MC-HF24 is an extraordinary offer on the multimedia speakers market. Unlike many popular computer multimedia speaker sets it doesn't use sub-woofer unit to generate low frequency sound. Whole frequency range is generated with 2 satellite speakers. Thanks to such solution also low frequencies are player in stereo sound mode (in 2.1 sets only 1 speaker is used for low frequencies). Moreover it helps to save some space underneath your desk as sub woofer units are mostly quite big. This set was designed with close listening in mind which is the case most of the time we work our computers.
Whole set is built based on MDF speaker cases. MDF is an excellent material for building high quality speakers as it's acoustic parameters are much better than those offered by plastic and other artificial materials. It is almost as if natural material used for the speaker box effected with natural feeling of the produced sound.
Each of the satellites come equipped with 2 driver units (1x1" hi-tone tweeter and 1x4" mid-low tone speaker) which allows it to produce natural and well balanced sound, that is also rich in mid frequencies (these are rarely found in plastic 2.1 speaker sets).
At the same time, set offers total power similar to 2.1 set which means you will not lack the power and dynamics from the reproduced sound, no matter if listening to music, watching a movie or playing computer games.
We deeply believe our set will fulfill the expectations you have... and more. - Olvasható a csomagolás egyik oldalán. A szöveg elég tetszetős, végre nem a szokásos "marketing maszlagot" kapjuk az arcunkba.
