Add file:
/etc/amavis/conf.d/90-custom
with this content:
Code:
use strict;
# Place your configuration directives here. They will override those in
# earlier files.
# See /usr/share/doc/amavisd-new/ for documentation and examples of
# the directives you can use in this file
$max_servers = 1;
#------------ Do not modify anything below this line -------------
1; # insure a defined return
and then restart amavis.
in postfix master.cf, change the line:
amavis unix - - - - 2 smtp
to:
amavis unix - - - - 1 smtp
and restart postfix.
