Mar irtam az egyik topikban rola , hogy odaveszett a nyaralasunkon keszult osszes kep es video. Igen, voltam olyan balga, hogy a frissen vasarolt kameramhoz csak egy memkartyat vettem, bizva a markaban, hiszen eddig csak jokat hallottam rola.
Sajnos minden lehetseges megoldas - na jo, a Kurtot nem probaltam- kudarcot vallott, az adatok vegleg az enyeszette lettek...
Viszont lehet erint masokat is, ezert megosztanam, hogy a Transcend visszahivta a 446136 XXXX es 446121 XXXX sorozatszamu kartyakat. (techsupport@transcend-uk.com cimen lehet felejuk jelezni)
Sajnos az enyem is a fenti sorozatbol valo volt
Transcend 16GB SDHC Class 10 Memory Card
Transcend recalls the above product due to possible failure on data transfer with over 4GB usage.
Due to manufacture process issue, item subjected to this recall might cause read/write blocking if in use capacity is over 4GB.
Please follow these steps in order to determine whether your memory card is subject to this recall:
Printed at the back of the SDHC Card is a 10-digit serial number, look at the first 6-digits to determine if your product is subject to this recall:
http://www.transcend-uk.com/Support/ShowSNImg.asp?PartNo=ts16gsdhc10
Serial Numbers subject to recall are: 446136 XXXX and 446121 XXXX
(XXXX represents numbers from 0001 to 9999)
Customers with matched serial number product, please contact Transcend via email at techsupport@transcend-uk.com or telephone (01442) 265494 to arrange a replacement.
If you purchased this product as a gift for someone, please notify the recipient and provide them with this information.
We regret the inconvenience this issue has caused you.
