A Zil 134 egy prototípus volt, ebből fejlesztették ki, a ZiL 135-öt, túl sok információ nincs róla, mert csak pár darab létezett belőle, amit tudni kell róla , hogy egy ismeretlen típusú 12 hengeres motor szolgáltatta a 240Le-őt, és 14 tonnát nyomott. Hasmagassága 50cm.
Zil 134:
History of development:
Based on the results of tests of prototype ZiS-E134 and other experimental design vehicles with high terrain průchodivostí team was headed by VAGračevem in Special Design Bureau (СКБ - Специальное конструкторское бюро) ZIL automobile was designed in January 1957 produced a four-axis auto truck ZIL-134 (АТК -6 Artillery event. truck tractor - round).
Peculiarities of construction:
For new vehicles were specially constructed motor drive, hydro-mechanical three-stage automatic transmission, the distributor of the main automatic differential lock, the entire chassis with independent suspension all wheels and prolonged operation of the rocking members cushioning, articulated Raceways and hub reduction drive in the wheel hubs, hydraulic power steering, Hermetic hydropneumatic brake, start the heater / preheater, 16,00-20 tire "and the system of centralized control of pressure in them and lots of other" specialties ".
As the author of the original article says, "nothing like that until it was unknown not only in the Soviet Union, but imagine, even in the world" ...
