NVIDIA GeForce GTX 690 információk, képek
The only difference between the two setups is the slightly lower speed at which the GTX 690 operates at. Instead of a 1006MHz Base Clock and 1058MHz Boost Clock, it makes do with slightly more pedestrian 915 / 1019Mhz speeds.
A cikk, képek, és további infók elérhetőek ITT!
