Hogyan állítsuk be transmission alatt a maximum aktív torrentek számát?
Találtam egy scriptet amit a cronnal ütemezve elméletileg lekorlátozza a maximum torrentek számát.
Szükséges hozzá a transmission-cli is a működéséhez.
Maga a script (innen is le lehet tölteni):
#!/bin/sh
# Configuration
REMOTE="/usr/bin/transmission-remote"
USERNAME="felhasznalonev_helye"
PASSWORD="jelszo_helye"
MAXDOWN="maximum_letoltesek_szama"
MAXACTIVE="maximum_osszes_fel/le_toltes_szama"
CONFIG="/config_fajl_eleresi_utvonala/settings.json"
# Set-up variables
CMD="$REMOTE --auth $USERNAME:$PASSWORD"
LOGCMD="/usr/bin/logger -t transmission-queue "
MAXRATIO=$(cat $CONFIG | grep \"ratio-limit\":)
MAXRATIO=${MAXRATIO#*\"ratio-limit\": }
MAXRATIO=${MAXRATIO%*, }
# deal with downloads
DOWNACTIVE="$($CMD -l | tail +2 | grep -v -e 100% -e Sum -e Stopped | wc -l)"
if [ $MAXDOWN -lt $DOWNACTIVE ]; then
DOWNTOSTOP="$($CMD -l | tail +2 | grep -v -e 100% -e Sum -e Stopped | \
tail -n $(expr $DOWNACTIVE - $MAXDOWN) | awk '{ print $1; }')"
for ID in $DOWNTOSTOP; do
NAME="$($CMD --torrent $ID --info | grep Name:)"
$LOGCMD "<<< $ID: ${NAME#*Name: }"
$CMD --torrent $ID --stop >> /dev/null 2>&1
done
else
[ $(expr $MAXDOWN - $DOWNACTIVE) -gt 0 ] && (
DOWNINACTIVE="$($CMD -l | tail +2 | grep -v 100% | grep Stopped | wc -l)"
[ $DOWNINACTIVE -gt 0 ] && (
DOWNTOSTART="$($CMD -l | tail +2 | grep -v 100% | grep Stopped | \
head -n $(expr $MAXDOWN - $DOWNACTIVE) | awk '{ print $1; }')"
for ID in $DOWNTOSTART; do
$LOGCMD ">>> $ID: ${NAME#*Name: }"
$CMD --torrent $ID --start >> /dev/null 2>&1
done
fi
# Then deal with total active
ACTIVE="$($CMD -l | tail +2 | grep -v Sum | grep -v Stopped | wc -l)"
if [ $MAXACTIVE -lt $ACTIVE ]; then
TOSTOP="$($CMD -l | tail +2 | grep 100% | grep -v Stopped | \
tail -n $(expr $ACTIVE - $MAXACTIVE) | awk '{ print $1; }')"
for ID in $TOSTOP; do
done
else
[ $(expr $MAXACTIVE - $ACTIVE) -gt 0 ] && (
SEEDINACTIVE="$($CMD -l | tail +2 | grep 100% | grep Stopped | \
awk -v ratio=$MAXRATIO '{ if (strtonum(substr($0,52,4)) < ratio) print $0 ;}' | wc -l)"
[ $SEEDINACTIVE -gt 0 ] && (
TOSTART="$($CMD -l | tail +2 | grep 100% | grep Stopped | \
awk -v ratio=$MAXRATIO '{ if (strtonum(substr($0,52,4)) < ratio) print $0 ;}' | \
head -n $(expr $MAXACTIVE - $ACTIVE) | awk '{ print $1; }')"
for ID in $TOSTART; do
done
fi
A configuration részt mindenki szerkessze át olyanra, amilyenre kell. :)
A fájlt mentsük egy tetszőleges helyre. Majd tegyük futtathatóvá.
chmod a+x script
Próbáljuk ki, hogy működik-e.
./script
Majd ütemezzük!
crontab -e
És másoljuk bele a következő sort! Ez 5 percenként futtatja a scriptet.
*/5 * * * * /home/script
Mentsük el! Vi alatt:
ESC + :wq! + ENTER
Sikerült megoldani, működik 100%-osan.
Elsősorban openwrt alá készült.
http://tothszabi.info
