Android-x86 4.4-r1 First Stable Version Released
Android-x86 4.4-r1 key features
- Integrate the ffmpeg as the stagefright-plugins to support much more multimedia files. Now we can play HD and full HD videos in apps.
- Use the latest longterm stable kernel 3.10.52 with more drivers enabled. Most netbooks can run Android-x86 in the native resolution.
- OpenGL ES hardware acceleration for AMD Radeon and Intel chipsets (PowerVR chips are NOT supported).
- Enhance the installer to support upgrade from previous versions (since ics-x86). The text based GUI installer supports ext3/ext2/ntfs/fat32 filesystems.
- KitKat style lanucher (Trebuchet).
- Support Multi-touch, Wifi, Audio, Bluetooth, G-sensor and Camera.
- Support Huawei 3G modem.
- Simulate sdcard by internal storage.
- External usb drive and sdcard are auto mounted to /storage/usbX on plugging. Support filesystem vfat/ntfs/exfat/ext4.
- Support hybrid mode of iso images.
- Multi-user support (max 8).
- Support Ethernet (DHCP only).
- Support 5-point touch calibration on some devices.
- Support VM like Qemu and VMware
Letöltés
Telepítés
Hivatalos oldal
Forrás
