Postfix-SASL Fail2Ban jegyzet
/etc/fail2ban/filter.d/postfix-sasl.conf
# Fail2Ban filter for postfix authentication failures
[INCLUDES]
before = common.conf
[Definition]
_daemon = postfix(-\w+)?/(?:submission/|smtps/)?smtp[ds]
failregex = ^%(__prefix_line)swarning: [-._\w]+\[<HOST>\]: SASL ((?i)LOGIN|PLAIN|(?:CRAM|DIGEST)-MD5) authentication failed(:[ A-Za-z0-9+/:]*={0,2})?\s*$
ignoreregex = authentication failed: Connection lost to authentication server$
[Init]
journalmatch = _SYSTEMD_UNIT=postfix.service
# Author: Yaroslav Halchenko
/etc/fail2ban/jail.local
[postfix-sasl]
enabled = true
port = smtp
filter = postfix-sasl
logpath = /var/log/mail.log
maxretry = 3 #Max 3 próbálkozás
bantime = 7200 #Másodperc alapú tiltás
/etc/fail2ban/jail.conf
[postfix-sasl]
filter = postfix[mode=auth]
port = smtp,465,submission,imap,imaps,pop3,pop3s
# You might consider monitoring /var/log/mail.warn instead if you are
# running postfix since it would provide the same log lines at the
# "warn" level but overall at the smaller filesize.
logpath = %(postfix_log)s
backend = %(postfix_backend)s
/etc/fail2ban/filter.d/postfix.conf
# Fail2Ban filter for selected Postfix SMTP rejections
[INCLUDES]
# Read common prefixes. If any customizations available -- read them from
# common.local
[Definition]
_daemon = postfix(-\w+)?/\w+(?:/smtp[ds])?
_port = (?::\d+)?
prefregex = ^%(__prefix_line)s<mdpr-<mode>> <F-CONTENT>.+</F-CONTENT>$
mdpr-normal = (?:(?:\w+): reject:|improper command pipelining after \S+)
mdre-normal=^RCPT from [^[]*\[<HOST>\]%(_port)s: 55[04] 5\.7\.1\s
^RCPT from [^[]*\[<HOST>\]%(_port)s: 45[04] 4\.7\.1 (?:Service unavailable\b|Client host rejected: cannot find your (reverse )?hostname\b)
^RCPT from [^[]*\[<HOST>\]%(_port)s: 450 4\.7\.1 (<[^>]*>)?: Helo command rejected: Host not found\b
^EHLO from [^[]*\[<HOST>\]%(_port)s: 504 5\.5\.2 (<[^>]*>)?: Helo command rejected: need fully-qualified hostname\b
^(RCPT|VRFY) from [^[]*\[<HOST>\]%(_port)s: 550 5\.1\.1\s
^RCPT from [^[]*\[<HOST>\]%(_port)s: 450 4\.1\.8 (<[^>]*>)?: Sender address rejected: Domain not found\b
^from [^[]*\[<HOST>\]%(_port)s:?
mdpr-auth = warning:
mdre-auth = ^[^[]*\[<HOST>\]%(_port)s: SASL ((?i)LOGIN|PLAIN|(?:CRAM|DIGEST)-MD5) authentication failed:(?! Connection lost to authentication server| Invalid authentication mechanism)
mdre-auth2= ^[^[]*\[<HOST>\]%(_port)s: SASL ((?i)LOGIN|PLAIN|(?:CRAM|DIGEST)-MD5) authentication failed:(?! Connection lost to authentication server)
# todo: check/remove "Invalid authentication mechanism" from ignore list, if gh-1243 will get finished (see gh-1297).
# Mode "rbl" currently included in mode "normal", but if needed for jail "postfix-rbl" only:
mdpr-rbl = %(mdpr-normal)s
mdre-rbl = ^RCPT from [^[]*\[<HOST>\]%(_port)s: [45]54 [45]\.7\.1 Service unavailable; Client host \[\S+\] blocked\b
# Mode "rbl" currently included in mode "normal" (within 1st rule)
mdpr-more = %(mdpr-normal)s
mdre-more = %(mdre-normal)s
mdpr-ddos = lost connection after(?! DATA) [A-Z]+
mdre-ddos = ^from [^[]*\[<HOST>\]%(_port)s:?
mdpr-extra = (?:%(mdpr-auth)s|%(mdpr-normal)s)
mdre-extra = %(mdre-auth)s
%(mdre-normal)s
mdpr-aggressive = (?:%(mdpr-auth)s|%(mdpr-normal)s|%(mdpr-ddos)s)
mdre-aggressive = %(mdre-auth2)s
%(mdre-normal)s
failregex = <mdre-<mode>>
# Parameter "mode": more (default combines normal and rbl), auth, normal, rbl, ddos, extra or aggressive (combines all)
# Usage example (for jail.local):
# [postfix]
# mode = aggressive
# # or another jail (rewrite filter parameters of jail):
# [postfix-rbl]
# filter = postfix[mode=rbl]
mode = more
ignoreregex =
[Init]
# Author: Cyril Jaquier
Légy az első hozzászóló!
Hozzászólok
