2F030J0 (Ball bearing) 30GB (1/1)
2F030L0 (FDB bearing) 30GB (1/1)
DiamondMax Plus 8 (7200RPM, 2MB cache, ATA-133 interface)
6E030L0 30GB (1/1)
DiamondMax Plus 9 (7200RPM, ATA-133 interface)
6Y080L0 (2MB Cache) 80GB (2/3 [short-stroked])*
*Note: a "4" as the second character of the serial number identifies a double-platter 6Y080L0.
2F020J0 (Ball bearing) 20GB (1/1 [short-stroked])
2F020L0 (FDB bearing) 20GB (1/1 [short-stroked])
2F040J0 (Ball bearing) 40GB (1/1)
2F040L0 (FDB bearing) 40GB (1/1)
6E020L0 20GB (1/1 [short-stroked])
6E040L0 40GB (1/1)
6K040L0 (RoHS Compliant) 40GB (1/1)
Note: hundreds of thousands of billions of these things were placed in bottom-of-the-barrel PCs from mom-and-pop shops between 2003-2006. I've got a stack of them, myself; a few still work perfectly (as of 2015), others were dead when pulled.
DiamondMax 8S (7200RPM, 2MB cache, SATA-150 interface)
6E040T0 40GB (1/1)
6N040T0 (RoHS Compliant) 40GB (1/1)
6Y060L0 (2MB Cache) 60GB (1/2 [short-stroked])
6Y080L0 (2MB Cache) 80GB (1/2)*
6Y080P0 (8MB Cache) 80GB (1/2)
6Y120L0 (2MB Cache) 120GB (2/3)
6Y120P0 (8MB Cache) 120GB (2/3)
6Y160L0 (2MB Cache) 160GB (2/4)
6Y160P0 (8MB Cache) 160GB (2/4)
6Y200P0 (8MB Cache) 200GB (3/5)
6Y250P0 (8MB Cache) 250GB (3/6)
*Note: a "2" as the second character of the serial number identifies a single-platter 6Y080L0. I don't know if this also applies to the 6Y080P0 and 6Y080M0 models (let alone if those models were also, at all, produced at some point with 60GB platters, like the 6Y080L0 was).
DiamondMax Plus 9 (7200RPM, 8MB cache, SATA-150 interface)
6Y060M0 60GB (1/2 [short-stroked])
6Y080M0 80GB (1/2)
6Y120M0 120GB (2/3)
6Y160M0 160GB (2/4)
6Y200M0 200GB (3/5)
6Y250M0 250GB (3/6)
DiamondMax 16 (5400RPM, 2MB cache, ATA-133 interface)
4R040L0 (FDB bearing) 40GB (1/1)
4R060J0 (Ball bearing) 60GB (1/2 [short-stroked])
4R060L0 (FDB bearing) 60GB (1/2 [short-stroked])
4R080J0 (Ball bearing) 80GB (1/2)
4R080L0 (FDB bearing) 80GB (1/2)
4R120J0 (Ball bearing) 120GB (2/3)
4R120L0 (FDB bearing) 120GB (2/3)
4A160J0 (Ball bearing) 160GB (2/4)
4R160L0 (FDB bearing) 160GB (2/4)
4A250J0 (Ball bearing) 250GB (3/6)
MaXLine II (5400RPM, 2MB cache, ATA-133 interface, for 24/7 use applications)
5A250J0 (Ball bearing) 250GB (3/6)
MaXLine Plus II (7200RPM, 8MB cache, ATA-133 interface, for 24/7 use applications)
7Y180P0 180GB (3/5 [short-stroked])
7Y250P0 250GB (3/6)
MaXLine Plus II (7200RPM, 8MB cache, SATA-150 interface, for 24/7 use applications)
7Y250M0 250GB (3/6)
100-107GB/platter Section (all drives under here use platters that can hold 100-107GB of data apiece.)
4A300J0 (Ball bearing) 300GB (3/6)
DiamondMax 10 (7200RPM, ATA-133 interface)
6L080L0 (2MB Cache, RoHS Compliant) 80GB (1/2 [short-stroked])
6L080P0 (8MB Cache, RoHS Compliant) 80GB (1/2 [short-stroked])
6L100P0 (8MB Cache, RoHS Compliant) 100GB (1/2)
6L120P0 (8MB Cache, RoHS Compliant) 120GB (2/3 [short-stroked])
6B160P0 (8MB Cache) 160GB (2/4 [short-stroked])
6L160P0 (8MB Cache, RoHS Compliant) 160GB (2/4 [short-stroked])
6B200P0 (8MB Cache) 200GB (2/4)
6L200P0 (8MB Cache, RoHS Compliant) 200GB (2/4)
6B250R0 (16MB Cache) 250GB (3/5)
6L250R0 (16MB Cache, RoHS Compliant) 250GB (3/5)
6B300R0 (16MB Cache) 300GB (3/6)
6L300R0 (16MB Cache, RoHS Compliant) 300GB (3/6)
DiamondMax 10 (7200RPM, SATA-150 interface)
6B080M0 (8MB Cache) 80GB (1/2 [short-stroked])
6L080M0 (8MB Cache, RoHS Compliant) 80GB (1/2 [short-stroked])
6L100M0 (8MB Cache, RoHS Compliant) 100GB (1/2)
6B120M0 (8MB Cache) 120GB (2/3 [short-stroked])
6L120M0 (8MB Cache, RoHS Compliant) 120GB (2/3 [short-stroked])
6B160M0 (8MB Cache) 160GB (2/4 [short-stroked])
6L160M0 (8MB Cache, RoHS Compliant) 160GB (2/4 [short-stroked])
6B200M0 (8MB Cache) 200GB (2/4)
6L200M0 (8MB Cache, RoHS Compliant) 200GB (2/4)
6B250S0 (16MB Cache) 250GB (3/5)
6L250S0 (16MB Cache, RoHS Compliant) 250GB (3/5)
6B300S0 (16MB Cache) 300GB (3/6)
6L300S0 (16MB Cache, RoHS Compliant) 300GB (3/6)
DiamondMax 10 (7200RPM, SATA-300 interface)
6V080E0 (8MB Cache, RoHS Compliant) 80GB (1/2 [short-stroked])
6V160E0 (8MB Cache, RoHS Compliant) 160GB (2/4 [short-stroked])
6V200E0 (8MB Cache, RoHS Compliant) 200GB (2/4)
6V250F0 (16MB Cache, RoHS Compliant) 250GB (3/5)
6V300F0 (16MB Cache, RoHS Compliant) 300GB (3/6)
6V320F0 (16MB Cache, RoHS Compliant) 320GB (3/6)
DiamondMax 11 (7200RPM, 16MB cache, ATA-133 interface)
6H400R0 400GB (4/8)
DiamondMax 11 (7200RPM, 16MB cache, SATA-300 interface)
6H400F0 400GB (4/8)
5A300J0 (Ball bearing) 300GB (3/6)
MaXLine III (7200RPM, 16MB cache, ATA-133 interface, for 24/7 use applications)
7L250R0 250GB (3/5)
7L300R0 300GB (3/6)
MaXLine III (7200RPM, 16MB cache, SATA-150 interface, for 24/7 use applications)
7L250S0 250GB (3/5)
7L300S0 300GB (3/6)
7L320S0 320GB (3/6)
MaXLine III (7200RPM, 16MB cache, SATA-300 interface, for 24/7 use applications)
7V250F0 250GB (3/5)
7V300F0 300GB (3/6)
QuickView 400 (7200RPM, 16MB cache, SATA-300 interface, for AV applications)
3H400F0 400GB (4/8)
6H500R0 500GB (4/8)
6H500F0 500GB (4/8)
MaXLine Pro 500 (7200RPM, 16MB cache, ATA-133 interface, for 24/7 use applications)
7H500R0 500GB (4/8)
MaXLine Pro 500 (7200RPM, 16MB cache, SATA-300 interface, for 24/7 use applications)
7H500F0 500GB (4/8)
QuickView 500 (7200RPM, 16MB cache, SATA-300 interface, for AV applications)
3H500F0 500GB (4/8)
160GB/platter Section (all drives under here use platters that can hold 160GB of data apiece.)
DiamondMax 17 (7200RPM, ATA-133 interface)
6G080L0 (2MB Cache) 80GB (1/1)
6G160P0 (8MB Cache) 160GB (1/2)
6G250P0 (8MB Cache) 250GB (2/4 [short-stroked])
6G320P0 (8MB Cache) 320GB (2/4)
Note: the DiamondMax 17 series is Maxtor's last completely in-house-designed line before the Seagate buyout. Subsequent DiamondMax lines (21, 22, etc) are actually just Seagate Barracudas with the Maxtor logo on (as such, check the Seagate lists for those models).
DiamondMax 17 (7200RPM, 8MB cache, SATA-300 interface)
6G080E0 80GB (1/1)
6G160E0 160GB (1/2)
6G250E0 250GB (2/4 [short-stroked])
6G320E0 320GB (2/4)
Samsung 1,3 & 1,8
SpinPoint A1 (1.3") (3600RPM, 2MB cache, ZIF ATA/100 interface)
HU025HA 20GB (512k Sectors) (1/1)
HU020HA 20GB (1024k Sectors) (1/1)
HU035HA 30GB (512k Sectors) (1/2)
HU030HA 30GB (1024k Sectors) (1/2)
HU045HA 40GB (512k Sectors) (1/2)
HU040HA 40GB (1024k Sectors) (1/2)
SpinPoint A1 (1.3") (3600RPM, 2MB cache, CE ATA/100 interface)
HU035HP 30GB (512k Sectors) (1/2)
HU030HP 30GB (1024k Sectors) (1/2)
HU045HP 40GB (512k Sectors) (1/2)
HU040HP 40GB (1024k Sectors) (1/2)
SpinPoint A1 (1.3") (3600RPM, 2MB cache, USB 2.0 interface)
HU020HS 20GB (512k Sectors) (1/1)
HU030HS 30GB (512k Sectors) (1/2)
HU040HS 40GB (512k Sectors) (1/2)
SpinPoint N1 (4200RPM, 2MB cache, ZIF ATA/100 interface)
HS030GB 30GB (1/1)
HS040HB 40GB (1/2)
HS060HB 60GB (1/2)
SpinPoint N1C (5400RPM, 8MB cache, ZIF ATA/100 interface)
HS08XJC 80GB (2/3)
HS10XJC 100GB (2/4)
HS122JC 120GB (2/4)
SpinPoint N1C (5400RPM, 8MB cache, SATA-150 interface)
HS04XHF 40GB (1/2)
HS062HF 60GB (1/2)
HS08XJF 80GB (2/3)
HS10XJF 100GB (2/4)
HS122JF 120GB (2/4)
SpinPoint N2A (3600RPM, 2MB cache, ZIF ATA/100 interface)
HS031GA 30GB (1/1)
HS041HA 40GB (1/1)
HS061HA 60GB (1/2)
HS080HA 80GB (1/2)
HS081HA 80GB (1/2)
SpinPoint N2B (4200RPM, ZIF ATA/100 interface)
HS020GB 20GB (1/1) (2MB Cache)
HS030GB 30GB (1/1) (2MB Cache)
HS040HB 40GB (1/1) (2MB Cache)
HS04THB 40GB (1/1) (8MB Cache)
HS060HB 60GB (1/2) (2MB Cache)
HS06THB 60GB (1/2) (8MB Cache)
HS080HB 80GB (1/2) (2MB Cache)
HS081HB 80GB (1/2) (2MB Cache)
HS082HB 80GB (1/2) (8MB Cache)
HS083HB 80GB (1/2) (8MB Cache)
HS10TJB 100GB (2/3) (8MB Cache)
HS120JB 120GB (2/3) (2MB Cache)
HS122JB 120GB (2/3) (8MB Cache)
HS160JB 160GB (2/4) (2MB Cache)
HS161JB 160GB (2/4) (2MB Cache)
SpinPoint N2B (4200RPM, 2MB cache, CE ATA/100 interface)
HS03SHQ 30GB (1/1)
HS12UJQ 120GB (2/3)
HS161JQ* 160GB (2/4)
*Note: This model was used in the first-gen 160GB iPod Classics.
SpinPoint N2B (4200RPM, 2MB cache, USB 2.0 interface)
HS03SHR 30GB (1/1)
HS040HR 40GB (1/1)
HS040HY 40GB (1/1)
HS06SHR 60GB (1/2)
HS060HY 60GB (1/2)
HS080HR 80GB (1/2)
HS080HY 80GB (1/2)
HS120JR 120GB (2/3)
HS120JY 120GB (2/3)
SpinPoint N3C (5400RPM, 16MB cache, SATA-300 interface)
HS04VHF 40GB (1/1)
HS06VHF 60GB (1/2)
HS06RHF 60GB (Free Fall Sensor) (1/2)
HS08VHF 80GB (1/2)
HS08RHF 80GB (Free Fall Sensor) (1/2)
HS12VJF 120GB (2/3)
HS12RJF 120GB (Free Fall Sensor) (2/3)
HS16VJF 160GB (2/4)
HS16RJF 160GB (Free Fall Sensor) (2/4)
SpinPoint N3A (3600RPM, 8MB cache, ZIF ATA/100 interface)
HS06YHA 60GB (1/1)
HS08YHA 80GB (1/2)
HS12YHA 120GB (1/2)
SpinPoint N3B (4200RPM, 16MB cache, SATA-150 interface)
HS12UHE 120GB (1/2)
SpinPoint N3U-3 (3600RPM, 8MB cache, USB2.0 interface)
HS122HZ 120GB (1/2)
HS16??? 160GB (2/3)
HS20YJZ 200GB (2/4)
HS250JI 250GB (2/4) (?)
HS25YJZ 250GB (2/4)
There appear to be two 250GB models. (The HS25YJZ model is shown in the picture. HS250JI was found in some of the articles for the release.) The model number of the 160GB version is unknown.
Something tells me that these are lurking inside Samsung's S1 Mini external drives...
Samsung 2,5
SpinPoint M40 (5400RPM, 8MB cache, ATA/100 interface)
MP0201H 20GB (1/1)
MP0302H 30GB (1/2)
MP0402H 40GB (1/2)
MP0603H 60GB (2/3)
MP0804H 80GB (2/4)
SpinPoint M40S (5400RPM, 8MB cache, SATA-150 interface)
HM020GI 20GB (1/1)
HM030HI 30GB (1/2)
HM040HI 40GB (1/2)
HM060II 60GB (2/3)
HM080JI 80GB (2/4)
SpinPoint M60 (5400RPM, 8MB cache, ATA/100 interface)
HM020GC 20GB (1/1 [short-stroked])
HM030GC 30GB (1/1)
HM040HC 40GB (1/2 [short-stroked])
HM060HC 60GB (1/2)
HM080IC 80GB (2/3 [short-stroked])
HM100JC 100GB (2/4 [short-stroked])
HM120JC 120GB (2/4)
SpinPoint M60S (5400RPM, 8MB cache, SATA-150 interface)
HM021GI 20GB (1/1 [short-stroked])
HM030GI 30GB (1/1)
HM041HI 40GB (1/2 [short-stroked])
HM042HI 40GB (1/2 [short-stroked])
HM060HI 60GB (1/2)
HM061HI 60GB (1/2)
HM080II 80GB (2/3 [short-stroked])
HM081II 80GB (2/3 [short-stroked])
HM100JI 100GB (2/4 [short-stroked])
HM101JI 100GB (2/4 [short-stroked])
HM120JI 120GB (2/4)
HM121JI 120GB (2/4)
SpinPoint M80 (5400RPM, 8MB cache, ATA/100 interface)
HM040GC 40GB (1/1)
HM061HC 60GB (1/2 [short-stroked])
HM080HC 80GB (1/2)
HM100IC 100GB (2/3 [short-stroked])
HM120IC 120GB (2/3)
HM160JC 160GB (2/4)
SpinPoint M80S (5400RPM, 8MB cache, SATA-150 interface)
HM040GI 40GB (1/1)
HM041GI 40GB (1/1)
HM062HI 60GB (1/2 [short-stroked])
HM080HI 80GB (1/2)
HM081HI 80GB (1/2)
HM100II 100GB (2/3 [short-stroked])
HM120II 120GB (2/3)
HM121II 120GB (2/3)
HM160JI 160GB (2/4)
HM161JI 160GB (2/4)
SpinPoint MH80S (5400RPM, 8MB cache, 256MB hybrid cache, SATA-150 interface)
HM08HHI 80GB (1/2)
HM12HII 120GB (2/3)
HM16HJI 160GB (2/4)
SpinPoint MP2 (7200RPM, 16MB cache, SATA-300 interface)
HM080HJ 80GB (1/2)
HM081HJ (Free Fall Sensor) 80GB (1/2)
HM160JJ 160GB (2/4)
HM161JJ (Free Fall Sensor) 160GB (2/4)
100-125GB/platter Section (all drives under here use platters that can hold 100-125GB of data apiece.)
SpinPoint M5 (5400RPM, 8MB cache, ATA/100 interface)
HM250JC 250GB (2/4)
SpinPoint M5S (5400RPM, 8MB cache, SATA-150 interface)
HM201JI 200GB (2/4)
HM250JI 250GB (2/4)
HM100HJ 100GB (1/2)
HM101HJ (Free Fall Sensor) 100GB (1/2)
HM120HJ 120GB (1/2)
HM121HJ (Free Fall Sensor) 120GB (1/2)
HM200JJ 200GB (2/4)
HM201JJ (Free Fall Sensor) 200GB (2/4)
HM250JJ 250GB (2/4)
HM251JJ (Free Fall Sensor) 250GB (2/4)
HM061GC 60GB (1/1 [short-stroked])
HM080GC 80GB (1/1)
HM121HC 120GB (1/2 [short-stroked])
HM160HC/ST160LM005 160GB (1/2)
Samsung's storage division was taken over by Seagate. Since then, variations of some of these drives with Seagate model numbers (STxxxxLMxxx) have began to circulate. Aside from the new branding, I'm not sure if there's much physical difference.
HM061GI 60GB (1/1 [short-stroked])
HM080GI 80GB (1/1)
HM121HI 120GB (1/2 [short-stroked])
HM160HI 160GB (1/2)
SpinPoint M6 (5400RPM, 8MB cache, SATA-300 interface)
HM251JI 250GB (2/4 [short-stroked])
HM320JI 320GB (2/4)
SpinPoint M6S (5400RPM, 8MB cache, SATA-300 interface, three platters in a 9.5mm z-height)
HM400LI 400GB (3/5)
HM500LI 500GB (3/6)
SpinPoint MH6 (5400RPM, 8MB cache, 512MB hybrid cache, SATA-150 interface)
HM16HHI 160GB (1/2)
HM25HJI 250GB (2/4 [short-stroked])
HM32HJI 320GB (2/4)
SpinPoint MH6 (5400RPM, 8MB cache, 1GB hybrid cache, SATA-150 interface)
HM16GHI 160GB (1/2)
HM25GJI 250GB (2/4 [short-stroked])
HM32GJI 320GB (2/4)
SpinPoint MU-X (5400RPM, Mini-USB interface)
HM160HX 160GB (1/2)
HM251JX 250GB (2/4 [short-stroked])
HM320JX 320GB (2/4)
Note: these are M6 drives with what appears to be an internal SATA-USB bridge. The result is a mini-USB port and a small LED on the back where the SATA ports would be. I expect these to work seamlessly as external drives by themselves, or a company could use these in their external disk products and thus not need a chip to convert the SATA or IDE interface of the harddisk to USB 2.0, as the drive already has it integrated, lowering the price and physical size of the enclosure.
SpinPoint M7 (5400RPM, 8MB cache, SATA-300 interface)
HM120GI 120GB (1/1)
HM161HI 160GB (1/2 [short-stroked])
HM250HI/ST250LM000* 250GB (1/2)
HM320II 320GB (2/3 [short-stroked])
HM400JI 400GB (2/4 [short-stroked])
HM500JI/ST500LM001 500GB (2/4)
Note: Samsung's storage division was taken over by Seagate. Since then, variations of some of these drives with Seagate model numbers (STxxxxLMxxx) have began to circulate. Aside from the new branding, I'm not sure if there's much physical difference.
*Note 2: These share their Seagate-specific model number (ST250LM000) with the M7E HM251HI. Confusing, right?
SpinPoint M7U (5400RPM, Mini-USB interface)
HM162HX 160GB (1/2 [short-stroked])
HM252HX 250GB (1/2)
HM322IX 320GB (2/3 [short-stroked])
HM502JX 500GB (2/4)
Note: these are M7 drives with what appears to be an internal SATA-USB bridge. The result is a mini-USB port and a small LED on the back where the SATA ports would be.
320-334GB/platter Section (all drives under here use platters that can hold 320-334GB of data apiece.)
SpinPoint M7E (5400RPM, 8MB cache, SATA-300 interface)
HM161GI/ST160LM000 160GB (1/1)
HM251HI/ST250LM000* 250GB (1/2 [short-stroked])
HM321HI/ST320LM000 320GB (1/2)
HM501II/ST500LM011 500GB (2/4 [short-stroked])
HM641JI/ST640LM000 640GB (2/4)
*Note 2: These share their Seagate-specific model number (ST250LM000) with the M7 HM250HI. Confusing, right?
SpinPoint MP4 (7200RPM, 16MB cache, SATA-300 interface)
HM250HJ/ST250LM001 250GB (1/2 [short-stroked])
HM320HJ/ST320LM007 320GB (1/2)
HM500JJ/ST500LM019 500GB (2/4 [short-stroked])
HM640JJ/ST640LM016 640GB (2/4)
SpinPoint MT2 (5400RPM, 8MB cache, SATA-300 interface, three platters)
HM750LI 750GB (3/5 [short-stroked])
HM100UI 1TB (3/6)
SpinPoint M8 (5400RPM, 8MB cache, SATA-300 interface)
HN-M160MBB/ST160LM003 160GB (1/1 [short-stroked])
HN-M250MBB/ST250LM004 250GB (1/1)
HN-M320MBB/ST320LM001 320GB (1/2 [short-stroked])
HN-M500MBB/ST500LM012 500GB (1/2)
HN-M640MBB/ST640LM001 640GB (2/3 [short-stroked])
HN-M750MBB/ST750LM022 750GB (2/3)
HN-M101MBB/ST1000LM024 1TB (2/4)
SpinPoint M8U (5400RPM, 8MB cache, USB 2.0 interface)
HN-M250XBB/ST250LM006 (1/1)
HN-M320XBB/ST320LM008 (1/2 [short-stroked])
HN-M500XBB/ST500LM016 (1/2)
HN-M640XBB/ST640LM021 (2/3 [short-stroked])
HN-M750XBB/ST750LM024 (2/3)
HN-M101XBB/ST1000LM026 (2/4)
Note: these are M8 drives with what appears to be an internal SATA-USB bridge. The result is a mini-USB port and a small LED on the back where the SATA ports would be.
Note 2: Samsung's storage division was taken over by Seagate. Since then, variations of some of these drives with Seagate model numbers (STxxxxLMxxx) have began to circulate. Aside from the new branding, I'm not sure if there's much physical difference.
SpinPoint M8U (5400RPM, 8MB cache, USB 3.0 interface)
HN-M250ABB/ST250LM003 (1/1)
HN-M320ABB/ST320LM005 (1/2 [short-stroked])
HN-M500ABB/ST500LM014 (1/2)
HN-M640ABB/ST640LM019 (2/3 [short-stroked])
HN-M750ABB/ST750LM023 (2/3)
HN-M101ABB/ST1000LM025 (2/4)
SpinPoint M9T (5400RPM, 32MB cache, SATA-600 interface, three platters in a 9.5mm z-height)
HN-M151RAD/ST1500LM006 1.5TB (3/6)
HN-M151RAD/ST1500LM007 1.5TB (3/6)
HN-M151RAD/ST1500LM010 1.5TB (3/6)
Note: We're not sure yet what the differences between these models are.
SpinPoint M9TU (5400RPM, 32MB cache, USB 3.0 interface, three platters in a 9.5mm z-height)
HN-M151AAD/ST1500LM008 1.5TB (3/6)
Note: these are M9T drives with what appears to be an internal SATA-USB bridge. The result is a mini-USB port and a small LED on the back where the SATA ports would be.
SpinPoint D8X (7200RPM, 32MB cache, SATA-600 interface)
HN-M500SAD/ST500LM027 500GB (1/2)
HN-M101SAD/ST1000LM044 1TB (2/4)
Note: Seagate seems to be, for whatever reason, content to keep at least the 2.5"-focused part of Samsung's HDD design team alive. These are brand new models (as of June 2016) that carry Samsung SpinPoint branding and obvious physical similarities to past Samsung mobile drives.
667GB/platter Section (all drives under here use platters that can hold 667GB of data apiece.)
HN-M171RAD/ST1750LM000 1.75TB (3/6 [short-stroked])
HN-M201RAD/ST2000LM003 2TB (3/6)
HN-M201RAD/ST2000LM004 2TB (3/6)
HN-M201RAD/ST2000LM006 2TB (3/6)
Note: We're not sure yet what the differences between the latter three models are.
HN-M201AAD/ST2000LM005 2TB (3/6)
Samsung 3,5
SpinPoint P80 with ATA-133 Interface (7200RPM)
SP0211N 20GB (2MB cache) (1/1 [short-stroked])
SP0401N 40GB (2MB cache) (1/1)
SP0612N 60GB (2MB cache) (1/2 [short-stroked])
SP0802N 80GB (2MB cache) (1/2)
SP0812N 80GB (8MB cache) (1/2)
SP1203N 120GB (2MB cache) (2/3)
SP1213N 120GB (8MB cache) (2/3)
SP1604N 160GB (2MB cache) (2/4)
SP1614N 160GB (8MB cache) (2/4)
SpinPoint P80 with SATA-150 Interface (7200RPM, 8MB cache)
SP0812C 80GB (1/2)
SP1213C 120GB (2/3)
SP1614C 160GB (2/4)
SpinPoint P80SD with SATA-300 Interface (7200RPM, 8MB cache)
HD040GJ 40GB (1/1)
HD080HJ 80GB (1/2)
HD120IJ 120GB (2/3)
HD160JJ 160GB (2/4)
SpinPoint P80CE with ATA-133 Interface (7200RPM, for AV applications)
SP0842N/CE 80GB (2MB cache) (1/2)
SP1243N/CE 120GB (2MB cache) (2/3)
SP1253N/CE 120GB (8MB cache) (2/3)
SP1644N/CE 160GB (2MB cache) (2/4)
SP1654N/CE 160GB (8MB cache) (2/4)
SpinPoint V80 with ATA-133 Interface (5400RPM, 2MB cache)
SV0211N 20GB (1/1 [short-stroked])
SV0401N 40GB (1/1)
SV0612N 60GB (1/2 [short-stroked])
SV0802N 80GB (1/2)
SV1203N 120GB (2/3)
SV1604N 160GB (2/4)
SpinPoint PL40 with ATA-133 Interface (7200RPM, 2MB cache)
SP0411N 40GB (1/1)
SpinPoint PL40 with SATA-150 Interface (7200RPM, 2MB cache)
SP0411C 40GB (1/1)
100-120GB/platter Section (all drives under here use platters that can hold 100-120GB of data.)
SpinPoint P120 with ATA-133 Interface (7200RPM)
SP1012N 100GB (8MB cache) (1/2)
SP1202N 120GB (2MB cache) (1/2)
SP1212N 120GB (8MB cache) (1/2)
SP2004N 200GB (2MB cache) (2/4)
SP2014N 200GB (8MB cache) (2/4)
SP2504N 250GB (2MB cache) (2/4)
SP2514N 250GB (8MB cache) (2/4)
SpinPoint P120 with SATA-300 Interface (7200RPM, 8MB cache)
SP2004C 200GB (2/4)
SP2504C 250GB (2/4)
SpinPoint P120CE with ATA-133 Interface (7200RPM, for AV applications)
HA200JC 200GB (2MB cache) (2/4)
HA250JC 250GB (2MB cache) (2/4)
SP2014N/CE 200GB (8MB cache) (2/4)
SP2514N/CE 250GB (8MB cache) (2/4)
133GB/platter Section (all drives under here use platters that can hold 133GB of data.)
SpinPoint T133 with ATA-133 Interface (7200RPM, 8MB cache)
HD250KD 250GB (2/4 [short-stroked])
HD300LD 300GB (3/5 [short-stroked])
HD320LD 320GB (3/5 [short-stroked])
HD400LD 400GB (3/6)
SpinPoint T133 with SATA-300 Interface (7200RPM)
HD250KJ 250GB (8MB cache) (2/4 [short-stroked])
HD300LJ 300GB (8MB cache) (3/5 [short-stroked])
HD301LJ 300GB (16MB cache) (3/5 [short-stroked])
HD320LJ 320GB (8MB cache) (3/5 [short-stroked])
HD321LJ 320GB (16MB cache) (3/5 [short-stroked])
HD400LJ 400GB (8MB cache) (3/6)
HD401LJ 400GB (16MB cache) (3/6)
SpinPoint S166 (7200RPM, SATA-300 interface)
HD041GJ 40GB (2MB cache) (1/1 [short-stroked])
HD042GJ 40GB (8MB cache) (1/1 [short-stroked])
HD081GJ 80GB (2MB cache) (1/1)
HD082GJ 80GB (8MB cache) (1/1)
HD120HJ 120GB (8MB cache) (1/2 [short-stroked])
HD161HJ 160GB (8MB cache) (1/2)
SpinPoint T166 (7200RPM, SATA-300 interface)
HD080GJ 80GB (8MB cache) (1/1)
HD160HJ 160GB (8MB cache) (1/2)
HD320KJ 320GB (8MB cache) (2/4)
HD321KJ 320GB (16MB cache) (2/4)
HD500LJ 500GB (8MB cache) (3/6)
HD501LJ 500GB (16MB cache) (3/6)
200-250GB/platter Section (all drives under here use platters that can hold 200-250GB of data.)
SpinPoint S250 (7200RPM, 8MB cache, SATA-300 interface)
HD200HJ 200GB (1/2)
HD250HJ 250GB (1/2)
SpinPoint S250 CE (7200RPM, 8MB cache, SATA-300 interface, for AV applications)
HA161HJ 160GB (1/2 [short-stroked])
HA250HJ 250GB (1/2)
SpinPoint F1 DT (7200RPM, SATA-300 interface)
HD162HJ 160GB (8MB cache) (1/2 [short-stroked])
HD251HJ 250GB (8MB cache) (1/2)
HD252HJ 250GB (16MB cache) (1/2)
HD502LJ 500GB (16MB cache) (2/4)
HD753LJ 750GB (32MB cache) (3/6)
SpinPoint F1R (7200RPM, SATA-300 interface, for RAID-based applications)
HE252HJ 250GB (16MB cache) (1/2)
HE502IJ 500GB (16MB cache) (2/4)
HE753LJ 750GB (32MB cache) (3/6)
SpinPoint F1 CE (7200RPM, SATA-300 interface, for AV applications)
HA251HJ 250GB (8MB cache) (1/2)
HA501IJ 500GB (8MB cache) (2/4)
HA751LJ 750GB (32MB cache) (3/6)
EcoGreen F1EG CE (5400RPM, SATA-300 interface, for AV applications)
HA252HI 250GB (16MB cache) (1/2)
HA502JI 500GB (16MB cache) (2/4)
HA753LI 750GB (32MB cache) (3/6)
HD083GJ 80GB (8MB cache) (1/1 [short-stroked])
HD161GJ/ST160DM002 160GB (8MB cache) (1/1)
HD162GJ 160GB (16MB cache) (1/1)
HD321HJ 320GB (8MB cache) (1/2)
HD322HJ 320GB (16MB cache) (1/2)
HD642JJ 640GB (16MB cache) (2/4)
HD103UJ/ST1000DM006 1TB (32MB cache) (3/6)
Samsung's storage division was taken over by Seagate. Since then, variations of some of these drives with Seagate model numbers (STxxxxDXxxx) have began to circulate. Aside from the new branding, I'm not sure if there's much physical difference.
SpinPoint F1R (7200RPM, SATA-300 interface, for RAID applications)
HE322HJ 320GB (16MB cache) (1/2)
HE642JJ 640GB (16MB cache) (2/4)
HE103UJ 1TB (32MB cache) (3/6)
HA321HJ 320GB (8MB cache) (1/2)
HA642JJ 640GB (32MB cache) (2/4)
HA101UJ 1TB (32MB cache) (3/6)
HA322HI 320GB (16MB cache) (1/2)
HA642JI 640GB (16MB cache) (2/4)
HA103UI 1TB (32MB cache) (3/6)
EcoGreen F3EG (5400RPM, 32MB cache, SATA-300 interface)
HD153WI 1.5TB (4/8)
EcoGreen F2EG (5400RPM, SATA-300 interface)
HD502HI 500GB (16MB cache) (1/2)
HD102SI 1TB (16MB cache) (2/4)
HD103SI 1TB (32MB cache) (2/4)
HD153UI 1.5TB (16MB cache) (3/6)
HD154UI 1.5TB (32MB cache) (3/6)
SpinPoint F3 (7200RPM, SATA-300 interface)
HD164GJ 160GB (8MB cache) (1/1 [short-stroked])
HD163GJ/ST160DM000 160GB (16MB cache) (1/1 [short-stroked])
HD254GJ 250GB (8MB cache) (1/1)
HD253GJ/ST250DM001 250GB (16MB cache) (1/1)
HD323HJ 320GB (16MB cache) (1/2 [short-stroked])
HD502HJ/ST500DM005 500GB (16MB cache) (1/2)
HD754JJ 750GB (32MB cache) (2/3)
HD103SJ/ST1000DM005 1TB (32MB cache) (2/4)
SpinPoint F3R (7200RPM, SATA-300 interface, Enterprise-class)
HE253GJ 250GB (16MB cache) (1/1)
HE502HJ 500GB (16MB cache) (1/2)
HE754JJ 750GB (32MB cache) (2/3)
HE103SJ 1TB (32MB cache) (2/4)
EcoGreen F3EG (5400RPM, SATA-300 interface)
HD253GI 250GB (16MB cache) (1/1)
HD324HI 320GB (16MB cache) (1/2 [short-stroked])
HD503HI/ST500DL001 500GB (16MB cache) (1/2)
HD754JI 750GB (32MB cache) (2/3)
HD105SI/ST1000DL004 1TB (32MB cache) (2/4)
HD203WI 2TB (32MB cache) (4/8)
That two terabyte model is unique in that it is Samsung's very first attempt at a four platter drive.
640-667GB/platter Section (all drives under here use platters that can hold 640-667GB of data.)
SpinPoint F4 (7200RPM, SATA-300 interface)
HD165GJ 160GB (8MB cache) (1/1 [short-stroked])
HD166GJ 160GB (16MB cache) (1/1 [short-stroked])
HD255GJ 250GB (8MB cache) (1/1 [short-stroked])
HD256GJ/ST250DM001 250GB (16MB cache) (1/1 [short-stroked])
HD322GJ/ST320DM001 320GB (16MB cache) (1/1)
EcoGreen F4EG (5400RPM, 32MB cache, SATA-300 interface)
HD155UI/ST1500DL004 1.5TB (3/5)
HD204UI/ST2000DL004 2TB (3/6)
1TB/platter Section (all drives under here use platters that can hold 1TB of data.)
SpinPoint EcoGreen F6 (5400RPM, 32MB cache, SATA-600 interface)
HN-D101RAE (?) 1TB (1/2)
HN-D151RAE (?) 1.5TB (2/3)
HN-D201RAE 2TB (2/4)
These have yet to be released, as, shortly after they were announced, Samsung's storage division was taken over by Seagate.
Seagate 1,8
Lyrion ST18.1 (3600RPM, 2MB cache, ZIF ATA/66 interface)
ST730212DE 30GB (1/1)
ST730212DEG 30GB (1/1)
ST740211DE 40GB (1/2 [short-stroked])*
ST760211DE 60GB (1/2)
ST760211DEG 60GB (1/2)
Note: The Lyrion ST18.1 is Seagate's first, and seemingly only, line of 1.8" drives. These are quite common and Seagate appears to still be making and selling them in some countries (as of 11/20/09.) A 160GB/platter Lyrion ST18.2 would be very interesting, but alas we probably won't ever see it.
Note 2: The "DEG" suffix marks free fall sensor-equipped models.
*Note: The 40GB model appears to be super rare and does not appear on the official Seagate datasheet. Instead it is listed in the huge product manual.
Lyrion ST18.1 (3600RPM, 2MB cache, CE-ATA interface)
ST730212CA 30GB (1/1)
ST760211CA 60GB (1/2)
Note: Same as the "DE"-suffix drives, but with a CE-ATA interface instead of the familiar (for 1.8" models at least) ZIF ATA.
Seagate 2,5
40GB/platter Section (all drives under here use platters that can hold 40GB of data apiece.)
Momentus 42 (5400RPM, 2MB cache, ATA/100 interface)
ST92014A 20GB (1/1)
ST93015A 30GB (1/2 [short-stroked])
ST94019A 40GB (1/2)
Note: Seagate datasheets for these contain the line "4,200-class performance (spin speed actually 5,400 RPM)".
Momentus 54 (5400RPM, 8MB cache, ATA/100 interface)
ST92011A (2MB cache) 20GB (1/1)
ST92811A 20GB (1/1)
ST94011A (2MB cache) 40GB (1/2)
ST94811A 40GB (1/2)
Momentus 4200 N-LITE (5400RPM, 2MB cache, ATA/100 interface)
ST940110A 40GB (1/2)
LD25.1 (5400RPM, 2MB cache, ATA/100 interface, for CE applications)
ST920217A 20GB (1/1)
ST9402115A 40GB (1/2)
LD25.1 SATA (5400RPM, 2MB cache, SATA-150 interface, for CE applications)
ST920217AS 20GB (1/1)
ST9402115AS 40GB (1/2)
50GB/platter Section (all drives under here use platters that can hold 50GB of data apiece.)
Momentus 4200.2 (5400RPM, 8MB cache, ATA/100 interface)
ST930219A (2MB cache) 30GB (1/1)
ST9402113A (2MB cache) 40GB (1/2 [short-stroked])
ST950212A (2MB cache) 50GB (1/2)
ST960821A 60GB (2/3 [short-stroked])
ST9808210A 80GB (2/3 [short-stroked])
ST9100822A 100GB (2/4)
Note: Seagate datasheets for these contain the line "4,200 RPM-class performance (actual spin speed: 5,400 RPM)".
Momentus 5400.2 (5400RPM, 8MB cache, ATA/100 interface)
ST9308110A 30GB (1/1)
ST9408114A 40GB (1/2 [short-stroked])
ST960822A 60GB (1/2)
ST9808211A 80GB (2/3 [short-stroked])
ST9100823A 100GB (2/4)
Momentus 7200.1 (7200RPM, 8MB cache, ATA/100 interface)
ST94015A 40GB (1/2 [short-stroked])
ST96023A 60GB (2/3 [short-stroked])
ST980825A 80GB (2/3 [short-stroked])
ST910021A 100GB (2/4)
Momentus 7200.1 (7200RPM, 8MB cache, SATA-150 interface)
ST94015AS 40GB (1/2 [short-stroked])
ST96023AS 60GB (2/3 [short-stroked])
ST980825AS 80GB (2/3 [short-stroked])
ST910021AS 100GB (2/4)
ST930218A 30GB (1/1)
ST9402112A 40GB (1/2 [short-stroked])
ST960812A 60GB (1/2)
ST980829A 80GB (2/3 [short-stroked])
ST9100825A 100GB (2/4)
ST9120824A 120GB (2/4)
ST93811A 30GB (1/1)
ST94813A 40GB (1/2 [short-stroked])
ST96812A 60GB (1/2)
ST98823A 80GB (2/3 [short-stroked])
ST9100824A 100GB (2/4)
ST9120821A 120GB (2/4)
Momentus 5400.2 SATA (5400RPM, 8MB cache, SATA-150 interface)
ST93811AS 30GB (1/1)
ST94813AS 40GB (1/2 [short-stroked])
ST96812AS 60GB (1/2)
ST98823AS 80GB (2/3 [short-stroked])
ST9100824AS 100GB (2/4)
ST9120821AS 120GB (2/4)
Momentus FDE (5400RPM, 8MB cache, ATA/100 interface, Self-Encryption)
ST940811A 40GB (1/2 [short-stroked])
ST960814A 60GB (1/2)
ST980821A 80GB (2/3 [short-stroked])
ST9100826A 100GB (2/4)
ST9120826A 120GB (2/4)
80GB/platter Section (all drives under here use platters that can hold 80GB of data apiece.)
Momentus 5400.3 (5400RPM, 8MB cache, ATA/100 interface)
ST940815A 40GB (1/1)
ST960815A 60GB (1/2 [short-stroked])
ST980815A 80GB (1/2)
ST9100828A 100GB (2/3 [short-stroked])
ST9120822A 120GB (2/3)
ST9160821A 160GB (2/4)
Momentus 5400.3 SATA (5400RPM, 8MB cache, SATA-150 interface)
ST940814AS 40GB (1/1)
ST960813AS 60GB (1/2 [short-stroked])
ST980811AS 80GB (1/2)
ST9100828AS 100GB (2/3 [short-stroked])
ST9120822AS 120GB (2/3)
ST9160821AS 160GB (2/4)
Momentus FDE.2 SATA (5400RPM, 8MB cache, SATA-150 interface, Self Encryption)
ST980816AS 80GB (1/2)
ST9120827AS 120GB (2/3)
ST9160824AS 160GB (2/4)
Maxtor MobileMax (5400RPM, 2MB cache, ATA/100 interface)
STM940215A 40GB (1/1)
STM960212A 60GB (1/2 [short-stroked])
STM980215A 80GB (1/2)
STM9120822A (8MB cache) 120GB (2/3)
LD25.2 (5400RPM, 2MB cache, ATA/100 interface, for CE applications)
ST940210A 40GB (1/1)
ST960210A 60GB (1/2 [short-stroked])
ST980210A 80GB (1/2)
LD25.2 SATA (5400RPM, 2MB cache, SATA-150 interface, for CE applications)
ST920210AS 20GB (1/1 [short-stroked])
ST940210AS 40GB (1/1)
ST960210AS 60GB (1/2 [short-stroked])
ST980210AS 80GB (1/2)
100-120GB/platter Section (all drives under here use platters that can hold 100-120GB of data apiece.)
Momentus 5400.4 (5400RPM, 8MB cache, SATA-300 interface)
ST980817AS 80GB (1/2 [short-stroked])
ST9120817AS 120GB (1/2)
ST9160827AS 160GB (2/3 [short-stroked])
ST9200827AS 200GB (2/4)
ST9250827AS 250GB (2/4)
Momentus 7200.2 (7200RPM, 16MB cache, SATA-300 interface)
ST980813AS 80GB (1/2 [short-stroked])
ST980813ASG 80GB (1/2 [short-stroked])
ST9100821AS 100GB (2/3 [short-stroked])
ST9120823AS 120GB (2/3 [short-stroked])
ST9120823ASG 120GB (2/3 [short-stroked])
ST9160823AS 160GB (2/4 [short-stroked])
ST9160823ASG 160GB (2/4 [short-stroked])
ST9200420AS 200GB (2/4)
ST9200420ASG 200GB (2/4)
Note: maximum platter density appears to be 100GB for this lineup. Not sure what's up with that 100GB model though; its model number suggests two platters (ST9100821AS), when ideally it would contain one platter and two heads.
160-166GB/platter Section (all drives under here use platters that can hold 160-166GB of data apiece.)
Momentus 5400.5 (5400RPM, 8MB cache, SATA-300 interface)
ST980310AS 80GB (1/1)
ST9120310AS 120GB (1/2 [short-stroked])
ST9160310AS 160GB (1/2)
ST9250320AS 250GB (2/4 [short-stroked])
ST9320320AS 320GB (2/4)
Momentus 7200.3 (7200RPM, 16MB cache, SATA-300 interface)
ST980411AS 80GB (1/1)
ST9160411AS 160GB (1/2)
ST9250421AS 250GB (2/4 [short-stroked])
ST9320421AS 320GB (2/4)
Momentus 5400 FDE.3 (5400RPM, 8MB cache, SATA-300 interface, Self Encryption)
ST9120312AS 120GB (1/2 [short-stroked])
ST9160312AS 160GB (1/2)
ST9160319AS 160GB (1/2)
ST9250322AS 250GB (2/4 [short-stroked])
ST9320322AS 320GB (2/4)
ST9320329AS 320GB (2/4)
Momentus 7200 FDE (7200RPM, 16MB cache, SATA-300 interface, Self Encryption)
ST9160414AS 160GB (1/2)
ST9160414ASG 160GB (1/2)
ST9250424AS 250GB (2/4 [short-stroked])
ST9320424AS 320GB (2/4)
ST9320424ASG 320GB (2/4)
Constellation (7200RPM, Not for laptops)
ST9160511NS 160GB (1/2)
ST9500530NS 500GB (3/6)
ST9500430SS 500GB (3/6)
ST9500431SS 500GB (3/6)
250GB/platter Section (all drives under here use platters that can hold 250GB of data apiece.)
Momentus 5400.6 (5400RPM, 8MB cache, SATA-300 interface)
ST9120315AS 120GB (1/1)
ST9160314ASG 160GB (1/2 [short-stroked])
ST9160314AS 160GB (1/2 [short-stroked])
ST9250315AS 250GB (1/2)
ST9250315ASG 250GB (1/2)
ST9320325ASG 250GB (2/3)
ST9320325AS 320GB (2/3 [short-stroked])
ST9500325ASG 500GB (2/4)
ST9500325AS 500GB (2/4)
Momentus 7200.4 (7200RPM, 16MB cache, SATA-300 interface)
ST9160412AS 160GB (1/2 [short-stroked])
ST9160412ASG 160GB (1/2 [short-stroked])
ST9250410AS 250GB (1/2)
ST9250410ASG 250GB (1/2)
ST9320423AS 320GB (2/3 [short-stroked])
ST9320423ASG 320GB (2/3 [short-stroked])
ST9500420AS 500GB (2/4)
ST9500420ASG 500GB (2/4)
Momentus 5400 FDE.4 (5400RPM, 8MB cache, SATA-300 interface, Self Encryption)
ST9120317AS 120GB (1/1)
ST9160317AS 160GB (1/2 [short-stroked])
ST9250317AS 250GB (1/2)
ST9320327AS 320GB (2/3 [short-stroked])
ST9500327AS 500GB (2/4)
Momentus 7200 FDE.2 (7200RPM, 16MB cache, SATA-300 interface, Self Encryption)
ST9160413AS 160GB (1/2 [short-stroked])
ST9160418ASG 160GB (1/2 [short-stroked])
ST9160419ASG 160GB (1/2 [short-stroked])
ST9250411AS 250GB (1/2)
ST9250414ASG 250GB (1/2)
ST9500421AS 500GB (2/4)
ST9500426ASG 500GB (2/4)
Momentus 7200 FDE.2 (7200RPM, 16MB cache, SATA-300 interface, FIPS 140-2 Self Encryption)
ST9250412AS 250GB (1/2)
ST9500422AS 500GB (2/4)
Momentus Thin (5400RPM, 8MB cache, SATA-300 interface, 7mm z-height)
ST91603010AS 160GB (1/2)
ST92503010AS 250GB (1/2)
Momentus XT (7200RPM, 32MB cache, SATA-300 interface, hybrid drive with 4GB flash memory)
ST92505610AS 250GB (1/2)
ST93205620AS 320GB (2/3 [short-stroked])
ST95005620AS 500GB (2/4)
320-375GB/platter Section (all drives under here use platters that can hold 320-370GB of data apiece.)
Momentus 5400.7 (5400RPM, 8MB cache, SATA-300 interface)
ST9160316AS 160GB (1/1)
ST9250310AS 250GB (1/2 [short-stroked])
ST9320310AS 320GB (1/2)
ST9320312AS (4K Sectors) 320GB (1/2)
ST9400321AS (4K Sectors) 400GB (2/3 [short-stroked])
ST9500320AS 500GB (2/4 [short-stroked])
ST9640320AS 640GB (2/4)
ST9640322AS (4K Sectors) 640GB (2/4)
ST9750423AS (16MB cache) 750GB (2/4)
Momentus 7200.5 (7200RPM, 16MB cache, SATA-300 interface)
ST9500423AS 500GB (2/4 [short-stroked])
ST9500424AS 500GB (2/4 [short-stroked])
ST9500423ASG (w/ Free Fall Sensor) 500GB (2/4 [short-stroked])
ST9640420AS 640GB (2/4)
ST9640422AS 640GB (2/4)
ST9640421AS (w/ Self-Encryption) 640GB (2/4)
ST9640420ASG (w/ Free Fall Sensor) 640GB (2/4)
ST9750420AS 750GB (2/4)
ST9750422AS 750GB (2/4)
ST9750421AS (w/ Self-Encryption) 750GB (2/4)
ST9750420ASG (w/ Free Fall Sensor) 750GB (2/4)
ST160LT003 160GB (1/1)
ST250LT003 250GB (1/2 [short-stroked])
ST320LT020 320GB (1/2)
Momentus Thin (7200RPM, 16MB cache, SATA-300 interface, 7mm z-height)
ST160LT007 160GB (1/1)
ST250LT007 250GB (1/2 [short-stroked])
ST320LT007 320GB (1/2)
Momentus Thin w/ Encryption (7200RPM, 16MB cache, SATA-300 interface, 7mm z-height)
ST250LT009 250GB (1/2 [short-stroked])
ST250LT014 250GB (1/2 [short-stroked])
ST320LT009 320GB (1/2)
ST320LT014 320GB (1/2)
Laptop Thin (5400RPM, 16MB cache, SATA-600 interface, 7mm z-height)
ST320LT012 320GB (1/2)
Laptop Thin (7200RPM, 32MB cache, SATA-600 interface, 7mm z-height)
ST320LM010 320GB (1/2)
Laptop Ultrathin (5400RPM, 16MB cache, SATA-600 interface, 5mm z-height)
ST320LT030 320GB (1/2)
ST320LT031 320GB [Self-Encrypting Drive] (1/2)
FreePlay (5400RPM?, 8MB cache?, SATA-300 interface?)
ST9750430AS 750GB (3/5) [or (3/6) if 250GB/platter]
ST9888430AS 880GB (3/6 [short-stroked])
ST91000430AS 1TB (3/6)
Seagate has used these unusual drives in some of their FreeAgent Go/GoFlex externals. Not much is known about them.
Momentus XT 2nd Gen. (7200RPM, 32MB cache, SATA-600 interface, hybrid drive with 8GB flash memory)
ST750LX003 750GB (2/4)
500GB/platter Section (all drives under here use platters that can hold 500GB of data apiece.)
ST250LT012 250GB (1/1)
ST500LT012 500GB (1/2)
ST500LT025 500GB (Self-Encrypting Drive) (1/2)
ST500LT015 500GB (FIPS 140-2 Self-Encrypting Drive) (1/2)
ST500LM021 500GB (1/2)
Laptop Thin (5400RPM, 32MB cache, SATA-600 interface, 7mm z-height)
ST750LM031 750GB (2/4)
ST750LM025 750GB (Self-Encrypting Drive) (2/4)
ST1000LM033 1TB (2/4)
ST1000LM029 1TB (Self-Encrypting Drive) (2/4)
ST500LT032 500GB (1/2)
ST500LT033 500GB [Self-Encrypting Drive] (1/2)
Mobile HDD (5400RPM, 128MB cache, SATA-600 interface, 7mm z-height)
ST1000LM035 1TB (2/4)
ST1000LM037 1TB (Self-Encrypting Drive) (2/4)
ST1000LM038 1TB (FIPS 140-2 Self-Encrypting Drive) (2/4)
Laptop Thin SSHD (5400RPM, 64MB cache, 8GB Flash, SATA-600 interface, 7mm z-height)
ST500LM000 500GB (1/2)
Laptop SSHD (5400RPM, 64MB cache, 8GB Flash, SATA-600 interface, 9.5mm z-height)
ST1000LM014 1TB (2/4)
1TB/platter Section (all drives under here use platters that can hold 1TB of data apiece.)
ST2000LM007 2TB (2/4)
ST2000LM009 2TB (Self-Encrypting Drive) (2/4)
ST2000LM010 2TB (FIPS 140-2 Self-Encrypting Drive) (2/4)
Seagate CE AV
120-133GB/platter Section (all drives under here use platters that can hold 120-133GB of data apiece.)
SV35 (7200RPM, ATA-100 interface)
ST3250824AV 250GB (8MB Cache) (2/4)
ST3500641AV 500GB (16MB Cache) (4/8)
SV35 (7200RPM, SATA-300 interface)
ST3250824SV 250GB (8MB Cache) (2/4)
ST3500641SV 500GB (16MB Cache) (4/8)
DB35 (7200RPM, ATA-100 interface)
ST3200826ACE 200GB (8MB Cache) (2/3)
ST3250823ACE 250GB (8MB Cache) (2/4)
ST3300831ACE 300GB (8MB Cache) (3/5 [short-stroked])
ST3400832ACE 400GB (8MB Cache) (3/6)
DB35 (7200RPM, SATA-150 interface)
ST3200826SCE 200GB (8MB Cache) (2/3)
ST3250823SCE 250GB (8MB Cache) (2/4)
ST3300831SCE 300GB (8MB Cache) (3/5 [short-stroked])
ST3400832SCE 400GB (8MB Cache) (3/6)
DB35.2 (7200RPM, ATA-100 interface)
ST3802110ACE 80GB (2MB Cache) (1/2 [short-stroked])
ST3120213ACE 120GB (2MB Cache) (1/2)
ST3200827ACE 200GB (8MB Cache) (2/3)
ST3250824ACE 250GB (8MB Cache) (2/4)
ST3400833ACE 400GB (8MB Cache) (3/6)
ST3500841ACE 500GB (8MB Cache) (4/8)
DB35.2 (7200RPM, SATA-300 interface)
ST3802110SCE 80GB (2MB Cache) (1/2 [short-stroked])
ST3120213SCE 120GB (2MB Cache) (1/2)
ST3200827SCE 200GB (8MB Cache) (2/3)
ST3250824SCE 250GB (8MB Cache) (2/4)
ST3400833SCE 400GB (8MB Cache) (3/6)
ST3500841SCE 500GB (8MB Cache) (4/8)
160-188GB/platter Section (all drives under here use platters that can hold 160-188GB of data apiece.)
ST3160812AV 160GB (8MB Cache) (1/2)
ST3160812SV 160GB (8MB Cache) (1/2)
SV35.2 (7200RPM, ATA-100 interface)
ST3160815AV 160GB (8MB Cache) (1/2)
ST3250820AV 250GB (8MB Cache) (2/3)
ST3320620AV 320GB (16MB Cache) (2/4)
ST3500630AV 500GB (16MB Cache) (3/6)
ST3750640AV 750GB (16MB Cache) (4/8)
SV35.2 (7200RPM, SATA-300 interface)
ST3160815SV 160GB (8MB Cache) (1/2)
ST3250820SV 250GB (8MB Cache) (2/3)
ST3320620SV 320GB (16MB Cache) (2/4)
ST3500630SV 500GB (16MB Cache) (3/6)
ST3750640SV 750GB (16MB Cache) (4/8)
ST3160212ACE 160GB (2MB Cache) (1/2)
ST3300822ACE 300GB (8MB Cache) (2/4 [short-stroked])
ST3160212SCE 160GB (2MB Cache) (1/2)
ST3300822SCE 300GB (8MB Cache) (2/4 [short-stroked])
DB35.3 (7200RPM, ATA-100 interface)
ST380215ACE 80GB (2MB Cache) (1/1)
ST3160215ACE 160GB (2MB Cache) (1/2)
ST3250820ACE 250GB (8MB Cache) (2/3)
ST3300820ACE 300GB (8MB Cache) (2/4 [short-stroked])
ST3320820ACE 320GB (8MB Cache) (2/4)
ST3500830ACE 500GB (8MB Cache) (3/6)
ST3750840ACE 750GB (8MB Cache) (4/8)
DB35.3 (7200RPM, SATA-300 interface)
ST380215SCE 80GB (2MB Cache) (1/1)
ST3160215SCE 160GB (2MB Cache) (1/2)
ST3250820SCE 250GB (8MB Cache) (2/3)
ST3300820SCE 300GB (8MB Cache) (2/4 [short-stroked])
ST3320820SCE 320GB (8MB Cache) (2/4)
ST3500830SCE 500GB (8MB Cache) (3/6)
ST3750840SCE 750GB (8MB Cache) (4/8)
ST3750640SCE 750GB (16MB Cache) (4/8)
200-250GB/platter Section (all drives under here use platters that can hold 200-250GB of data apiece.)
SV35.3 (7200RPM, SATA-300 interface)
ST3250310SV 250GB (8MB Cache) (1/2)
ST3500320SV 500GB (32MB Cache) (2/4)
ST3750330SV 750GB (32MB Cache) (3/6)
ST31000340SV 1TB (32MB Cache) (4/8)
ST3400820ACE 400GB (8MB Cache) (2/4)
ST3400820SCE 400GB (8MB Cache) (2/4)
DB35.4 (7200RPM, 8MB cache, SATA-300 interface)
ST3250310CS 250GB (1/2)
SV35.5 (7200RPM)
ST3250311SV (8MB Cache) (SATA-300 interface) 250GB (1/1)
ST3500410SV (16MB Cache) (SATA-300 interface) 500GB (1/2)
ST3500411SV (16MB Cache) (SATA-600 interface) 500GB (1/2)
ST31000525SV (32MB Cache) (SATA-300 interface) 1TB (2/4)
ST31000526SV (32MB Cache) (SATA-600 interface) 1TB (2/4)
Pipeline HD.2 (5900RPM, SATA-300 interface)
ST3160316CS 160GB (8MB cache) (1/1)
ST3250312CS 250GB (8MB cache) (1/1)
ST3250412CS 250GB (16MB cache) (1/1)
ST3320311CS 320GB (8MB cache) (1/2)
ST3320413CS 320GB (16MB cache) (1/2)
ST3500312CS 500GB (8MB cache) (1/2)
ST3500414CS 500GB (16MB cache) (1/2)
ST31000322CS 1TB (8MB cache) (2/4)
ST31000424CS 1TB (16MB cache) (2/4)
Pipeline HD (5900RPM, 64MB cache, SATA-300 interface)
ST1500VM002 1.5TB (3/6)
600-667GB/platter Section (all drives under here use platters that can hold 600-667GB of data apiece.)
SV35 (5900RPM, 64MB cache, SATA-300 interface)
ST2000VX002 2TB (3/6)
ST2000VM002 2TB (3/6)
SV35.6/Surveillance HDD (7200RPM, 64MB cache, SATA-600 interface)
ST1000VX000 1TB (1/2)
ST2000VX000 2TB (2/4) or (3/?)*
ST3000VX000 3TB (3/6)
*Like the Barracuda ST2000DM001, there appear to be multiple head/platter configurations of the ST2000VX000 out in the wild, all under the same model number. It's unclear how many heads and what platter density the three-platter versions employ. Buyer beware.
ST3000VX002 3TB (3/6)
ST4000VX000 4TB (4/8)
Pipeline HD/Video 3.5 HDD (5900RPM, 64MB cache, SATA-600 interface)
ST1000VM002 1TB (1/2)
ST2000VM003 2TB (2/4)
ST3000VM002 3TB (3/6)
ST4000VM000 4TB (4/8)
Seagate Desktop
Barracuda 7200.7 (7200RPM, ATA-100 interface)
ST340014A 40GB (2MB Cache) (1/1)
ST360014A 60GB (2MB Cache) (1/2 [short-stroked])
ST380011A 80GB (2MB Cache) (1/2)
ST380013A 80GB (8MB Cache) (1/2)
ST3120022A 120GB (2MB Cache) (2/3)
ST3120026A 120GB (8MB Cache) (2/3)
ST3160021A 160GB (2MB Cache) (2/4)
ST3160023A 160GB (8MB Cache) (2/4)
Barracuda 7200.7 (7200RPM, SATA-150 interface)
ST340014AS 40GB (2MB Cache) (1/1)
ST340111AS 40GB (8MB Cache) (1/1)
ST380011AS 80GB (2MB Cache) (1/2)
ST380013AS 80GB (8MB Cache) (1/2)
ST380817AS 80GB (8MB Cache) (1/2)
ST3120022AS 120GB (2MB Cache) (2/3)
ST3120026AS 120GB (8MB Cache) (2/3)
ST3120827AS 120GB (8MB Cache) (2/3)
ST3160021AS 160GB (2MB Cache) (2/4)
ST3160023AS 160GB (8MB Cache) (2/4)
ST3160827AS 160GB (8MB Cache) (2/4)
100GB/platter Section (all drives under here use platters that can hold 100GB of data apiece.)
ST3200021A 200GB (2MB Cache) (2/4)
ST3200822A 200GB (8MB Cache) (2/4)
ST3200822AS 200GB (8MB Cache) (2/4)
Barracuda 7200.8 (7200RPM, ATA-100 interface)
ST3200826A 200GB (8MB Cache) (2/3)
ST3250823A 250GB (8MB Cache) (2/4)
ST3250623A 250GB (16MB Cache) (2/4)
ST3300831A 300GB (8MB Cache) (3/5 [short-stroked])
ST3300631A 300GB (16MB Cache) (3/5 [short-stroked])
ST3400832A 400GB (8MB Cache) (3/6)
ST3400632A 400GB (16MB Cache) (3/6)
Barracuda 7200.8 (7200RPM, SATA-150 interface)
ST3200826AS 200GB (8MB Cache) (2/3)
ST3250823AS 250GB (8MB Cache) (2/4)
ST3250623AS 250GB (16MB Cache) (2/4)
ST3300831AS 300GB (8MB Cache) (3/5 [short-stroked])
ST3300631AS 300GB (16MB Cache) (3/5 [short-stroked])
ST3400832AS 400GB (8MB Cache) (3/6)
ST3400632AS 400GB (16MB Cache) (3/6)
Barracuda 7200.9 (7200RPM, ATA-100 interface)
ST3402111A 40GB (2MB Cache) (1/1 [short-stroked])
ST3802110A 80GB (2MB Cache) (1/2 [short-stroked])
ST3120213A 120GB (2MB Cache) (1/2)
ST3120814A 120GB (8MB Cache) (1/2)
ST3200827A 200GB (8MB Cache) (2/3)
ST3250824A 250GB (8MB Cache) (2/4)
ST3250624A 250GB (16MB Cache) (2/4)
ST3320833A 320GB (8MB Cache) (3/5 [short-stroked])
ST3320633A 320GB (16MB Cache) (3/5 [short-stroked])
ST3400833A 400GB (8MB Cache) (3/6)
ST3400633A 400GB (16MB Cache) (3/6)
ST3500841A 500GB (8MB Cache) (4/8)
ST3500641A 500GB (16MB Cache) (4/8)
Barracuda 7200.9 (7200RPM, SATA-300 interface)
ST3402111AS 40GB (2MB Cache) (1/1 [short-stroked])
ST340211AS 40GB (2MB Cache) (1/1 [short-stroked])
ST3802110AS 80GB (2MB Cache) (1/2 [short-stroked])
ST3808110AS 80GB (8MB Cache) (1/2 [short-stroked])
ST380211AS 80GB (2MB Cache) (1/2 [short-stroked])
ST380811AS 80GB (8MB Cache) (1/2 [short-stroked])
ST3120213AS 120GB (2MB Cache) (1/2)
ST3120813AS 120GB (8MB Cache) (1/2)
ST3120211AS 120GB (2MB Cache) (1/2)
ST3120811AS 120GB (8MB Cache) (1/2)
ST3200827AS 200GB (8MB Cache) (2/3)
ST3250824AS 250GB (8MB Cache) (2/4)
ST3250624AS 250GB (16MB Cache) (2/4)
ST3400833AS 400GB (8MB Cache) (3/6)
ST3400633AS 400GB (16MB Cache) (3/6)
ST3500841AS 500GB (8MB Cache) (4/8)
ST3500641AS 500GB (16MB Cache) (4/8)
DiamondMax 20 (7200RPM, ATA-100 interface)
STM3402111A 40GB (2MB Cache) (1/1 [short-stroked])
STM380211A 80GB (2MB Cache) (1/2 [short-stroked])
DiamondMax 20 (7200RPM, SATA-300 interface)
STM340211AS 40GB (2MB Cache) (1/1 [short-stroked])
STM380211AS 80GB (2MB Cache) (1/2 [short-stroked])
STM380811AS 80GB (8MB Cache) (1/2 [short-stroked])
ST3160212A 160GB (2MB Cache) (1/2)
ST3160812A 160GB (8MB Cache) (1/2)
ST3300822A 300GB (8MB Cache) (2/4 [short-stroked])
ST3300622A 300GB (16MB Cache) (2/4 [short-stroked])
ST3160212AS 160GB (2MB Cache) (1/2)
ST3160812AS 160GB (8MB Cache) (1/2)
ST3160211AS 160GB (2MB Cache) (1/2)
ST3160811AS 160GB (8MB Cache) (1/2)
ST3300822AS 300GB (8MB Cache) (2/4 [short-stroked])
ST3300622AS 300GB (16MB Cache) (2/4 [short-stroked])
STM3160212A 160GB (2MB Cache) (1/2)
STM3160211AS 160GB (2MB Cache) (1/2)
STM3160811AS 160GB (8MB Cache) (1/2)
Barracuda 7200.10 (7200RPM, ATA-100 interface)
ST340215A 40GB (2MB Cache) (1/1 [short-stroked])
ST340815A 40GB (8MB Cache) (1/1 [short-stroked])
ST380215A 80GB (2MB Cache) (1/1)
ST380815A 80GB (8MB Cache) (1/1)
ST3120215A 120GB (2MB Cache) (1/2 [short-stroked])
ST3120815A 120GB (8MB Cache) (1/2 [short-stroked])
ST3160215A 160GB (2MB Cache) (1/2)
ST3160815A 160GB (8MB Cache) (1/2)
ST3200820A 200GB (8MB Cache) (2/3 [short-stroked])
ST3250820A 250GB (8MB Cache) (2/3)
ST3250620A 250GB (16MB Cache) (2/3)
ST3300820A 300GB (8MB Cache) (2/4 [short-stroked])
ST3300620A 300GB (16MB Cache) (2/4 [short-stroked])
ST3320820A 320GB (8MB Cache) (2/4)
ST3320620A 320GB (16MB Cache) (2/4)
ST3500830A 500GB (8MB Cache) (3/6)
ST3500630A 500GB (16MB Cache) (3/6)
ST3750840A 750GB (8MB Cache) (4/8)
ST3750640A 750GB (16MB Cache) (4/8)
Barracuda 7200.10 (7200RPM, SATA-300 interface)
ST340215AS 40GB (2MB Cache) (1/1 [short-stroked])
ST340815AS 40GB (8MB Cache) (1/1 [short-stroked])
ST380215AS 80GB (2MB Cache) (1/1)
ST380815AS 80GB (8MB Cache) (1/1)
ST3120215AS 120GB (2MB Cache) (1/2 [short-stroked])
ST3120815AS 120GB (8MB Cache) (1/2 [short-stroked])
ST3160215AS 160GB (2MB Cache) (1/2)
ST3160310AS 160GB (8MB Cache) (1/2)
ST3160815AS 160GB (8MB Cache) (1/2)
ST3200820AS 200GB (8MB Cache) (2/3 [short-stroked])
ST3250820AS 250GB (8MB Cache) (2/3)
ST3250620AS 250GB (16MB Cache) (2/3)
ST3300820AS 300GB (8MB Cache) (2/4 [short-stroked])
ST3300620AS 300GB (16MB Cache) (2/4 [short-stroked])
ST3320820AS 320GB (8MB Cache) (2/4)
ST3320620AS 320GB (16MB Cache) (2/4)
ST3500830AS 500GB (8MB Cache) (3/6)
ST3500630AS 500GB (16MB Cache) (3/6)
ST3750840AS 750GB (8MB Cache) (4/8)
ST3750640AS 750GB (16MB Cache) (4/8)
DiamondMax 21 (7200RPM, ATA-100 interface)
STM380215A 80GB (2MB Cache) (1/1)
STM3160215A 160GB (2MB Cache) (1/2)
STM3200820A 200GB (8MB Cache) (2/3 [short-stroked])
STM3250820A 250GB (8MB Cache) (2/3)
STM3250620A 250GB (16MB Cache) (2/3)
STM3300620A 300GB (16MB Cache) (2/4 [short-stroked])
STM3320820A 320GB (8MB Cache) (2/4)
DiamondMax 21 (7200RPM, SATA-300 interface)
STM340215AS 40GB (2MB Cache) (1/1 [short-stroked])
STM380215AS 80GB (2MB Cache) (1/1)
STM380815AS 80GB (8MB Cache) (1/1)
STM3160215AS 160GB (2MB Cache) (1/2)
STM3160815AS 160GB (8MB Cache) (1/2)
STM3250820AS 250GB (8MB Cache) (2/3)
STM3250824AS 250GB (8MB Cache) (2/3)
STM3320820AS 320GB (8MB Cache) (2/4)
STM3320620AS 320GB (16MB Cache) (2/4)
STM3500630AS 500GB (16MB Cache) (3/6)
ST3400820A 400GB (8MB Cache) (2/4)
ST3400620A 400GB (16MB Cache) (2/4)
ST3250310AS 250GB (8MB Cache) (1/2)
ST3250410AS 250GB (16MB Cache) (1/2)
ST3400820AS 400GB (8MB Cache) (2/4)
ST3400620AS 400GB (16MB Cache) (2/4)
STM3250310AS 250GB (8MB Cache) (1/2)
Barracuda 7200.11 (7200RPM, SATA-300 interface)
ST3500820AS 500GB (8MB Cache) (2/4)
ST3500620AS 500GB (16MB Cache) (2/4)
ST3500320AS 500GB (32MB Cache) (2/4)
ST3640630AS 640GB (16MB Cache) (3/6 [short-stroked])
ST3640330AS 640GB (32MB Cache) (3/6 [short-stroked])
ST3750630AS 750GB (16MB Cache) (3/6)
ST3750330AS 750GB (32MB Cache) (3/6)
ST31000640AS 1TB (16MB Cache) (4/8)
ST31000340AS 1TB (32MB Cache) (4/8)
DiamondMax 22 (7200RPM, SATA-300 interface)
STM3500820AS (8MB Cache) 500GB (2/4)
STM3500620AS (16MB Cache) 500GB (2/4)
STM3500320AS (32MB Cache) 500GB (2/4)
STM3750630AS (16MB Cache) 750GB (3/6)
STM3750330AS (32MB Cache) 750GB (3/6)
STM31000640AS 1TB (16MB Cache) (4/8)
STM31000340AS 1TB (32MB Cache) (4/8)
320-375GB/platter Section (all drives under here use platters that can hold 320-375GB of data apiece.)
ST3160813AS 160GB (8MB Cache) (1/1)
ST3320813AS 320GB (8MB Cache) (1/2)
ST3320613AS 320GB (16MB Cache) (1/2)
ST3640623AS 640GB (16MB Cache) (2/4)
ST3640323AS 640GB (32MB Cache) (2/4)
ST31000333AS 1TB (32MB Cache) (334GB/platter) (3/6)
ST31500341AS (32MB Cache) (375GB/platter) 1.5TB (4/8)
STM3160813AS (8MB Cache) 160GB (1/1)
STM3320614AS (16MB Cache) 320GB (1/2)
STM31000334AS (32MB Cache) (334GB/platter) 1TB (3/6)
Barracuda LP (5900RPM, 32MB cache, SATA-300 interface)
ST31500541AS (375GB/platter) 1.5TB (4/8)
Barracuda 7200.12 (7200RPM)
ST3160318AS 160GB (8MB Cache) (SATA-300 interface) (1/1 [short-stroked])
ST3160316AS 160GB (8MB Cache) (SATA-600 interface) (1/1 [short-stroked])
ST3250318AS 250GB (8MB Cache) (SATA-300 interface) (1/1)
ST3250312AS 250GB (8MB Cache) (SATA-600 interface) (1/1)
ST3320418AS 320GB (16MB Cache) (SATA-300 interface) (1/2 [short-stroked])
ST3320413AS 320GB (16MB Cache) (SATA-600 interface) (1/2 [short-stroked])
ST3500418AS 500GB (16MB Cache) (SATA-300 interface) (1/2)
ST3500413AS 500GB (16MB Cache) (SATA-600 interface) (1/2)
ST3750528AS 750GB (32MB Cache) (SATA-300 interface) (2/3)
ST3750525AS 750GB (32MB Cache) (SATA-600 interface) (2/3)
ST31000528AS 1TB (32MB Cache) (SATA-300 interface) (2/4)
ST31000524AS 1TB (32MB Cache) (SATA-600 interface) (2/4)
Barracuda (7200RPM, 16MB cache, SATA-600 interface, Advanced Format)
ST250DM000 250GB (1/1)
ST320DM000 320GB (1/2 [short-stroked])
ST500DM002 500GB (1/2)
DiamondMax 23 (7200RPM, SATA-300 interface)
STM3160318AS 160GB (1/1) (8MB Cache) (1/1 [short-stroked])
STM3250318AS 250GB (1/1) (8MB Cache) (1/1)
STM3320418AS 320GB (1/2) (16MB Cache) (1/2 [short-stroked])
STM3500418AS 500GB (1/2) (16MB Cache) (1/2)
STM3750528AS 750GB (2/3) (32MB Cache) (2/4)
STM31000528AS 1TB (2/4) (32MB Cache) (2/4)
"Samsung by Seagate" Barracuda (7200RPM, SATA-300 interface)
ST500DM005 (HD502HJ) 500GB (16MB Cache) (1/2)
ST1000DM005 (HD103SJ) 1TB (32MB Cache) (2/4)
Note: These, at least at first glance, appear to be nothing more than relabeled Samsung SpinPoint F3 hard disk drives.
Barracuda LP (5900RPM, SATA-300 interface)
ST3500412AS 500GB (16MB Cache) (1/2)
ST31000520AS 1TB (32MB Cache) (2/4)
ST32000542AS 2TB (32MB Cache) (4/8)
Barracuda Green (5900RPM)
ST1000DL002 1TB (32MB Cache) (SATA-300 interface) (2/4)*
ST1500DL003 1.5TB (64MB Cache) (SATA-600 interface) (3/6)
*Note: Not very sure about this model's platter density. Seagate makes it seem like the Barracuda Green family is only meant to contain 1.5TB and 2TB models, but here we have a 1TB model with smaller cache and lesser interface in stock at several retailers. I'm assuming the drive contains a pair of 500GB platters, so unless someone chimes in with a weight comparison between a 2TB/1.5TB Green and one of these, here it will stay.
Barracuda XT (7200RPM, 64MB cache, SATA-600 interface)
ST32000641AS 2TB (4/8)
ST2000DL001 2TB (32MB Cache) (SATA-300 interface) (3/6)*
ST2000DL003 2TB (64MB Cache) (SATA-600 interface) (3/6)
*Note: Seagate doesn't list these in any of their PDF datasheets for the Barracuda Green family. They can be found within the plastic cases of the firm's GoFlex products, though. (Someone on the Seagate forums had mentioned that their GoFlex came with the above 2TB model.)
ST33000651AS 3TB (5/10)
750-800GB/platter Section (all drives under here use platters that can hold 750-800GB of data apiece.)
Desktop HDD.15 (5900RPM, 64MB cache, SATA-600 interface)
ST3000DM003 3TB (4/8)
The "DM" in the model number suggests a 7200 RPM drive (historically, the 5900 RPM Barracuda Greens used "DL"), but according to an analysis, at least the 4TB model actually spins at around 5900 RPM. Going back on what you said about 5900 RPM drives, are you, Seagate? The company doesn't even give a specific rotational speed for these.
Barracuda XT (7200RPM, 128MB cache, SATA-600 interface)
ST4000DX000 4TB (5/10)
Barracuda 7200.14 (7200RPM, 64MB cache, SATA-600 interface)
ST750DM003 750GB (1/2 [short-stroked])
ST1000DM003 1TB (1/2)
ST1500DM003 1.5TB (2/3)
ST2000DM001 2TB (2/4) or (3/5 [800~GB/platter]) or (3/6 [667~GB/platter])*
ST2500DM001 2.5TB (3/5)
ST3000DM001 3TB (3/6)
*Like the similar WD Greens and Reds, the 2TB Barracuda ST2000DM001 can be found at random in a range of platter configurations - the 'perfect' two-platter version or two different three-platter models, which are slower and might also be less reliable. If you have an ST2000DM001 that weighs more than 600 grams, has a shallow (as opposed to deep and wide) depression on the cover (like this), and HD Tune reports a maximum read transfer rate of less than 190MB/s, you have a three-platter unit, and you may want to consider getting a refund.
*There seems to be another way to determine the platter count of an ST2000DM001 - by looking at the third character of the serial number. An 'E' seems to point to a two-platter unit. An 'F' seems to mark a three-platter one. For example, W1Exxxxxxx = two-platter, W1Fxxxxxxx = three-platter. Seagate might change this scheme at any moment, though, so watch out. Thanks to ~fzabkar for this info.
ST4000DM000 4TB (4/8)
Unknown Desktop HDD (SATA-600 interface)
ST5000DX000 5TB (5/10)
Some of LaCie's new external drives are shipping with these models. If you happen to find an official datasheet for this model, do let me know.
Desktop SSHD (64MB cache, 8GB SSD cache, SATA-600 interface)
ST1000DX001 1TB (7200 RPM) (1/2)
ST2000DX001 2TB (7200 RPM) (2/4)
ST4000DX001 4TB (5900 RPM) (4/8)
1.25TB/platter Section (all drives under here use platters that can hold 1.25TB of data apiece.)
Desktop HDD.15 (5900RPM, 128MB cache, SATA-600 interface, SMR recording)
ST5000DM000 5TB (4/8)
Seagate Enterprise
NL35 FC (7200RPM, FC-AL interface)
ST3400071FC 400GB (8MB Cache) (4/8)
NL35 (7200RPM, SATA-150 interface)
ST3250823NS 250GB (8MB Cache) (2/4)
ST3250623NS 250GB (16MB Cache) (2/4)
ST3400832NS 400GB (8MB Cache) (3/6)
ST3400632NS 400GB (16MB Cache) (3/6)
NL35.2 (7200RPM, SATA-300 interface)
ST3500841NS 500GB (8MB Cache) (4/8)
ST3500641NS 500GB (16MB Cache) (4/8)
ST3500071FC 500GB (8MB Cache) (4/8)
Barracuda ES (7200RPM, SATA-300 interface)
ST3250820NS 250GB (8MB Cache) (2/3)
ST3250620NS 250GB (16MB Cache) (2/3)
ST3320820NS 320GB (8MB Cache) (2/4)
ST3320620NS 320GB (16MB Cache) (2/4)
ST3500830NS 500GB (8MB Cache) (3/6)
ST3500630NS 500GB (16MB Cache) (3/6)
ST3750840NS 750GB (8MB Cache) (4/8)
ST3750640NS 750GB (16MB Cache) (4/8)
Barracuda ES.2 (7200RPM)
ST3250310NS 250GB (SATA-300, 16MB Cache) (1/2)
ST3500320NS 500GB (SATA-300, 16MB Cache) (2/4)
ST3500620SS 500GB (SAS, 32MB Cache) (2/4)
ST3750330NS 750GB (SATA-300, 16MB Cache) (3/6)
ST3750630SS 750GB (SAS, 32MB Cache) (3/6)
ST31000340NS 1TB (SATA-300, 16MB Cache) (4/8)
ST31000640SS 1TB (SAS, 32MB Cache) (4/8)
Constellation ES (7200RPM, SATA-300 interface)
ST3500514NS 500GB (32MB Cache) (1/2)
ST31000524NS 1TB (32MB Cache) (2/4)
ST32000644NS 2TB (64MB Cache) (4/8)
Constellation ES (7200RPM, 16MB cache, SAS-600 interface)
ST3500414SS 500GB (1/2)
ST3500415SS 500GB (128-bit Self-Encryption) (1/2)
ST3500416SS 500GB (128-bit FIPS Self-Encryption) (1/2)
ST31000424SS 1TB (2/4)
ST31000425SS 1TB (128-bit Self-Encryption) (2/4)
ST31000426SS 1TB (128-bit FIPS Self-Encryption) (2/4)
ST32000444SS 2TB (4/8)
ST32000445SS 2TB (128-bit Self-Encryption) (4/8)
ST32000446SS 2TB (128-bit FIPS Self-Encryption) (4/8)
Constellation ES (7200RPM, 64MB cache, SATA-600 interface)
ST500NM0011 500GB (1/2)
ST500NM0031 500GB (256-bit Self-Encryption) (1/2)
ST500NM0051 500GB (FIPS Self-Encryption) (1/2)
ST1000NM0011 1TB (2/4)
ST1000NM0031 1TB (256-bit Self-Encryption) (2/4)
ST1000NM0051 1TB (FIPS Self-Encryption) (2/4)
ST2000NM0011 2TB (4/8)
ST2000NM0031 2TB (256-bit Self-Encryption) (4/8)
ST2000NM0051 2TB (FIPS Self-Encryption) (4/8)
Constellation ES (7200RPM, 64MB cache, SAS-600 interface)
ST500NM0001 500GB (1/2)
ST500NM0021 500GB (256-bit Self-Encryption) (1/2)
ST500NM0041 500GB (FIPS Self-Encryption) (1/2)
ST1000NM0001 1TB (2/4)
ST1000NM0021 1TB (256-bit Self-Encryption) (2/4)
ST1000NM0041 1TB (FIPS Self-Encryption) (2/4)
ST2000NM0001 2TB (4/8)
ST2000NM0021 2TB (256-bit Self-Encryption) (4/8)
ST2000NM0041 2TB (FIPS Self-Encryption) (4/8)
Constellation ES.2 (7200RPM, 64MB cache, SATA-600 interface)
ST33000650NS 3TB (5/10)
ST33000651NS 3TB (Self-Encryption) (5/10)
Constellation ES.2 (7200RPM, 64MB cache, SAS-600 interface)
ST33000650SS 3TB (5/10)
ST33000651SS 3TB (Self-Encryption) (5/10)
Constellation ES.3/Enterprise Capacity (7200RPM, 128MB cache, SATA-600 interface)
ST1000NM0033 1TB (2/3 [short-stroked])
ST1000NM0053 1TB (Self-Encryption) (2/3 [short-stroked])
ST1000NM0103 1TB (Self-Encryption, ISE) (2/3 [short-stroked])
ST2000NM0033 2TB (3/5)
ST2000NM0053 2TB (Self-Encryption) (3/5)
ST2000NM0103 2TB (Self-Encryption, ISE) (3/5)
ST3000NM0033 3TB (4/8 [short-stroked])
ST3000NM0053 3TB (Self-Encryption) (4/8 [short-stroked])
ST3000NM0103 3TB (Self-Encryption, ISE) (4/8 [short-stroked])
ST4000NM0033 4TB (5/10)
ST4000NM0053 4TB (Self-Encryption) (5/10)
ST4000NM0103 4TB (Self-Encryption, ISE) (5/10)
Constellation ES.3/Enterprise Capacity (7200RPM, 128MB cache, SAS-600 interface)
ST1000NM0023 1TB (2/3 [short-stroked])
ST1000NM0043 1TB (Self-Encryption) (2/3 [short-stroked])
ST1000NM0113 1TB (Self-Encryption, ISE) (2/3 [short-stroked])
ST1000NM0063 1TB (FIPS Self-Encryption) (2/3 [short-stroked])
ST2000NM0023 2TB (3/5)
ST2000NM0043 2TB (Self-Encryption) (3/5)
ST2000NM0113 2TB (Self-Encryption, ISE) (3/5)
ST2000NM0063 2TB (FIPS Self-Encryption) (3/5)
ST3000NM0023 3TB (4/8 [short-stroked])
ST3000NM0043 3TB (Self-Encryption) (4/8 [short-stroked])
ST3000NM0113 3TB (Self-Encryption, ISE) (4/8 [short-stroked])
ST3000NM0063 3TB (FIPS Self-Encryption) (4/8 [short-stroked])
ST4000NM0023 4TB (5/10)
ST4000NM0043 4TB (Self-Encryption) (5/10)
ST4000NM0113 4TB (Self-Encryption, ISE) (5/10)
ST4000NM0063 4TB (FIPS Self-Encryption) (5/10)
Enterprise NAS HDD (7200RPM, 128MB cache, SATA-600 interface)
ST2000VN0001 2TB (3/5)
ST3000VN0001 3TB (4/8)
ST4000VN0001 4TB (5/10)
NAS HDD (5900RPM, 64MB cache, SATA-600 interface)
ST3000VN000 3TB (4/8)
Enterprise Capacity 3.5 HDD v4 (7200RPM, 128MB cache, SATA-600 interface)
ST6000NM0004 6TB (6/12)
ST6000NM0024 6TB (6/12)
ST6000NM0044 6TB (6/12)
ST6000NM0084 6TB (6/12)
Enterprise Capacity 3.5 HDD v4 (7200RPM, 128MB cache, SAS-1200 interface)
ST6000NM0014 6TB (6/12)
ST6000NM0034 6TB (6/12)
ST6000NM0054 6TB (6/12)
ST6000NM0104 6TB (6/12)
Constellation CS/Enterprise Value (7200RPM, 64MB cache, SATA-600 interface)
ST1000NC001 1TB (1/2)
ST1000NC000 1TB (Instant Secure Erase) (1/2)
ST2000NC001 2TB (2/4)
ST2000NC000 2TB (Instant Secure Erase) (2/4)
ST3000NC002 3TB (3/6)
ST3000NC000 3TB (Instant Secure Erase) (3/6)
Terascale HDD (5900RPM, 64MB cache, SATA-600 interface)
ST4000NC001 4TB (4/8)
ST4000NC000 4TB (Instant Secure Erase) (4/8)
ST5000VN0001 5TB (5/10)
ST6000VN0001 6TB (6/12)
ST2000VN000 2TB (2/4)
ST4000VN000 4TB (4/8)
Archive HDD (5900RPM, 128MB cache, SATA-600 interface, SMR recording)
ST6000AS0002 6TB (6/12)
ST6000AS0012 6TB (Self-encryption) (6/12)
ST5000AS0011 5TB (4/8)
ST5000AS0001 5TB (Self-encryption) (4/8)
1.33TB/platter Section (all drives under here use platters that can hold 1.33TB of data apiece.)
ST8000AS0002 8TB (6/12)
ST8000AS0012 8TB (Self-encryption) (6/12)
Toshiba 1,8
2GB/platter Section (all drives under here use platters that can hold 2GB of data apiece.)
01MPL (4200RPM, 256KB cache, PC Card ATA/66 interface)
MK2001MPL 2GB (1/2)
5GB/platter Section (all drives under here use platters that can hold 5GB of data apiece.)
02MPL (3990RPM, 256KB cache, PC Card ATA/66 interface)
MK5002MPL 5GB (1/2)
02MAL (4200RPM, 1MB cache, 44-pin ATA/66 interface)
MK5002MAL 5GB (1/2)
10GB/platter Section (all drives under here use platters that can hold 10GB of data apiece.)
03GAL (4200RPM, 512KB cache, 44-pin ATA/100 interface)
MK1003GAL 10GB (1/2)
03GAH (4200RPM, 512KB cache, 44-pin ATA/100 interface)
MK2003GAH 20GB (2/4)
20GB/platter Section (all drives under here use platters that can hold 20GB of data apiece.)
04GAL (4200RPM, 44-pin ATA/100 interface)
MK1504GAL 15GB [512KB cache] (1/2 [short-stroked])
MK2004GAL 20GB [2MB cache] (1/2)
04GAH (4200RPM, 2MB cache, 44-pin ATA/100 interface)
MK4004GAH 40GB (2/4)
30GB/platter Section (all drives under here use platters that can hold 30GB of data apiece.)
06GAL (4200RPM, 2MB cache, 44-pin ATA/100 interface)
MK2006GAL 20GB (1/2 [short-stroked])
MK3006GAL 30GB (1/2)
06GAH (4200RPM, 2MB cache, 44-pin ATA/100 interface)
MK4006GAH 40GB (2/3 [short-stroked])
MK6006GAH 60GB (2/4)
08GAL (4200RPM, 2MB cache, ZIF ATA/100 interface)
MK2008GAL 20GB (1/2 [short-stroked])
MK3008GAL 30GB (1/2)
08GAH (4200RPM, 2MB cache, ZIF ATA/100 interface)
MK4008GAH 40GB (2/3 [short-stroked])
MK6008GAH 60GB (2/4)
07GAL (4200RPM, 2MB cache, 44-pin ATA/100 interface)
MK4007GAL 40GB (1/2)
07GAH (4200RPM, 2/8MB cache, 44-pin ATA/100 interface)
MK8007GAH 80GB (2/4)
Note: different datasheets list different cache sizes for this drive.
09GAL (4200RPM, 8MB cache, ZIF ATA/100 interface)
MK4009GAL 40GB (1/2)
09GAH (4200RPM, 8MB cache, ZIF ATA/100 interface)
MK8009GAH 80GB (2/4)
11GAH (4200RPM, 8MB cache, ZIF ATA/100 interface)
MK1011GAH 100GB (2/4)
60GB/platter Section (all drives under here use platters that can hold 60GB of data apiece.)
14GAL (4200RPM, 2MB cache, ZIF ATA/100 interface)
MK6014GAL 60GB (1/2)
Note: this drive looks to be the older version of the MK6028GAL listed above.
14GAH (4200RPM, 8MB cache, ZIF ATA/100 interface)
MK1214GAH 120GB (2/4)
15GAA (3600RPM, 160KB cache, ZIF ATA/66 interface)
MK6015GAA 60GB (1/2)
28GAL (4200RPM, 2MB cache, ZIF ATA/100 interface)
MK6028GAL 60GB (1/2)
17GSG (5400RPM, 8MB cache, SATA-150 interface)
MK8017GSG 80GB (1/2)
MK1617GSG 160GB (2/4).
22GAA (3600RPM, 160KB cache, ZIF ATA/100 interface)
MK8022GAA 80GB (1/2)
*Note: I find the tiny cache (160KB) on this drive and the MK6015GAA a bit humorous, though Toshiba aimed these drives at CE applications only. PC vendors were probably advised to use the MK8025GAL instead. 80GB iPod Classics made use of MK8022GAA drives.
25GAL (4200RPM, 8MB cache, ZIF ATA/100 interface)
MK8025GAL 80GB (1/2)
26GCB (3600RPM, 160KB cache, ZIF ATA/100 interface)
MK1626GCB 160GB (2/4)
Note: This is the dual-platter version of the MK8022GAA, and retains the tiny cache among most other features.
120-125GB/platter Section (all drives under here use platters that can hold 120-125GB of data apiece.)
29GSG Series (5400RPM, 8MB cache, SATA-300 interface)
MK1229GSG 120GB (1/2)
MK1629GSG 160GB (2/3 [short-stroked])
MK2529GSG 250GB (2/4)
31GAL/31GAH Series (4200RPM, 8MB cache, ZIF ATA/100 interface)
MK8031GAL 80GB (1/2 [short-stroked])
MK1231GAL 120GB (1/2)*
MK2431GAH 240GB (2/4)**
*Note: This drive was used in the Microsoft Zune 120.
**Note: Yes it is an unusual capacity. Toshiba added 10 more gigabytes for the 29GSG model.
33GSG Series (5400RPM, 16MB cache, SATA-300 interface)
MK1633GSG 160GB (1/2)
MK2533GSG 250GB (2/4 [short-stroked])
MK3233GSG 320GB (2/4)
Note: with 16MB of cache, a 5400RPM spindle speed, a native SATA interface and 320GB of capacity on the flagship model, you can pretty much consider these the Velociraptors of the 1.8" drive world. Their performance is so far unknown, but you can bet it'll be way better than the 4200RPM ZIF models used in most 1.8" drive-toting computers.
34GAL Series (4200RPM, 8MB cache, ZIF ATA/100 interface)
MK6034GAL 60GB (1/1 [short-stroked])
MK8034GAL 80GB (1/1)
MK1234GAL 120GB (1/2 [short-stroked])
MK1634GAL 160GB (1/2)*
*Note: As far as I know, this drive is used in the new circa 2009 160GB iPod Classics.
35GSL Series (4200RPM, 8MB cache, SATA-300 interface)
MK1235GSL 120GB (1/2 [short-stroked])
Note: I'm not completely sure if these use 160 or 120GB platters, but I'm guessing 160GB as they came out with the 33GSG series above. You can consider this a "low end" version of the aforementioned 33GSGs, as it spins slower at 4200RPM and has 50% of the cache, but keeps the same interface.
36GAL Series (4200RPM, 2MB cache, ZIF ATA/100 interface)
MK6036GAL 60GB (1/1 [short-stroked]?)
Note: no publicly-available datasheet seems to exist for these, but you can find them on Ebay. My FSC Amilo UI 3520 netbook's BIOS throws a "Fixed Disk 0 Failure" with one of them in, though (it seemed to work fine in a USB 2.0 enclosure, so I don't think it was DOA; possibly just a strange quirk with the netbook?). Platter density is a tentative guess based on the family code (36GAL).
220GB/platter Section (all drives under here use platters that can hold 220GB of data apiece.)
39GSL Series (4200RPM, 16MB cache, LIF SATA-150 interface)
MK1639GSL 160GB (1/2 [short-stroked])
MK2039GSL 200GB (1/2 [short-stroked])
MK2239GSL 220GB (1/2)
Note: probably Toshiba's last 1.8" HDD family. They have not released anything new in this form factor since (as of Q2 2016).
Toshiba 2,5 6.4GB-120GB Platter
6.4GB/platter Section (all drives under here use platters that can hold 6.4GB of data apiece.)
11MAT (4200RPM, 1MB cache, ATA/66 interface, 8.45mm z-height instead of 9.5mm)
MK6411MAT 6GB (1/2)
12MAT (4200RPM, 1MB cache, ATA/66 interface, 8.45mm z-height instead of 9.5mm)
MK3212MAT 3GB (1/1)
MK6412MAT 6GB (1/2)
14MAP (4200RPM, 1MB cache, ATA/66 interface)
MK6014MAP 6GB (1/2 [short-stroked])
MK6414MAP 6GB (1/2)
14GAP (4200RPM, 1MB cache, ATA/66 interface)
MK6414GAP 6GB (1/2)
MK1214GAP 12GB (2/4)
14GAV (4200RPM, 1MB cache, ATA/66 interface)
MK1814GAV 18GB (3/6)
16GAP (4200RPM, 1MB cache, ATA/100 interface)
MK1016GAP 10GB (1/2)
MK1516GAP 15GB (2/3)
MK2016GAP 20GB (2/4)
15GB/platter Section (all drives under here use platters that can hold 15GB of data apiece.)
17GAP (4200RPM, ATA/100 interface)
MK1017GAP 10GB (256KB Cache) (1/2 [short-stroked])
MK1517GAP 15GB (2MB Cache) (1/2)
MK2017GAP 20GB (2MB Cache) (2/3 [short-stroked])
MK3017GAP 30GB (2MB Cache) (2/4)
17GAS (4200RPM, 2MB cache, ATA/100 interface)
MK1517GAS 15GB (1/2)
MK2017GAS 20GB (2/3 [short-stroked])
MK3017GAS 30GB (2/4)
18GAP (4200RPM, 2MB cache, ATA/100 interface)
MK1018GAP 10GB (1/1)
MK2018GAP 20GB (1/2)
MK3018GAP 30GB (2/3)
MK4018GAP 40GB (2/4)
18GAS (4200RPM, 2MB cache, ATA/100 interface)
MK1018GAS 10GB (1/1)
MK2018GAS 20GB (1/2)
MK3018GAS 30GB (2/3)
MK4018GAS 40GB (2/4)
Besides a few obvious exterior differences, FDB bearings instead of ball bearings and some seek timing improvements, there is not much to differentiate between the older 18GAP and newer 18GAS series of drives.
19GAX (5400RPM, 16MB cache, ATA/100 interface)
MK1019GAX 10GB (1/1)
MK2019GAX 20GB (1/2)
MK3019GAX 30GB (2/3)
MK4019GAX 40GB (2/4)
The Toshiba drives with larger-than-normal cache buffers are in the 26GAX, 22GAX and 19GAX series.
25GB/platter Section (all drives under here use platters that can hold 25GB of data apiece.)
24GAY (7200RPM, 16MB cache, ATA/100 interface)
MK5024GAY 50GB (2/4)
Note: One of the first 7200RPM laptop drives, together with Hitachi's Travelstar 7K60.
21GAS (4200RPM, 2MB cache, ATA/100 interface)
MK2021GAS 20GB (1/2 [short-stroked])
MK3021GAS 30GB (1/2)
MK4021GAS 40GB (2/3 [short-stroked])
MK6021GAS 60GB (2/4)
22GAX (5400RPM, 16MB cache, ATA/100 interface)
MK6022GAX 60GB (2/4)
23GAS (4200RPM, 2MB cache, ATA/100 interface)
MK4023GAS 40GB (1/2)
25GAS (4200RPM, 8MB cache, ATA/100 interface)
MK2025GAS 20GB (1/1)
MK3025GAS 30GB (1/2 [short-stroked])
MK4025GAS 40GB (1/2)
MK6025GAS 60GB (2/3)
MK8025GAS 80GB (2/4)
26GAX (5400RPM, 16MB cache, ATA/100 interface)
MK2026GAX 20GB (1/1)
MK3026GAX 30GB (1/2 [short-stroked])
MK4026GAX 40GB (1/2)
MK6026GAX 60GB (2/3)
MK8026GAX 80GB (2/4)
36GAC (4200RPM, 8MB cache, ATA/100 interface, Automotive-Grade)
MK4036GAC 40GB (1/2)
36GACE (4200RPM, 8MB cache, ATA/100 interface, Automotive-Grade)
MK4036GACE 40GB (1/2)
50GAC (4200RPM, 8MB cache, ATA/100 interface, Automotive-Grade)
MK4050GAC 40GB (1/2)
50GACE (4200RPM, 8MB cache, ATA/100 interface, Automotive-Grade)
MK4050GACE 40GB (1/2)
31GAS (4200RPM, 8MB cache, ATA/100 interface)
MK1031GAS 100GB (2/4)
32GAX (5400RPM, 8MB cache, ATA/100 interface)
MK4032GAX 40GB (1/2 [short-stroked])
MK6032GAX 60GB (2/3 [short-stroked])
MK8032GAX 80GB (2/4 [short-stroked])
MK1032GAX 100GB (2/4)
32GSX (5400RPM, 8MB cache, SATA-150 interface)
MK4032GSX 40GB (1/2 [short-stroked])
MK6032GSX 60GB (2/3 [short-stroked])
MK8032GSX 80GB (2/4 [short-stroked])
MK1032GSX 100GB (2/4)
34GAX (5400RPM, 8MB cache, ATA/100 interface)
MK6034GAX 60GB (1/2)
MK8034GAX 80GB (2/3 [short-stroked])
MK1234GAX 120GB (2/4)
34GSX (5400RPM, 8MB cache, SATA-150 interface)
MK4034GSX 40GB (1/2 [short-stroked])
MK6034GSX 60GB (1/2)
MK8034GSX 80GB (2/3 [short-stroked])
MK1034GSX 100GB (2/4 [short-stroked])
MK1234GSX 120GB (2/4)
37GSX (5400RPM, 8MB cache, SATA-300 interface)
MK6037GSX 60GB (1/2 [short-stroked])
MK8037GSX 80GB (1/2)
MK1237GSX 120GB (2/3)
MK1637GSX 160GB (2/4)
MK8050GAC 80GB (1/2)
MK8050GACE 80GB (1/2)
50GACY (4200RPM, 8MB cache, ATA/100 interface, Automotive-Grade)
MK8050GACY 80GB (1/2)
57GSC (4200RPM, 8MB cache, SATA-150 interface, Automotive-Grade)
MK8057GSC 80GB (1/2)
35GSS (4200RPM, 8MB cache, SATA-150 interface)
MK2035GSS 200GB (2/4)
49GSY (7200RPM, 16MB cache, SATA-300 interface)
MK8049GSY 80GB (1/2 [short-stroked])
MK1249GSY 120GB (2/3 [short-stroked])
MK1649GSY 160GB (2/4 [short-stroked])
MK2049GSY 200GB (2/4)
51GSY (7200RPM, 16MB cache, SATA-300 interface)
MK8051GSY 80GB (1/2 [short-stroked])
MK1251GSY 120GB (2/3 [short-stroked])
MK1651GSY 160GB (2/4 [short-stroked])
MK2051GSY 200GB (2/4)
120GB/platter Section (all drives under here use platters that can hold 120GB of data apiece.)
46GSX (5400RPM, 8MB cache, SATA-300 interface)
MK8046GSX 80GB (1/2 [short-stroked])
MK1246GSX 120GB (1/2)
MK1646GSX 160GB (2/3 [short-stroked])
MK2546GSX 250GB (2/4)
Toshiba 2,5 160GB Platter-Present
160GB/platter Section (all drives under here use platters that can hold 160GB of data apiece.)
52GSX (5400RPM, 8MB cache, SATA-300 interface)
MK8052GSX 80GB (1/1)
MK1252GSX 120GB (1/2 [short-stroked])
MK1652GSX 160GB (1/2)
MK2552GSX 250GB (2/4 [short-stroked])
MK3252GSX 320GB (2/4)
53GSX (5400RPM, 8MB cache, SATA-300 interface)
MK1253GSX 120GB (1/2 [short-stroked])
MK1653GSX 160GB (1/2)
MK2553GSX 250GB (2/4 [short-stroked])
MK3253GSX 320GB (2/4)
54GSY/F (7200RPM, 16MB cache, SATA-300 interface)
MK8054GSY 80GB (1/1)
MK8054GSYF 80GB (1/1)
MK1254GSY 120GB (1/2 [short-stroked])
MK1254GSYF 120GB (1/2 [short-stroked])
MK1654GSY 160GB (1/2)
MK1654GSYF 160GB (1/2)
MK2554GSY 250GB (2/4 [short-stroked])
MK2554GSYF 250GB (2/4 [short-stroked])
MK3254GSY 320GB (2/4)
MK3254GSYF 320GB (2/4)
Note: "F" code denotes free fall sensor-equipped models.
58GSX (5400RPM, 8MB cache, SATA-300 interface)
MK4058GSX 400GB (2/4)
55GSX/N (5400RPM, 8MB cache, SATA-300 interface)
MK1255GSX 120GB (1/1)
MK1255GSXN 120GB (1/1)
MK1655GSX 160GB (1/2 [short-stroked])
MK1655GSXN 160GB (1/2 [short-stroked])
MK2555GSX 250GB (1/2)
MK2555GSXN 250GB (1/2)
MK3255GSX 320GB (2/3 [short-stroked])
MK4055GSX 400GB (2/4)
MK5055GSX 500GB (2/4)
MK5055GSXN 500GB (2/4)
Note: "N" code possibly denotes a new revision.
63GSX/N (5400RPM, 8MB cache, SATA-300 interface)
MK3263GSX 320GB (2/3 [short-stroked])
MK3263GSXN 320GB (2/3 [short-stroked])
56GSY (7200RPM, 16MB cache, SATA-300 interface)
MK1656GSY 160GB (1/2 [short-stroked])
MK2556GSY 250GB (1/2)
MK3256GSY 320GB (2/3 [short-stroked])
MK5056GSY 500GB (2/4)
64GSY (7200RPM, 16MB cache, SATA-300 interface)
MK3264GSY 320GB (2/3 [short-stroked])
59GSX/P (5400RPM, 8MB cache, SATA-300 interface)
MK1259GSX 120GB (1/1)
MK1259GSXP 120GB (1/1)
MK2559GSX 250GB (1/2)
MK2559GSXP 250GB (1/2)
MK5059GSX 500GB (2/4)
MK5059GSXP 500GB (2/4)
Note: "P" code signifies the use of Advanced Format.
Note 2: not much is known about the 59GSX series, other than the fact that an MK6459GSX was discovered inside one of Toshiba's new 640GB enclosures by someone on the NotebookReview Forums, with the rest being listed on Toshiba's European "Register Online" site. These could perhaps be 65GSX variants with special firmware designed for use in an external case. Who knows.
59GSM/P (5400RPM, 8MB cache, SATA-300 interface, 12.5mm z-height)
MK7559GSM 750GB (3/6)
75GSX (5400RPM, 8MB cache, SATA-300 interface, Advanced Format)
MK2575GSX 250GB (1/2)
MK5075GSX 500GB (2/4)
Note: No clue just how different these are from the 59GSXP series. Maybe they're just improved versions, just like the 76GSXs are to the 65GSXs, or they are OEM-only versions. In any case, I've began to see the MK7575GSX first in a few recent (mid-November 2011) notebooks.
65GSX/F/N/V (5400RPM, 8MB cache, SATA-300 interface)
MK1265GSX 120GB (1/1)
MK2565GSX 250GB (1/2)
MK2565GSXF 250GB (1/2)
MK2565GSXN 250GB (1/2)
MK2565GSXV 250GB (1/2)
MK5065GSX 500GB (2/4)
MK5065GSXF 500GB (2/4)
MK5065GSXN 500GB (2/4)
Note: "F" code denotes free fall sensor-equipped models. "N" code possibly denotes a new revision. "V" code possibly denotes AV application-targeted models.
76GSX/N/Z (5400RPM, 8MB cache, SATA-300 interface)
MK1276GSX 120GB (1/1)
MK2576GSX 250GB (1/2)
MK2576GSXN 250GB (1/2)
MK2576GSXZ 250GB (1/2)
MK5076GSX 500GB (2/4)
MK5076GSXN 500GB (2/4)
MK5076GSXZ 500GB (2/4)
Note: "N" code possibly denotes a new revision. "Z" code denotes models rated for 24/7 operation.
Note 2: On Toshiba's product page for this series, the company claims that these drives "build upon the maturity of the Toshiba 320GB per-platter architecture to offer the same big storage capacities with enhanced quality and reliability." It seems that these are just updated versions of the 65GSX family, with the same specs but a more refined design.
61GSY/N/B/D/G (7200RPM, 16MB cache, SATA-300 interface)
MK8061GSYB 80GB (1/1 [short-stroked])
MK1661GSYB 160GB (1/2 [short-stroked])
MK2561GSY 250GB (1/2)
MK2561GSYN 250GB (1/2)
MK2561GSYB 250GB (1/2)
MK2561GSYD 250GB (1/2)
MK2561GSYG 250GB (1/2)
MK5061GSY 500GB (2/4)
MK5061GSYN 500GB (2/4)
MK5061GSYB 500GB (2/4)
MK5061GSYD 500GB (2/4)
MK5061GSYG 500GB (2/4)
Note: "N" code possibly denotes a new revision. "B" code denotes models rated for 24/7 operation. "D" code denotes models with AES-256 hardware encryption. "G" code denotes models with AES-256 hardware encryption and Toshiba Wipe Technology.
Note 2: The specs between 61GSY and 61GSYN on Toshiba's PDF datasheets are identical.
60GSC (4200RPM, 8MB cache, SATA-150 interface, Automotive-Grade)
MK1060GSC 100GB (1/1)
MK2060GSC 200GB (1/2)
60GSCX (4200RPM, 8MB cache, SATA-150 interface, Automotive-Grade)
MK1060GSCX 100GB (1/1)
MQ01AAD Series (4200RPM, 8MB cache, SATA-300 interface, Extreme Environment)
MQ01AAD010C 100GB (1/1)
MQ01AAD020C 200GB (1/2)
59GSX/F/P (5400RPM, 8MB cache, SATA-300 interface)
MK1659GSX 160GB (1/1)
MK1659GSXP 160GB (1/1)
MK3259GSX 320GB (1/2)
MK3259GSXP 320GB (1/2)
MK6459GSX 640GB (2/4)
MK6459GSXP 640GB (2/4)
MK7559GSXF 750GB (2/4)
MK7559GSXP 750GB (2/4)
Note: "F" code denotes free fall sensor-equipped models. "P" code signifies the use of Advanced Format.
MK1059GSM 1TB (3/6)
MK1059GSMP 1TB (3/6)
MK1675GSX 160GB (1/1)
MK3275GSX 320GB (1/2)
MK6475GSX 640GB (2/4)
MK7575GSX 750GB (2/4)
MK1665GSX 160GB (1/1)
MK1665GSXN 160GB (1/1)
MK1665GSXV 160GB (1/1)
MK3265GSX 320GB (1/2)
MK3265GSXF 320GB (1/2)
MK3265GSXN 320GB (1/2)
MK3265GSXV 320GB (1/2)
MK6465GSX 640GB (2/4)
MK6465GSXN 640GB (2/4)
76GSX/N (5400RPM, 8MB cache, SATA-300 interface)
MK1676GSX 160GB (1/1)
MK3276GSX 320GB (1/2)
MK3276GSXN 320GB (1/2)
MK6476GSX 640GB (2/4)
MK6476GSXN 640GB (2/4)
61GSY/N/D/G (7200RPM, 16MB cache, SATA-300 interface)
MK1661GSY 160GB (1/1)
MK1661GSYN 160GB (1/1)
MK1661GSYD 160GB (1/1)
MK1661GSYG 160GB (1/1)
MK3261GSY 320GB (1/2)
MK3261GSYN 320GB (1/2)
MK3261GSYD 320GB (1/2)
MK3261GSYG 320GB (1/2)
MK6461GSY 640GB (2/4)
MK6461GSYN 640GB (2/4)
MK6461GSYD 640GB (2/4)
MK6461GSYG 640GB (2/4)
Note: "N" code possibly denotes a new revision. "D" code denotes models with AES-256 hardware encryption. "G" code denotes models with AES-256 hardware encryption and Toshiba Wipe Technology.
MQ01ABDxxx/H/V/VS Series (5400RPM, 8MB cache, SATA-300 interface, Advanced Format)
MQ01ABD032 320GB (1/2)
MQ01ABD032V 320GB (1/2)
MQ01ABD032VS 320GB (1/2)
MQ01ABD064 640GB (2/4)
MQ01ABD075 750GB (2/4)
MQ01ABD075H 750GB (2/4)
Note: "H" code signifies hybrid capability (on-board flash memory). "V" code denotes AV application-targeted models. "VS" code denotes AV application-targeted models with STB DRM Authentication.
MQ01ABFxxx/H Series (5400RPM, 8MB cache, SATA-600 interface, Advanced Format, 7mm z-height)
MQ01ABF032 320GB (1/2)
MQ01ABF032H 320GB (1/2)
MQ02ABFxxx Series (5400RPM, 16MB cache, SATA-600 interface, Advanced Format, 7mm z-height)
MQ02ABF075 750GB (2/4)
MQ01ABUxxx/W/BW Series (5400RPM, 8MB cache, SATA-600 interface, Advanced Format, 7mm z-height)
MQ01ABU032W 320GB (1/2)
MQ01ABU032BW 320GB (1/2)
Note: "W" code denotes models with Toshiba Wipe Technology. "BW" code denotes models with Toshiba Wipe Technology and FIPS 140-2 Encryption.
MQ01ABCxxx Series (5400RPM, 8MB cache, SATA-300 interface, Advanced Format, 12.5mm z-height)
MQ01ABC100 1TB (3/6)
MQ01ACFxxx Series (7200RPM, 16MB cache, SATA-600 interface, Advanced Format, 7mm z-height)
MQ01ACF032 320GB (1/2)
MQ01AADxxx Series (4200RPM, 8MB cache, SATA-300 interface, Extreme Environment)
MQ01AAD032C 320GB (1/2)
MQ01ABDxxx/H/V/VS Series (5400RPM, SATA-300 interface, Advanced Format)
MQ01ABD025 250GB (1/1)
MQ01ABD025V 250GB (1/1)
MQ01ABD025VS 250GB (1/1)
MQ01ABD050 500GB (1/2)
MQ01ABD050V 500GB (1/2)
MQ01ABD050VS 500GB (1/2)
MQ01ABD100 1TB (2/4)
MQ01ABD100H 1TB (2/4)
MQ01ABD100V 1TB (2/4)
MQ01ABD100VS 1TB (2/4)
MQ02ABDxxx/H Series (5400RPM, 64MB cache, SATA-600 interface, Advanced Format)
MQ02ABD100H 1TB (2/4)
MQ01ABFxxx/H Series (5400RPM, SATA-600 interface, Advanced Format, 7mm z-height)
MQ01ABF025 250GB (1/1)
MQ01ABF050 500GB (1/2)
MQ01ABF050H 500GB (1/2)
MQ02ABFxxx/H Series (5400RPM, SATA-600 interface, Advanced Format, 7mm z-height)
MQ02ABF050H 500GB (1/2)
MQ02ABF100 1TB (2/4)
MQ01ABU050W 500GB (1/2)
MQ01ABU050BW 500GB (1/2)
MQ01ABC150 1.5TB (3/6)
MQ01ABBxxx Series (5400RPM, 8MB cache, SATA-300 interface, Advanced Format, 15mm z-height)
MQ01ABB200 2TB (4/8)
MQ03ABBxxx Series (5400RPM, 16MB cache, SATA-300 interface, Advanced Format, 15mm z-height)
MQ03ABB200 2TB (4/8)
MQ01ACF050 500GB (1/2)
750GB/platter Section (all drives under here use platters that can hold 750GB of data apiece.)
MQ03ABB Series (5400RPM, 16MB cache, SATA-600 interface, Advanced Format, 15mm z-height)
MQ03ABB300 3TB (4/8)
Toshiba 3,5
01TRKB (7200RPM, 16MB cache, SAS-600 interface, For Enterprise Applications)
MK1001TRKB 1TB (2/4)
MK2001TRKB 2TB (4/8)
02TSKB (7200RPM, 64MB cache, SATA-300 interface, For Enterprise Applications)
MK0502TSKB 500GB (1/2)
MK1002TSKB 1TB (2/4)
MK2002TSKB 2TB (4/8)
600GB/platter Section (all drives under here use platters that can hold 600GB of data apiece.)
MG03SCAxxx/MG03SCPxxx (7200RPM, 64MB cache, SAS-600 interface, For Enterprise Applications)
MG03SCA100 1TB (2/4 [short-stroked])
MG03SCP100 (Encryption) 1TB (2/4 [short-stroked])
MG03SCA200 2TB (4/8 [short-stroked])
MG03SCP200 (Encryption) 2TB (4/8 [short-stroked])
MG03ACAxxx/MG03ACAxxxY (7200RPM, 64MB cache, SATA-600 interface, For Enterprise Applications)
MG03ACA100 1TB (2/4 [short-stroked])
MG03ACA100Y (Encryption) 1TB (2/4 [short-stroked])
MG03ACA200 2TB (4/8 [short-stroked])
MG03ACA200Y (Encryption) 2TB (4/8 [short-stroked])
MD03ACAxxxV (7200RPM, 64MB cache, SATA-600 interface, For 24/7 Operation)
MD03ACA200V 2TB (4/8 [short-stroked])
MG04SCAxxxX (7200RPM, 64MB cache, SAS-600 interface, For Enterprise Applications)
MG04SCA200A (4KB Sectors) 2TB (4/8 [short-stroked])
MG04SCA200AY (4KB Sectors, Sanitize Instant Erase) 2TB (4/8 [short-stroked])
MG04SCA200E (512B Sector Emu) 2TB (4/8 [short-stroked])
MG04SCA200EY (512B Sector Emu, Sanitize Instant Erase) 2TB (4/8 [short-stroked])
MG04SCAxxXX (7200RPM, 128MB cache, SAS-1200 interface, For Enterprise Applications)
MG04SCA20EA (4KB Sectors) 2TB (4/8 [short-stroked])
MG04SCA20EE (512B Sector Emu) 2TB (4/8 [short-stroked])
MG04ACAxxxX (7200RPM, 128MB cache, SATA-600 interface, For Enterprise Applications)
MG04ACA200A (4KB Sectors) 2TB (4/8 [short-stroked])
MG04ACA200AY (4KB Sectors, Sanitize Instant Erase) 2TB (4/8 [short-stroked])
MG04ACA200E (512B Sector Emu) 2TB (4/8 [short-stroked])
MG04ACA200EY (512B Sector Emu, Sanitize Instant Erase) 2TB (4/8 [short-stroked])
MC04ACAxxxE (7200RPM, 128MB cache, SATA-600 interface, For Enterprise Applications)
MC04ACA200E 2TB (4/8 [short-stroked])
800GB/platter Section (all drives under here use platters that can hold 800GB of data apiece.)
MG03SCA300 3TB (4/8 [short-stroked])
MG03SCP300 (Encryption) 3TB (4/8 [short-stroked])
MG03SCA400 4TB (5/10)
MG03SCP400 (Encryption) 4TB (5/10)
MG03ACA300 3TB (4/8 [short-stroked])
MG03ACA300Y (Encryption) 3TB (4/8 [short-stroked])
MG03ACA400 4TB (5/10)
MG03ACA400Y (Encryption) 4TB (5/10)
MD03ACA300V 3TB (4/8 [short-stroked])
MD03ACA400V 4TB (5/10)
MC04ACA300E 3TB (4/8 [short-stroked])
MC04ACA400E 4TB (5/10)
MD04ABAxxxV (5400RPM, 128MB cache, SATA-600 interface)
MD04ABA400V 4TB (5/10)
MD04ACAxxx / X300 (7200RPM, 128MB cache, SATA-600 interface)
MD04ACA400/HDWE140 4TB (5/10)
MG04SCA300A (4KB Sectors) 3TB (4/8 [short-stroked])
MG04SCA300AY (4KB Sectors, Sanitize Instant Erase) 3TB (4/8 [short-stroked])
MG04SCA300E (512B Sector Emu) 3TB (4/8 [short-stroked])
MG04SCA300EY (512B Sector Emu, Sanitize Instant Erase) 3TB (4/8 [short-stroked])
MG04SCA400A (4KB Sectors) 4TB (5/10)
MG04SCA400AY (4KB Sectors, Sanitize Instant Erase) 4TB (5/10)
MG04SCA400E (512B Sector Emu) 4TB (5/10)
MG04SCA400EY (512B Sector Emu, Sanitize Instant Erase) 4TB (5/10)
MG04SCA40EA (4KB Sectors) 4TB (5/10)
MG04SCA40EE (512B Sector Emu) 4TB (5/10)
MG04ACA300A (4KB Sectors) 3TB (4/8 [short-stroked])
MG04ACA300AY (4KB Sectors, Sanitize Instant Erase) 3TB (4/8 [short-stroked])
MG04ACA300E (512B Sector Emu) 3TB (4/8 [short-stroked])
MG04ACA300EY (512B Sector Emu, Sanitize Instant Erase) 3TB (4/8 [short-stroked])
MG04ACA400A (4KB Sectors) 4TB (5/10)
MG04ACA400AY (4KB Sectors, Sanitize Instant Erase) 4TB (5/10)
MG04ACA400E (512B Sector Emu) 4TB (5/10)
MG04ACA400EY (512B Sector Emu, Sanitize Instant Erase) 4TB (5/10)
DT01ACAxxx / P300 (7200RPM, 32MB cache, SATA-600 interface)
DT01ACA025 250GB (1/1 [short-stroked])
DT01ACA032 320GB (1/1 [short-stroked])
DT01ACA050/HDWD105 500GB (1/1)
DT01ACA064 640GB (1/2)
DT01ACA075 750GB (1/2 [short-stroked])
DT01ACA100/HDWD110 1TB (1/2)
Note: Designed by Hitachi's Deskstar design team. These are relabeled Deskstar 7K1000.D's. Early batches of these units identify with 7K1000.D-specific model numbers and have the Hitachi logo (in addition to the Toshiba logo) on their labels.
DT01ACAxxx / P300 (7200RPM, 64MB cache, SATA-600 interface)
DT01ACA150 1.5TB (2/3)
DT01ACA200/HDWD120/HDS723020BLE640 2TB (2/4)
DT01ACA300/HDWD130/HDS723030BLE640 3TB (3/6)
Note: Designed by Hitachi's Deskstar design team. Early batches of these units identify with Hitachi-style model numbers and have the Hitachi logo (in addition to the Toshiba logo) on their labels. These were presumably to be released by Hitachi under a "Deskstar 7K3000.B" umbrella that never came to be.
DT01ABAxxx / E300 (5700RPM, 32MB cache, SATA-600 interface)
DT01ABA025 250GB (1/1 [short-stroked])
DT01ABA032 320GB (1/1 [short-stroked])
DT01ABA050/HDWA105 500GB (1/1)
DT01ABA075 750GB (1/2 [short-stroked])
DT01ABA100/HDWA110 1TB (1/2)
DT01ABA150 1.5TB (2/3)
DT01ABA200/HDWA120 2TB (2/4)
Note: Designed by Hitachi's Deskstar design team. Models up to 1TB are relabeled Deskstar 5K1000.B's.
DT01ABAxxx / E300 (5940RPM, 32MB cache, SATA-600 interface)
DT01ABA300/HDWA130 3TB (3/6)
DT01ACAxxxV (7200RPM, 32MB cache, SATA-600 interface, For CE Applications)
DT01ACA025V 250GB (1/1 [short-stroked])
DT01ACA032V 320GB (1/1 [short-stroked])
DT01ACA050V 500GB (1/1)
DT01ACA075V 750GB (1/2 [short-stroked])
DT01ACA100V 1TB (1/2)
Note: Designed by Hitachi's Deskstar design team. These are relabeled Cinemastar 7K1000.D's.
DT01ACAxxxV (7200RPM, 64MB cache, SATA-600 interface, For CE Applications)
DT01ACA150V 1.5TB (2/3)
DT01ACA200V 2TB (2/4)
DT01ACA300V 3TB (3/6)
DT01ABAxxxV (5700RPM, 32MB cache, SATA-600 interface, For CE Applications)
DT01ABA025V 250GB (1/1 [short-stroked])
DT01ABA032V 320GB (1/1 [short-stroked])
DT01ABA050V 500GB (1/1)
DT01ABA075V 750GB (1/2 [short-stroked])
DT01ABA100V 1TB (1/2)
DT01ABA150V 1.5TB (2/3)
DT01ABA200V 2TB (2/4)
Note: Designed by Hitachi's Deskstar design team. Models up to 1TB are relabeled Cinemastar 5K1000.B's.
DT01ABAxxxV (5940RPM, 32MB cache, SATA-600 interface, For CE Applications)
DT01ABA300V 3TB (3/6)
MC04ACA500E 5TB (5/10)
MD04ACA500/HDWE150 5TB (5/10)
MD04ACA600/HDWE160 6TB (6/12)
MD04ABA500V 5TB (5/10)
MG04SCA500A (4KB Sectors) 5TB (5/10)
MG04SCA500AY (4KB Sectors, Sanitize Instant Erase) 5TB (5/10)
MG04SCA500E (512B Sector Emu) 5TB (5/10)
MG04SCA500EY (512B Sector Emu, Sanitize Instant Erase) 5TB (5/10)
MG04SCA50EA (4KB Sectors) 5TB (5/10)
MG04SCA50EE (512B Sector Emu) 5TB (5/10)
MG04ACA500A (4KB Sectors) 5TB (5/10)
MG04ACA500AY (4KB Sectors, Sanitize Instant Erase) 5TB (5/10)
MG04ACA500E (512B Sector Emu) 5TB (5/10)
MG04ACA500EY (512B Sector Emu, Sanitize Instant Erase) 5TB (5/10)
1.2TB/platter Section (all drives under here use platters that can hold 1.2TB of data apiece.)
MG04SCA60EA (4KB Sectors) 6TB (5/10)
MG04SCA60EE (512B Sector Emu) 6TB (5/10)
MG04ACA600A (4KB Sectors) 6TB (5/10)
MG04ACA600E (512B Sector Emu) 6TB (5/10)
WD AV AV-GP
AV-GP (5400RPM, SATA-300 interface, for AV applications)
WD2500AVVS-? 250GB (8MB Cache) (1/2)
WD3200AVVS-? 320GB (8MB Cache) (2/4 [short-stroked])
WD5000AVVS-63ZWB0 500GB (8MB Cache) (2/4)
WD7500AVCS-00ZJB0 750GB (16MB Cache) (3/6)
WD10EVCS-63ZLB0/63E0B0 1TB (16MB Cache) (4/8)
320-334GB/platter Section (all drives under here use platters that can hold 320-334GB of data apiece.)
WD1600AVVS-00L2B0/63L2B0/73L2B0 160GB (8MB Cache) (1/1)
WD2500AVVS-00L2B0/63L2B0/73L2B0 250GB (8MB Cache) (1/2 [short-stroked])
WD3200AVVS-00L2B0/63L2B0/73L2B0 320GB (8MB Cache) (1/2)
WD5000AVVS-00H0B1/63H0B1 500GB (8MB Cache) (2/4 [short-stroked])
WD6400AVVS-63H0B1 640GB (8MB Cache) (2/4)
WD10EVVS-? 1TB (8MB Cache) (3/6)
WD10EVDS-63H5B1 1TB (32MB Cache) (3/6)
AV (7200RPM, 16MB cache, SATA-600 interface, for AV applications)
WD800AVKX-? 80GB (1/1 [short-stroked])
WD1600AVKX-635FY0 160GB (1/1 [short-stroked])
WD2500AVKX-635FY0 250GB (1/1)
WD3200AVKX-635FY0 320GB (1/2 [short-stroked])
WD5000AVKX-635FY0 500GB (1/2)
AV-GP (5400RPM, 32MB cache, SATA-300 interface)
WD6400AVVS-00G9B0/00G9B1 640GB (2/3 [short-stroked])
WD15EVDS-68V9B0 1.5TB (3/6)
WD20EVDS-63T3B0 2TB (4/8)
AV-GP (5400RPM, 64MB cache, SATA-300 interface)
WD7500AURS-? 750GB (2/3)
WD10EURS-630AB1 1TB (2/4)
WD15EURS-63S48Y0 1.5TB (3/6)
WD20EURS-63Z9B1 2TB (4/8)
AV-GP (5400RPM, 16MB cache, SATA-600 interface, Advanced Format)
WD10EUCX-63YZ1Y0 1TB (2/4)
667-750GB/platter Section (all drives under here use platters that can hold 667-750GB of data apiece.)
AV-GP (5400RPM, 64MB cache, SATA-300 interface, Advanced Format)
WD15EURS-63S48Y0 1.5TB (3/5 [short-stroked])
WD20EURS-63S48Y0 2TB (3/6)
WD25EURS-63R8UY0 2.5TB (4/7 [short-stroked])
WD30EURS-63R8UY0 3TB (4/8)
WD30EURS-63SPKY0 3TB (3/6)
AV-GP (5400RPM, 64MB cache, SATA-600 interface, Advanced Format)
WD10EURX-63FH1Y0 1TB (1/2)
WD20EURX-63T0FY0 2TB (2/4)
WD30EURX-63T0FY0 3TB (3/6)
WD40EURX-64WRWY0 4TB (4/8)
WD AV-25 2,5
320GB/platter Section (all drives under here use platters that can hold 320GB of data.)
WD AV-25 (5400RPM, 32MB cache, SATA-300, for CE use)
WD1600BUDT-73DPZY0 160GB (1/1)
WD2500BUDT-73DPZY0 250GB (1/2)
WD3200BUDT-73DPZY0 320GB (1/2)
WD5000BUDT-63G8FY0 500GB (2/4 [short-stoked])
WD AV-25 (5400RPM, 16MB cache, SATA-300, for CE use)
WD1600BUCT-63TWBY0 160GB (1/1)
WD2500BUCT-63TWBY0 250GB (1/2)
WD3200BUCT-63TWBY0 320GB (1/2)
WD5000BUCT-63PUZY0 500GB (2/4 [short-stoked])
500GB/platter Section (all drives under here use platters that can hold 500GB of data.)
WD5000LUCT-63Y8HY0 500GB (1/2)
WD10JUCT-63J6SY0 1TB (2/4)
WD Black
250GB/platter Section (all drives under here use platters that can hold 250GB of data.)
Caviar Black (7200RPM, 32MB cache, SATA-300 interface)
WD5001AALS-00L3B 500GB (2/4)
WD6401AALS-00J7B1 640GB (3/6 [short-stroked])*
*Note: Seems like a very early batch.
WD5001AALS-00L3B2*/00LWTA0 500GB (2/4 [short-stroked])
WD6401AALS-00L3B2/003B20/00E8B0 640GB (2/4)
WD7501AALS-xxJ7Bx/00E8B0 750GB (3/5 [short-stroked])
WD1001FALS-xxJ7Bx/00K1B0/00E8B0/00U9B0 1TB (3/6)
*Note: there are rumors on the internet about the WD5001AALS-00L3B2 having one 500GB platter. This is not true. This new revision appears to use 320GB/platters, two of them.
WD5001AALS-00E3A0 500GB (1/2)
WD7501AALS-xxE3Ax 750GB (2/3)
WD7502AALS-22E3A0 750GB (2/3)
WD1001FALS-00E3A0/00Y6A0 1TB (2/4)
WD1501FASS-00U0B0/00W2B0 1.5TB (3/6)
WD2001FASS-00U0B0/00W2B0 2TB (4/8)
Caviar Black (7200RPM, 64MB cache, SATA-300 interface)
WD1001FAES-xxW7Ax/xxZ2Ax 1TB (2/4)
Caviar Black (7200RPM, 32MB cache, SATA-600 interface)
WD5002AALX-00J37A0 500GB (1/2)
Caviar Black (7200RPM, 64MB cache, SATA-600 interface)
WD5002AAEX-xxY9Ax 500GB (1/2)
WD6402AAEX-00Z3A0/00Y9A0 640GB (2/3 [short-stroked])
WD7502AAEX-00Z3A0/00Y9A0 750GB (2/3)
WD1002FAEX-007BA0/00Z3A0/00Y9A0 1TB (2/4)
WD1502FAEX-007BA0 1.5TB (3/6)
WD2002FAEX-007BA0 2TB (4/8)
800GB/platter Section (all drives under here use platters that can hold 800GB of data.)
WD3001FAEX-00MJRA0 3TB (4/8 [short-stroked])
WD4001FAEX-00MJRA0 4TB (5/10)
Caviar Black (7200RPM, 64MB cache, SATA-600 interface, Advanced Format)
WD2003FZEX-00Z4SA0 2TB (3/6 [short-stroked])
WD3003FZEX-00Z4SA0 3TB (4/8 [short-stroked])
WD4003FZEX-00Z4SA0 4TB (5/10)
1TB/platter Section (all drives under here use platters that can hold 1TB of data.)
WD5003AZEX-00K1GA0/00RKKA0 500GB (1/1)
WD1003FZEX-00MK2A0 1TB (1/2)
WD Blue SE SE16
80-83GB/platter Section (all drives under here use platters that can hold 80-83GB of data apiece.)
Caviar (7200RPM, 2MB cache, ATA-100 interface)
WD400BB-xxJHCx/xxFRAx/xxFJAx 40GB (1/1)
WD400LB-xxDNAx 40GB (1/1)
WD600BB-xxJHAx 60GB (1/2 [short-stroked])
WD600LB-xxDNAx 60GB (1/2 [short-stroked])
WD800BB-xxJHCx/xxFRAx/xxFJAx 80GB (1/2)
WD800LB-xxDNAx 80GB (1/2)
WD1200BB-xxDWAx/xxFTAx/xxGUAx/xxGUCx/xxRDAx 120GB (2/3)
WD1200LB-xxEDAx 120GB (2/3)
WD1600BB-xxDWAx/xxFTAx/xxGUAx/xxGUCx/xxRDAx 160GB (2/4)
WD1600LB-xxEDAx 160GB (2/4)
WD2000BB-xxDWAx/xxFTAx/xxGUAx/xxGUCx/xxRDAx 200GB (3/5)
WD2000LB-xxEDAx 200GB (3/5)
WD2500BB-xxDWAx/xxFTAx/xxGUAx/xxGUCx/xxRDAx 250GB (3/6)
WD2500LB-xxEDAx 250GB (3/6)
Caviar (7200RPM, 2MB cache, SATA-150 interface)
WD400BD-xxJMAx/xxJMCx/xxJPAx/xxLRAx/xxLTAx/xxMRAx 40GB (1/1)
WD800BD-xxJMAx/xxJMCx/xxLRAx/xxMRAx 80GB (1/2)
Caviar SE (7200RPM, 8MB cache, ATA-100 interface)
WD400JB-xxFMAx/xxFSAx/xxJJAx/xxJJCx 40GB (1/1)
WD400PB-xxEPAx 40GB (1/1)
WD800JB-xxFMAx/xxFSAx/xxJJAx/xxJJCx 80GB (1/2)
WD800PB-xxEPAx 80GB (1/2)
WD1200JB-xxEVAx/xxFUAx/xxGVAx/xxGVCx/xxREAx 120GB (2/3)
WD1200PB-xxFBAx 120GB (2/3)
WD1600JB-xxEVAx/xxFUAx/xxGVAx/xxGVCx/xxREAx 160GB (2/4)
WD1600PB-xxFBAx 160GB (2/4)
WD2000JB-xxEVAx/xxFUAx/xxGVAx/xxGVCx/xxREAx 200GB (3/5)
WD2000PB-xxFBAx 200GB (3/5)
WD2500JB-xxEVAx/xxFUAx/xxGVAx/xxGVCx/xxREAx 250GB (3/6)
WD2500PB-xxFBAx 250GB (3/6)
Caviar SE (7200RPM, 8MB cache, SATA-150 interface)
WD400JD-xxHKAx/xxJNAx/xxJNCx/xxLSAx/xxMSAx 40GB (1/1)
WD800JD-xxHKAx/xxJNAx/xxJNCx/xxJRAx/xxJRCx/xxLUAx/xxLSAx/xxMUAx/xxMSAx 80GB (1/2)
WD1200JD-xxFYBx/xxGBBx/xxHBBx/xxHBCx 120GB (2/3)
WD1200PD-xxFZBx 120GB (2/3)
WD1600JD-xxFYBx/xxGBBx/xxHBBx/xxHBCx 160GB (2/4)
WD1600PD-xxFZBx 160GB (2/4)
WD2000JD-xxFYBx/xxGBBx/xxHBBx/xxHBCx 200GB (3/5)
WD2000PD-xxFZBx 200GB (3/5)
WD2500JD-xxFYBx/xxGBBx/xxHBBx/xxHBCx 250GB (3/6)
WD2500PD-xxFZBx 250GB (3/6)
Caviar SE (7200RPM, 8MB cache, SATA-300 interface)
WD800AAJS-xxTDAx 80GB (1/2)
WD1200JS-xxMHBx/xxNCBx/xxSGBx/xxMVBx 120GB (2/3)
WD1600JS-xxMHBx/xxNCBx/xxNGBx/xxSGBx/xxTGBx/xxMVBx 160GB (2/4)
WD2000JS-xxMHBx/xxNCBx/xxSGBx/xxMVBx 200GB (3/5)
WD2500JS-xxMHBx/xxNCBx/xxNGBx/xxSGBx/xxTGBx/xxMVBx 250GB (3/6)
Caviar SE16 (7200RPM, 16MB cache, SATA-300 interface)
WD2000KS-xxMJBx 200GB (3/5)
WD2500KS-xxMJBx 250GB (3/6)
100-107GB/platter Section (all drives under here use platters that can hold 100-107GB of data apiece.)
WD2000BB-xxKEAx 200GB (2/4)
WD2500BB-xxKEAx 250GB (3/5)
WD3000BB-xxKEAx 300GB (3/6 [short-stroked])
WD3200BB-xxKEAx 320GB (3/6)
WD2000JB-xxKFAx 200GB (2/4)
WD2500JB-xxKFAx 250GB (3/5)
WD3000JB-xxKFAx 300GB (3/6 [short-stroked])
WD3200JB-xxKFAx 320GB (3/6)
WD2000JD-xxKLBx 200GB (2/4)
WD2500JD-xxKLBx 250GB (3/5)
WD3000JD-xxKLBx 300GB (3/6 [short-stroked])
WD3200JD-xxKLBx 320GB (3/6)
WD2000JS-xxPDBx 200GB (2/4)
WD2500JS-xxPDBx 250GB (3/5)
WD3000JS-xxPDBx 300GB (3/6 [short-stroked])
WD3200JS-xxPDBx 320GB (3/6)
Caviar SE16 (7200RPM, 16MB cache, SATA-150 interface)
WD4000KD-xxNABx/xxNSBx 400GB (4/8)
WD3200KS-xxPFBx 320GB (3/6)
125GB/platter Section (all drives under here use platters that can hold 125GB of data apiece.)
WD4000KS-xxMNBx 400GB (4/7 [short-stroked])
WD5000KS-xxMNBx 500GB (4/8)
160-167GB/platter Section (all drives under here use platters that can hold 160-167GB of data apiece.)
WD1600AABB-xxPUAx 160GB (1/2)
Caviar (7200RPM, 2MB cache, SATA-300 interface)
WD1600AABS-xxPRAx 160GB (1/2)
WD1600AAJB-xxPVAx 160GB (1/2)
WD2500AAJB-xxTYAx 250GB (2/4 [short-stroked])
WD3200AAJB-xxTYAx 320GB (2/4)
WD4000AAJB-xxUHAx/xxYRAx 400GB (3/5)
WD5000AAJB-xxUHAx/xxYRAx 500GB (3/6)
WD800AAJS-xxPSAx/xxWAAx 80GB (1/1)
WD1600AAJS-xxPSAx/xxWAAx/xxRYAx 160GB (1/2)
WD2500AAJS-xxRYAx/xxYFAx/xxVWAx 250GB (2/4 [short-stroked])
WD3200AAJS-xxRYAx/xxYFAx/xxVWAx 320GB (2/4)
WD4000AAJS-xxTKAx/xxYFAx 400GB (3/5)
WD5000AAJS-xxTKAx/xxYFAx 500GB (3/6)
Caviar SE16 (7200RPM, 16MB cache, ATA-100 interface)
WD3200AAKB-xxUAAx/xxWHAx 320GB (2/4)
WD4000AAKB-xxUKAx/xxYSAx 400GB (3/5)
WD5000AAKB-xxUKAx/xxYSAx 500GB (3/6)
WD2500AAKS-xxYGAx/xxSBAx/xxC9Ax 250GB (2/4 [short-stroked])
WD3200AAKS-xxTMAx/xxYGAx/xxSBAx/xxC9Ax 320GB (2/4)
WD4000AAKS-xxTMAx/xxYGAx 400GB (3/5)
WD5000AAKS-xxTMAx/xxYGAx 500GB (3/6)
188GB/platter Section (all drives under here use platters that can hold 188GB of data apiece.)
WD7500AAKS-xxRBAx 750GB (4/8)
250GB/platter Section (all drives under here use platters that can hold 250GB of data apiece.)
WD1200AAJS-xxVTAx 120GB (1/1)
WD2500AAJS-xxVTAx 250GB (1/2)
Caviar SE16/Blue (7200RPM, 16MB cache, SATA-300 interface)
WD2500AAKS-xxVSAx 250GB (1/2)
WD4000AAKS-xxC8Ax 400GB (2/4 [short-stroked])
WD5000AAKS-xxC8Ax 500GB (2/4)
Caviar/Blue (7200RPM, 2MB cache, SATA-300 interface)
WD1600AABS-xxH4Ax 160GB (1/1)
Caviar SE/Blue (7200RPM, 8MB cache, ATA-100 interface)
WD1600AAJB-xxJ3Ax 160GB (1/1)
WD2500AAJB-xxJ3Ax 250GB (1/2 [short-stroked])
WD3200AAJB-xxJ3Ax 320GB (1/2)
Caviar SE/Blue (7200RPM, 8MB cache, SATA-300 interface)
WD800AAJS-xxB4Ax/xxL7Ax 80GB (1/1 [short-stroked])
WD1600AAJS-xxB4Ax/xxV4Ax/xxL7Ax/xxG0Ax 160GB (1/1)
WD2500AAJS-xxB4Ax/xxV4Ax/xxL7Ax/xxG0Ax 250GB (1/2 [short-stroked])
WD3200AAJS-xxB4Ax/xxV4Ax/xxL7Ax/xxG0Ax 320GB (1/2)
WD5000AAJS-xxA8Bx 500GB (2/4 [short-stroked])
Caviar SE16/Blue (7200RPM, 16MB cache, ATA-100 interface)
WD5000AAKB-xxH8Ax 500GB (2/4 [short-stroked])
WD1600AAKS-xxB3Ax/xxL9Ax/xxL6Ax 160GB (1/1)
WD2500AAKS-xxB3Ax/xxL9Ax/xxL6Ax 250GB (1/2 [short-stroked])
WD3200AAKS-xxB3Ax/xxL9Ax/xxL6Ax/xxG3Ax 320GB (1/2)
WD4000AAKS-xxA7Bx/xxH2Bx 400GB (2/3 [short-stroked])
WD5000AAKS-xxA7Bx/xxH2Bx/xxZ7Bx/xxE4Ax/xxD2Bx/xx7AAx 500GB (2/4 [short-stroked])
WD6400AAKS-xxA7Bx/xxH2Bx/xxZ7Bx/xxE4Ax 640GB (2/4)
Caviar Blue (7200RPM, 16MB cache, SATA-600 interface)
WD5000AAKX-329BA0 500GB (2/4 [short-stroked])
500GB/platter Section (all drives under here use platters that can hold 500GB of data apiece.)
Caviar Blue (7200RPM, 8MB cache, ATA-100 interface)
WD3200AAJB-? 320GB (1/2 [short-stroked])
Caviar Blue (7200RPM, 8MB cache, SATA-300 interface)
WD800AAJS-xxM0Ax 80GB (1/1 [short-stroked])
WD1600AAJS-xxM0Ax/00YZCA0 160GB (1/1 [short-stroked])
WD2500AAJS-xxM0Ax/00YZCA0 250GB (1/1)
WD3200AAJS-xxM0Ax/00YZCA0 320GB (1/2 [short-stroked])
Caviar Blue (7200RPM, 16MB cache, SATA-300 interface)
WD2500AAKS-xxV1Ax/xxV6Ax/xxWWPAx/xxUU3Ax/xxF0Ax 250GB (1/1)
WD3200AAKS-xxV1Ax/xxV6Ax/xxWWPAx/xxUU3Ax/xxF0Ax/xxM9Ax 320GB (1/2 [short-stroked])
WD5000AAKS-xxV1Ax/xxV6Ax/xxWWPAx/xxUU3Ax/xxV0Ax/xxM9Ax 500GB (1/2)
Caviar Blue (7200RPM, 32MB cache, SATA-300 interface)
WD10EALS-xxZ8Ax/xx2BAx 1TB (2/4)
WD2500AAKX-xx1CAx/xx3CAx/xxERMAx/xxU6AAx 250GB (1/1)
WD3200AAKX-xx1CAx/xx3CAx/xxERMAx/xxU6AAx 320GB (1/2 [short-stroked])
WD5000AAKX-xx1CAx/xx3CAx/xxERMAx/xxU6AAx 500GB (1/2)
Caviar Blue (7200RPM, 32MB cache, SATA-600 interface)
WD7500AALX-xx9BAx 750GB (2/3)
WD10EALX-xx9BAx 1TB (2/4)
1TB/platter Section (all drives under here use platters that can hold 1TB of data apiece.)
WD3200AZKX-xxD6NAx 320GB (1/1 [short-stroked])
WD5000AZKX-xxD6NAx 500GB (1/1)
WD5000AZLX-xxK4KAx 500GB (1/1)
Blue (7200RPM, 64MB cache, SATA-600 interface)
WD7500AZEX-xxRKKAx/xxZF5Ax/xxBN5Ax 750GB (1/2 [short-stroked])
WD10EZEX-xxRKKAx/xxZF5Ax/xxBN5Ax/xxKUWAx 1TB (1/2)
Blue (5400RPM, 64MB cache, SATA-600 interface)
WD5000AZRZ-xxHTKBx 500GB (1/1)
WD10EZRZ-xxHTKBx 1TB (1/2)
WD20EZRZ-xxZ5HBx 2TB (2/4)
WD30EZRZ-xxZ5HBx 3TB (3/6)
WD40EZRZ-xxWN9Bx 4TB (4/8)
WD50EZRZ-xxRWYBx 5TB (5/10)
Blue SSHD (5400RPM, 64MB cache, 8GB NAND cache, SATA-600 interface)
WD40E31X-xxHY4Ax 4TB (4/8)
WD60EZRZ-xxRWYBx 6TB (5/10)
WD Green 2,5
375GB/platter Section (all drives under here use platters that can hold 375GB of data.)
WD Green (5???RPM, 8MB cache, SATA-300 interface)
WD15NPVT-00Z2TT0 1.5TB (4/8)
WD20NPVT-00Z2TT0 2TB (4/8)
WD Green (5???RPM, 8MB cache, SATA-600 interface)
WD20NPVX-00EA4T0 2TB (4/8)
WD Green
Caviar GP (5400RPM, 8MB cache, SATA-300 interface)
WD3200AAVS-xxZTBx 320GB (2/3 [short-stroked])
WD5000AAVS-xxZTBx 500GB (2/4)
Caviar GP (5400RPM, 16MB cache, SATA-300 interface)
WD5000AACS-xxZUBx 500GB (2/4)
WD7500AACS-xxZJBx 750GB (3/6)
WD10EACS-xxZJBx 1TB (4/8)
320-375GB/platter Section (all drives under here use platters that can hold 320-375GB of data.)
Caviar Green (5400RPM, 8MB cache, SATA-300 interface)
WD5000AAVS-xxG9Bx 500GB (2/4 [short-stroked])
WD6400AAVS-xxG9Bx 640GB (2/4)
WD7500AAVS-xxD7Bx 750GB (3/5 [short-stroked])
WD10EAVS-xxD7Bx 1TB (3/6)
Caviar Green/GP (5400RPM, 16MB cache, SATA-300 interface)
WD5000AACS-xxG8Bx 500GB (2/4 [short-stroked])
WD6400AACS-xxG8Bx 640GB (2/4)
WD7500AACS-xxD6Bx 750GB (3/5 [short-stroked])
WD10EACS-xxD6Bx 1TB (3/6)
Caviar Green (5400RPM, 32MB cache, SATA-300 interface)
WD5000AADS-xxL4Bx 500GB (2/4 [short-stroked])
WD7500AADS-xxL5Bx 750GB (3/5 [short-stroked])
WD8088AADS-xxL5Bx 808.8GB (3/6 [short-stroked])*
WD10EADS-xxL5Bx 1TB (3/6)
*Note: What an unusual capacity this drive has. WD sold these as "lucky" drives in China because of the amount of 8s making up the capacity, though it seems some people (not necessarily in China) have also gotten the drives sent to them as replacements for RMA'd units of similar capacity.
WD5000AAVS-xxN7Bx 500GB (1/2)
WD5000AADS-xxS9Bx 500GB (1/2)
WD6400AADS-xxM2Bx 640GB (2/3 [short-stroked])
WD7500AADS-xxM2Bx 750GB (2/3)
WD10EADS-xxP8Bx/xxM2Bx 1TB (2/4)
WD15EADS-xxP8Bx/xxR2Bx 1.5TB (3/6)
WD15EADS-xxR6Bx/xxS2Bx/xxW4Bx/xxH7Bx 1.5TB (4/7 [short-stroked])
WD20EADS-xxR6Bx/xxS2Bx/xxW4Bx 2TB (4/8)
Caviar Green (5400RPM, 32MB cache, SATA-300 interface, Advanced Format)
WD5000AADS-11M2B2 500GB (1/2)
WD6400AADS-11M2B2 640GB (2/3 [short-stroked])
WD7500AADS-11M2B2 750GB (2/3)
WD10EADS-11M2B2 1TB (2/4)
Caviar Green (5400RPM, 64MB cache, SATA-300 interface, Advanced Format)
WD5000AARS-xxY5Bx/xx3BBx 500GB (1/2)
WD6400AARS-xxY5Bx/xx3BBx 640GB (2/3 [short-stroked])
WD7500AARS-xxY5Bx/xx3BBx 750GB (2/3)
WD8000AARS-xxY5Bx 800GB (2/4 [short-stroked])
WD10EARS-xxY5Bx/xx3BBx 1TB (2/4)
WD15EARS-xxS8Bx/00J2GB0/xxZ5Bx 1.5TB (3/6)*
WD20EARS-xxS8Bx/00J2GB0/42S0XB0 2TB (4/8)*
*Note: I have noticed something a little odd with the xxS8Bx and 00J2GB0 revision WD15EARS and WD20EARS. They share the same quad-platter casing (hinting four platters inside), yet supposedly the WD15EARS uses one less platter, as both drives have near identical HD Tune read results (from the screenshots that I have seen). I suppose WD just decided to use the quad-platter casing to house this three-platter drive, for whatever reason. The WD15EARS-xxZ5Bx models, in contrast, use the three-platter casing.
Caviar Green (5400RPM, 32MB cache, SATA-600 interface)
WD10EADX-xxTDHBx 1TB (2/4)
Caviar Green (5400RPM, 64MB cache, SATA-600 interface, Advanced Format)
WD15EARX-xxZUDBx 1.5TB (3/6)
WD20EARX-xxZUDBx 2TB (4/8)
640-750GB/platter Section (all drives under here use platters that can hold 640-750GB of data.)
Caviar Green (5400RPM, 16MB cache, SATA-300 interface, Advanced Format)
WD15EACS-11BHUB0 1.5TB (3/5 [short-stroked])
WD20EACS-11BHUB0 2TB (3/6)
WD10EARS-xxMVWBx 1TB (2/3)
WD15EARS-xxMVWBx 1.5TB (3/5 [short-stroked])
WD20EARS-xxMVWBx 2TB (3/6)
WD20EARS-xxJ99Bx 2TB (4/7 [short-stroked])
WD25EZRS-xxJ99Bx 2.5TB (4/7)
WD30EZRS-xxJ99Bx 3TB (4/8)
WD7500AARX-xxN0YBx 750GB (2/3 [short-stroked])
WD10EARX-xxN0YBx 1TB (2/3)
WD15EARX-xxPASBx 1.5TB (3/5 [short-stroked])
WD20EARX-xxPASBx 2TB (3/6)
WD20EARX-xxMMMBx/xxAZ6Bx 2TB (3/6?)*
WD25EZRX-xxMMMBx/xxAZ6Bx 2.5TB (4/7 [short-stroked])
WD30EZRX-xxMMMBx/xxAZ6Bx 3TB (4/8)
Like some WD15EARS and WD20EARS models listed earlier, there appears to be a version of the WD20EARX that shares the WD30EZRX/WD25EZRX units' four-platter chassis and identifier code (xxMMMBx). It's unclear whether these models retain the 3/6 configuration of the WD20EARX-xxPASBx models, or if they use four short-stroked or lower density platters.
Caviar Green (5400RPM, 64MB cache, SATA-600 interface)
WD20EARX-xx8FBx 2TB (3/6)
1TB/platter Section (all drives under here use platters that can hold 1TB of data each.)
Caviar Green (5400RPM, 32MB cache, SATA-600 interface, Advanced Format)
WD3200AZDX-xxSC2Bx 320GB (1/1 [short-stroked])
WD5000AZDX-xxSC2Bx 500GB (1/1)
WD3200AZRX-xxA8LBx 320GB (1/1 [short-stroked])
WD5000AZRX-xxA8LBx 500GB (1/1)
WD7500AZRX-xxA8LBx 750GB (1/2 [short-stroked])
WD10EZRX-xxA8LBx 1TB (1/2)
WD20EZRX-xxDC0Bx/xxD8PBx 2TB (2/4)/(3/6 [667+GB/platter])*
WD30EZRX-xxDC0Bx/xxD8PBx/00SPEB0 3TB (3/6)**
WD40EZRX-xxSPEBx 4TB (4/8)
WD50EZRX-xxMVLBx 5TB (5/10)
*Note: Just like the new Seagate ST2000DM001 2TB drives, two different platter configurations of the 2TB WD20EZRX appear to be floating around, with no easy way to tell the difference other than weight (a 640~ gram weight seems to signal three platters). Of course, the dual-platter version is the one to get.
**Note: there's some confusion surrounding the WD30EZRX with 00SPEB0 model code. It uses WD's four-platter casing, unlike the other 1TB/platter WD30EZRX models, and looks physically identical to the WD40EZRX-xxSPEBx models. It's unclear whether or not it incorporates three 1TB platters, or four 750GB platters. Buyer beware!
1.2TB/platter Section (all drives under here use platters that can hold 1.2TB of data each.)
WD60EZRX-xxMVLBx 6TB (5/10)
WD RE RE-GP SE
RE2 (7200RPM, 16MB cache, SATA-300 interface, for RAID applications)
WD4001ABYS-01YNA0 400GB (2/4 [short-stroked])
WD5001ABYS-01YNA0 500GB (2/4)
WD7500AYYS-01RCA0 750GB (3/6)
RE2-GP (5400RPM, 16MB cache, SATA-300 interface, for RAID applications)
WD5000ABPS-01ZZB0 500GB (2/4)
WD7500AYPS-01ZKB0 750GB (3/6)
WD1000FYPS-01ZKB0 1TB (4/8)
RE SAS/S35 (7200RPM, 32MB cache, SAS 6Gbps interface)
WD1000FYYG-01A21V0 1TB (4/8)
WD3201ABYS-01B9A0 320GB (1/2)
WD5001ABYS-01B1B 500GB (2/4 [short-stroked])
RE3 (7200RPM, SATA-300 interface, for RAID applications)
WD2502ABYS-01B7A0 250GB (16MB Cache) (1/2 [short-stroked])
WD3202ABYS-01B7A0 320GB (16MB Cache) (1/2)
WD5002ABYS-01B1B0/02B1B0/70B1B0 500GB (16MB Cache) (2/4 [short-stroked])
WD7502ABYS-01A6B0/18A6B0 750GB (32MB Cache) (3/5 [short-stroked])
WD1002FBYS-01A6B0/02A6B0/70A6B0 1TB (32MB Cache) (3/6)
Note: The RE3 series is kinda interesting as it is based upon two different kinds of drives. The first three sizes are based on Caviar Blues with 16MB of cache, while the 750 and 1TB models are based on the Caviar Black models with 32MB of cache.
RE4 (7200RPM, 64MB cache, SATA-300 interface)
WD1503FYYS-02W0B0/01T8B0 1.5TB (4/8)
RE4-GP (5400RPM, 64MB cache, SATA-300 interface)
WD1502FYPS-02W3B0 1.5TB (4/8)
RE3 (7200RPM, 32MB cache, SATA-300 interface)
WD2002FBYS-? 2TB (4/8)
WD2503ABYX-01WERA0 250GB (1/1)
WD5003ABYX-01WERA0 500GB (1/2)
WD1003FBYX-01Y7B1 1TB (2/4)
WD2003FYYS-01T8B0 2TB (4/8)
RE4 (7200RPM, 64MB cache, SATA-600 interface)
WD2503ABYZ-? 250GB (1/1)
WD5003ABYZ-011FA0 500GB (1/2)
WD1003FBYZ-010FB0 1TB (2/4)
WD2002FYPS-01U1B/02W3B0 2TB (4/8)
WD2000FYYG-01A21V0 2TB (4/8)
RE (7200RPM, 64MB cache, SATA-600 interface)
WD2000FYYZ-01UL1B0 2TB (4/8 [short-stroked])
WD200MFYYZ-? 2TB (5/10 [short-stroked])
WD3000FYYZ-01UL1B0 3TB (5/10)
RE SAS (7200RPM, 32MB cache, SAS-600 interface)
WD1001FYYG-01SL3W0 1TB (2/4 [short-stroked])
WD2001FYYG-01SL3W0 2TB (4/8 [short-stroked])
WD200MFYYG-? 2TB (5/10 [short-stroked])
WD3001FYYG-01SL3W0 3TB (5/10)
SE (7200RPM, 64MB cache, SATA-600 interface)
WD2000F9YZ-09N20L0 2TB (4/8 [short-stroked])
WD3000F9YZ-09N20L0 3TB (5/10)
WD4000FYYZ-01UL1B0 4TB (5/10)
WD4001FYYG-01SL3W0 4TB (5/10)
WD4000F9YZ-09N20L0 4TB (5/10)
RE+ (5760RPM, 128MB cache, SATA-600 interface)
WD5005FRPZ-? 5TB (5/10)
SE (7200RPM, 128MB cache, SATA-600 interface)
WD1002F9YZ-09H1JL0 1TB (1/2)
WD6005FRPZ-? 6TB (5/10)
WD Red 2,5
375GB/platter Section (all drives under here use platters that can hold 375GB of data apiece.)
Red (5400RPM, 16MB cache, SATA-600 interface)
WD7500BFCX-68N6GN0 750GB (2/4)
WD10JFCX-68N6GN0 1TB (2/4)
WD Red Purple
Red Pro (7200RPM, 64MB cache, SATA-600 interface)
WD2001FFSX-68JNUN0 2TB (4/8 [short-stroked])
WD3001FFSX-68JNUN0 3TB (5/10)
WD4001FFSX-68JNUN0 4TB (5/10)
Red (5400RPM, 64MB cache, SATA-600 interface)
WD10EFRX-68JCSN0/68PJCN0 1TB (1/2)
WD20EFRX-68AX9N0/68EUZN0 2TB (2/4) OR (3/6 [667GB+/platter])*
WD30EFRX-68AX9N0/68EUZN0 3TB (3/6)
WD40EFRX-68WT0N0 4TB (4/8)
WD50EFRX-68MYMN1 5TB (5/10)
*WD being annoying by introducing inferior drives into the market without changing the model code. Just like the new Seagate 2TB drives, be prepared to roll the dice if you purchase one of these online. You'll either get the slower three-platter variant (which weighs around 640 grams) or the "perfect" (lighter) two-platter one, at least until WD gets its 1TB platter production up to spec.
Purple (5400RPM, 64MB cache, SATA-600 interface, for surveillance applications)
WD10PURX-64D85Y0 1TB (1/2)
WD20PURX-64P6ZY0 2TB (2/4)
WD30PURX-64P6ZY0 3TB (3/6)
WD40PURX-64GVNY0 4TB (4/8)
WD60EFRX-68MYMN0/68TGBN1 6TB (5/10)
WD Scorpio Black
Scorpio Black (7200RPM, 16MB cache, SATA-300 interface)
WD800BEKT-00F3T0/66F3T2 80GB (1/1)
WD1200BEKT-60F3T0 120GB (1/2 [short-stroked])
WD1600BEKT-00F3T0/22F3T0/60F3T1/66F3T2/60V5T1 160GB (1/2)
WD2500BEKT-00F3T0/22F3T0/60F3T0/66F3T2/75F3T0/60F3T1/60V5T1 250GB (2/4 [short-stroked])
WD3200BEKT-00F3T0/22F3T0/60F3T0/75F3T0/60F3T1/60V5T1 320GB (2/4)
WD800BJKT-75F4T0 80GB (1/1)
WD1200BJKT-? 120GB (1/2 [short-stroked])
WD1600BJKT-00F4T0/22F4T0/75F4T0 160GB (1/2)
WD2500BJKT-00F4T0/22F4T0/75F4T0 250GB (2/4 [short-stroked])
WD3200BJKT-00F4T0/22F4T0/75F4T0 320GB (2/4)
Note: models with the BJKT have a free-fall sensor installed.
WD1600BEKT-00A25T0/60A25T/75A25T0 160GB (1/2 [short-stroked])
WD2500BEKT-00A25T0/60A25T/75A25T0/00A25T1 250GB (1/2)
WD3200BEKT-00KA9T0/22KA9T0/60KA9T0/22A25T1 320GB (2/3 [short-stroked])
WD5000BEKT-00KA9T0/22KA9T0/24KA9T0/60KA9T0/75KA9T0/80KA9T0 500GB (2/4)
WD1600BEKT-60PVMT0/66PVMT0/75PVMT0 160GB (1/1)
WD1600BJKT-00PVMT0 160GB (1/1)
WD2500BEKT-00PVMT0/22PVMT0/60PVMT0/66PVMT0/75PVMT0 250GB (1/2 [short-stroked])
WD3200BEKT-00PVMT0/22PVMT0/60PVMT0/66PVMT0/75PVMT0/08PVMT1 320GB (1/2)
WD5000BPKT-00PK4T0/75PK4T0/80PK4T0 500GB (2/4 [short-stroked])
WD7500BPKT-00PK4T0/22PK4T0/75PK4T0 750GB (2/4)
Note: models with the BJKT code have a free-fall sensor installed. Models with the BPKT code use Advanced Format (4K) sectors.
Scorpio Black (7200RPM, 16MB cache, SATA-600 interface)
WD1600BEKX-00B7WT0 160GB (1/1)
WD2500BEKX-00B7WT0 250GB (1/2 [short-stroked])
WD3200BEKX-00B7WT0/22B7WT0/75B7WT0 320GB (1/2)
WD5000BPKX-00HPJT0/22HPJT0/60HPJT0/75HPJT0/80HPJT0 500GB (2/4 [short-stroked])
WD7500BPKX-00HPJT0/22HPJT0/60HPJT0/75HPJT0/80HPJT0 750GB (2/4)
Note: models with the BPKX code use Advanced Format (4K) sectors.
Black (7200RPM, 32MB cache, SATA-600 interface, 7mm z-height)
WD3200LPLX-? 320GB (1/2)
WD2500LPLX-? 250GB (1/1)
WD5000LPLX-? 500GB (1/2)
Black² Dual-Drive (5400RPM, 120GB onboard SSD, SATA-600 interface)
WD1001X06X-00SJVT0 1TB (2/4)
Black SSHD (24GB flash cache)
WD5000M13K-? 500GB (1/2)
WD Scorpio Blue
160GB/platter Section (all drives under here use platters that can hold 160GB of data.)
Scorpio Blue (ML160) (5400RPM, 8MB cache, BEVE=IDE, BEVS=SATA-150, BEVT=SATA-300)
WD800BEVE-00A0HT0 80GB (1/1)
WD800BEVT-00ZCT0/22ZCT0/75ZCT2/00ZCT2 80GB (1/1)
WD1200BEVS-00VAT0/22VAT0 120GB (1/2)
WD1200BEVT-00ZCT0/22ZCT0/60ZCT1/75ZCT2 120GB (1/2)
WD1600BEVS-00VAT0/22VAT0/08VAT1/60VAT0 160GB (1/2)
WD1600BEVT-00ZCT0/22ZCT0/60ZCT0/75ZCT0/35ZCT1/60ZCT1/75ZCT1/75ZCT2/11A23T0 160GB (1/2)
WD2500BEVE-00A0HT0 320GB (2/4)
WD2500BEVS-00VAT0/22VAT0/16VAT0/26VAT0 250GB (2/4)
WD2500BEVT-00ZCT0/22ZCT0/11ZCT0/60ZCT1/75ZCT2 250GB (2/4)
WD3200BEVE-00A0HT0 320GB (2/4)
WD3200BEVS-00VAT0/22VAT0/16VAT0/26VAT0/60VAT0 320GB (2/4)
WD3200BEVT-00ZCT0/22ZCT0/11ZCT0/35ZCT0/60ZCT0/75ZCT0/35ZCT1/60ZCT1/75ZCT1/75ZCT2 320GB (2/4)
Scorpio Blue (5400RPM, 8MB cache, SATA-300)
WD2500BEVT-00ZAT0/22ZAT0 250GB (1/2)
WD3200BEVT-00ZAT0/22ZAT0 320GB (2/3)
WD4000BEVT-00ZAT0/22ZAT0 400GB (2/4)
WD5000BEVT-00ZAT0/22ZAT0/11ZAT0/60ZAT0/75ZAT0/00ZAT1 500GB (2/4)
WD7500KEVT-00A28T0 750GB (3/6) (5200RPM)
WD7500KPVT-65HT5T0 (Advanced Format) 750GB (3/6)
Scorpio Blue w/ Advanced Format (7200RPM, 8MB cache, SATA-300)
WD5000BPVT-00KPFT0 500GB (2/4)
WD once released a certain number of WD5000BPVT drives with 7200 RPM spindles and the unique '00KPFT0' code. Why? Who knows. Perhaps it was some sort of weird mistake at the factory; perhaps they were being generous. Either way, lucky buyers got a free upgrade.
WD1200BEVT-11A23T0 120GB (1/1)
WD1600BEVT-00A23T0/22A23T0/60A23T0/75A23T0/80A23T0 160GB (1/1)
WD2500BEVT-00A23T0/22A23T0/25A23T0/60A23T0/75A23T0/80A23T0 250GB (1/2)
WD3200BEVT-00A23T0/22A23T0/60A23T0/75A23T0/00A0RT0/80A0RT0/80A0RT1 320GB (1/2)
WD5000BEVT-00A03T0/11A03T0/00A0RT0/22A0RT0/75A0RT0/80A0RT0/80A0RT1 500GB (2/4)
WD6400BEVT-00A0RT0/22A0RT0/60A0RT0/75A0RT0/80A0RT0 640GB (2/4)
WD10TEVT-00A28T0 (334GB/platter) 1TB (3/6)
Note: The WD10TEVT and WD7500KEVT were the very first 750GB and 1TB 2.5" notebook drives ever! Both are 12.5mm high though and spin at 5200RPM. The 750GB model uses 250GB models instead of 334GB platters like the 1TB model, apparently.
Scorpio Blue w/ Advanced Format (5400RPM, 8MB cache, SATA-300)
WD1600BPVT-00ZEST0/22ZEST0/00JJ5T0/22JJ5T0 160GB (1/1)
WD2500BPVT-00ZEST0/22ZEST0/80ZEST0/00JJ5T0/22JJ5T0/75JJ5T0 250GB (1/2)
WD3200BPVT-00ZEST0/22ZEST0/75ZEST0/80ZEST0/00JJ5T0/22JJ5T0/08JJ5T0/60JJ5T0/75JJ5T0/80JJ5T0 320GB (1/2)
WD5000BPVT-00HXZT0/00HXZT1/22HXZT1/75HXZT1/80HXZT1 500GB (2/4)
WD6400BPVT-00HXZT0/22HXZT0/22HXZT0/00HXZT1/22HXZT1/60HXZT1/75HXZT1/80HXZT1 640GB (2/4)
WD7500BPVT-00HXZT0/22HXZT0/00HXZT1/22HXZT1/60HXZT1/80HXZT1 (375GB/platter) 750GB (2/4)
WD10TPVT-00HT5T0/65HT5T0/00HT5T1 (334GB/platter) 1TB (3/6)
WD5000BPVT-00A1YT0/22A1YT0/08A1YT0/60A1YT0/75A1YT0 500GB (1/2)
WD7500BPVT-00A1YT0/22A1YT0/08A1YT0/75A1YT0 750GB (2/3)
WD10JPVT-00A1YT0/22A1YT0/08A1YT0/60A1YT0/75A1YT0 1TB (2/4)
Scorpio Blue w/ Advanced Format (5400RPM, 8MB cache, SATA-600)
WD5000BPVX-? 500GB (1/2)
WD7500BPVX-22JC3T0/75JC3T0 750GB (2/3)
WD10JPVX-00JC3T0/22JC3T0/75JC3T0 1TB (2/4)
Scorpio Blue [7mm-height] (5400RPM, 8MB cache, SATA-300)
WD2500LPVT-00G33T0 250GB (1/1)
WD3200LPVT-00G33T0/22G33T0 320GB (1/2)
WD5000LPVT-00G33T0/22G33T0/75G33T0 500GB (1/2)
Scorpio Blue [7mm-height] (5400RPM, 8MB cache, SATA-600)
WD2500LPVX-? 250GB (1/1)
WD3200LPVX-00V0TT0/22V0TT0/08V0TT2/75V0TT0 320GB (1/2)
WD5000LPVX-00V0TT0/22V0TT0/75V0TT0 500GB (1/2)
Blue UltraSlim [5mm-height] (5400RPM, 16MB cache, SATA-600)
WD5000MPCK-00AWHT0/22AWHT0/60AWHT0 500GB (1/2)
Blue Slim [7mm-height] (5400RPM, 16MB cache, SATA-600)
WD7500LPCX-? 750GB (2/4)
WD10SPCX-00HWST0/22HWST0 1TB (2/4)
WD VelociRaptor
150-160GB/platter Section (all drives under here use platters that can hold 150-160GB of data apiece.)
Velociraptor (10,000RPM, 16MB cache, SATA-300 interface)
WD3000GLFS (Older IcePak) 300GB (2/4)
WD740HLFS (IcePak) 74GB (1/1)
WD1500HLFS (IcePak) 150GB (1/2)
WD3000HLFS (IcePak) 300GB (2/4)
WD740BLFS (No IcePak) 74GB (1/1)
WD1500BLFS (No IcePak) 150GB (1/2)
WD3000BLFS (No IcePak) 300GB (2/4)
WD800HLFS (IcePak, Dell exclusive) 80GB (1/1)
WD1600HLFS (IcePak, Dell exclusive) 160GB (1/2)
200GB/platter Section (all drives under here use platters that can hold 200GB of data apiece.)
Velociraptor (10,000RPM, 32MB cache, SATA-600 interface)
WD1500HLHX (IcePak) 150GB (1/2 [short-stroked])
WD3000HLHX (IcePak) 300GB (2/3)
WD4500HLHX (IcePak) 450GB (3/5 [short-stroked])
WD6000HLHX (IcePak) 600GB (3/6)
WD1500BLHX (No IcePak) 150GB (1/2 [short-stroked])
WD3000BLHX (No IcePak) 300GB (2/3)
WD4500BLHX (No IcePak) 450GB (3/5 [short-stroked])
WD6000BLHX (No IcePak) 600GB (3/6)
WD1600HLHX (IcePak, Dell/HP exclusive) 160GB (1/2 [short-stroked])
WD1600BLHX (No IcePak, Dell/HP exclusive) 160GB (1/2 [short-stroked])
Velociraptor (10,000RPM, 64MB cache, SATA-600 interface)
WD2500HHTZ (IcePak) 250GB (1/2)
WD5000HHTZ (IcePak) 500GB (2/4)
WD2500BHTZ (No IcePak) 250GB (1/2)
WD5000BHTZ (No IcePak) 500GB (2/4)
334GB/platter Section (all drives under here use platters that can hold 334GB of data apiece.)
WD1000DHTZ (IcePak) 1TB (3/6)
WD1000CHTZ (No IcePak) 1TB (3/6)
