Sniper Elite V2 Benchmark Report
Created: 2016-11-19 at 14:26:32
Build Version: 1.13, May 23 2014
Average FPS: 54.3
Minimum FPS: 24.3
Maximum FPS: 196.5
Number Of Frames: 4179
Average Frame: 18.399ms
Minimum Frame: 5.090ms
Maximum Frame: 41.212ms
Machine Name: INTEL-CORE-I5
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 32691MB
CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
Number of Cores: 4
GPU Name: NVIDIA GeForce GTX 1060 6GB
Feature Level: DX11.0
Driver version: 21.21.13.7595
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Advanced Shadows: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Compute Shaders: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: ON
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2016-11-19 at 02:10:43
Version 1.15a Build Version: 2014.12.09.001
Average FPS: 57.3
Minimum FPS: 13.3
Maximum FPS: 86.5
Number Of Frames: 4374
Average Frame: 17.439ms
Minimum Frame: 11.564ms
Maximum Frame: 75.006ms
Monitors: 1
System RAM: 32691MB
Number of Cores: 4
Anti-aliasing: HIGH
Supersampling: 4.0x
Obscurance Fields: ON
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
